Seized Up
LanceMullin
PostPosted: 00:31 - 03 Mar 2014    Post subject: Seized Up Reply with quote
Hello
i'm new Smile
i got a problem with a bike the Rear Axle Bolt Seized Up wheel won't move
can't get the bolt out so i was thinking in replacing the whole swinging arm
or cut the bolt off
Lance
SQL
PostPosted: 00:34 - 03 Mar 2014    Post subject: Reply with quote
Drill a small pilot hole through the swing arm into the nut and you will then get it out easier
LanceMullin
PostPosted: 00:37 - 03 Mar 2014    Post subject: Reply with quote
ok cool sounds alot easier than to replace the whole swing arm
thank you again
cb1rocket
PostPosted: 10:16 - 03 Mar 2014    Post subject: Reply with quote
Get an impact driver on it. A bike shop may do this for beer money
skatefreak
PostPosted: 10:29 - 03 Mar 2014    Post subject: Reply with quote
weld on a breaker bar,
Get someone to stand on the rear break and jump away Wink
-Jvr
DiscoBiscuit This post is not being displayed because the poster is banned. Unhide this post / all posts.
m3-paul
PostPosted: 13:26 - 03 Mar 2014    Post subject: Reply with quote
Heat, wd40 and an impact gun. I had to undo the swing arm nut on my TZR a few weeks back. It took a 600nm rated snap-on impact gun with lots of heat with liberal doses of wd40 to get it off. I ended up rounding off the 22mm bolt and had to hammer on a 21mm socket and actually ran one battery down on the gun - I was at it that long!!
Bolts can be right gits to get off so I would get it to someone who has these tools.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
SQL
PostPosted: 13:49 - 03 Mar 2014    Post subject: Reply with quote
Vincent wrote:
'Never heard this one before......wherabouts in the swingarm do you have to drill? And into what nut?
Mine was solid, tried heat, plus gas, sledgehammer couldn't get it to move at all.
Drilled through the engine mounting point into the swingarm spindle and put a touch of ACF 50 in there, couple of whacks while turning and bobs your uncle.
Thats if the swing arm goes through the engine.
SQL
PostPosted: 15:28 - 03 Mar 2014    Post subject: Reply with quote
I totally read the first post I did Shifty
to do that id be tempted to use a 9" grinder with skinny cutting discs if I couldn't budge it at all but only as a last resort.
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 72.88 Kb
