Waaah bike won't start
Mez
PostPosted: 21:35 - 02 Mar 2014    Post subject: Waaah bike won't start Reply with quote
I know there's a bazillion "my bike won't start" threads and here's another.
My ZL400 is an absolute pain in the arse to start up. In it's defense it barely gets used so I figure that never helps things, but it's always been a bugger to get it running, and I'm finally asking you good people before I scrap the piece of shit.
So, as simply as I can put it:
- fires up on the button, then cuts out after a few seconds, guaranteed
- RARELY will start again no matter how hard I try to balance choke/throttle
- odds are slightly improved if it's jump started from another bike/car (probably will still cut out within 20 secs though)
- plugs are good
- fuel is good
- carbs are clean and balanced
- have fully charged the battery multiple times, doesn't seem to help tbh
It's alright once it's warm, no problems with cutting out or anything.
Just want confirmation that I need a new battery before I blow my lunch money. Karma
My deviantArt gallery - My Youtube profile
Honda CG125 -> Baotian BT49 -> AJS JS125 -> Honda CG125-> Kawasaki ZL400 -> Kawasaki GPZ500
panrider_uk
PostPosted: 22:09 - 02 Mar 2014    Post subject: Reply with quote
Get the battery tested to make sure it's charging fully and holding the charge.
Mez
PostPosted: 22:49 - 02 Mar 2014    Post subject: Reply with quote
I hadn't thought of that. Should I expect to pay for that kind of thing?
clancy
PostPosted: 22:53 - 02 Mar 2014    Post subject: Reply with quote
Got a multi metre ? Have a look herehttps://www.batterystuff.com/blog/how-to-tell-if-your-battery-is-bad.html
KLX 300r
doggone
PostPosted: 23:02 - 02 Mar 2014    Post subject: Reply with quote
I'm not sure why you suspect the battery if it fires initially.
The hard part is turning it over from dead cold with thick oil - supplying spark once running does not require peak voltage, and the charging system should kick in almost immediately anyway.
Clutchy
PostPosted: 23:36 - 02 Mar 2014    Post subject: Reply with quote
What colour spark are you getting?
Clutchy
PostPosted: 23:37 - 02 Mar 2014    Post subject: Reply with quote
How old is the fuel?
Mez
PostPosted: 00:14 - 03 Mar 2014    Post subject: Reply with quote
I know someone with a multimeter so I'll look at that. The fuel is new/recent and the plugs look okay, don't know about the colour of the spark itself.
The battery is taking some sort of charge as after I've boosted it the bike does sound more lively when I try to start it, but it doesn't really improve the success rate.
gavbriggs
PostPosted: 22:34 - 03 Mar 2014    Post subject: Reply with quote
Often when a battery is on it's last legs it will measure 12.5 + volts! mine did on the bandit! but when fully tested the CCA (cold cranking amps) can be reduced. Again men was and had lost 1/3 of its capacity. I bought a slightly larger 200CCA, up from the 150CCA recommended. It starts perfectly and did so from the moment I put the new battery on.
Batteries will really only last a couple of years at best so they are a consumable item.
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 61.25 Kb
