turn signal help /indicators PLEASE HELP ME
jason3249
PostPosted: 18:45 - 01 Mar 2014    Post subject: turn signal help /indicators PLEASE HELP ME Reply with quote
Hi all as some of you no iv just finished my project
But I wont to fit indicators to it
Does any one no a quick way or some think
Or does any one no a video
Easiest way possible as abit dum
    clancy
    PostPosted: 19:39 - 01 Mar 2014    Post subject: Reply with quote
    Fit indicators to what ? I don't know what project you've done
    KLX 300r
    jason3249
    PostPosted: 20:44 - 01 Mar 2014    Post subject: Reply with quote
    Sorry mate
    Its a custom job but it still runs of the standard gilera sp 125/180 wiring loom
    Its a gilera runner sp 125/180 well was
    If its possible wont it to run of a seperate circuit
    Just of the battery if thats possible
    https://i1289.photobucket.com/albums/b512/tomgreen1985/Mobile%20Uploads/IMG_20140228_110424_zpsy0bb7ifm.jpg
    jason3249
    PostPosted: 12:07 - 02 Mar 2014    Post subject: Reply with quote
    Any one no a easy set up just of the battery and a switch gear
    Smile
    qarka
    PostPosted: 17:47 - 02 Mar 2014    Post subject: Reply with quote
    You're gonna need a flasher unit. Check ebay.
    https://www.kevinscycleracing.com/images/plastic/Turn%20Signal%20Wiring%20Diagram.JPG
    jason3249
    PostPosted: 00:18 - 03 Mar 2014    Post subject: Reply with quote
    Thanks mate got one some where are copy that Smile
    Robby
    Dirty Old Man
    PostPosted: 08:16 - 03 Mar 2014    Post subject: Reply with quote
    If you can find some bar-end indicators they would look quite good.
    A few things to remember:
    1. If you get LED indicators you need to get an LED relay. The power draw from LEDs is much lower, so if you use a normal relay it will flash too fast.
    2. To simplify the wiring, you don't need to wire all of the earths (negative) back to the battery. Just wire each earth into the frame somewhere, and make sure there is a connection somewhere from the frame to the battery negative. This connection should already exist.
    jason3249
    PostPosted: 08:47 - 03 Mar 2014    Post subject: Reply with quote
    Hi mate all ready cracked that
    Led relays are dear
    So you just buy a higher watt standard one and it works fine think I was running on my other bike 80 watt standard ticker box and it worked good
    Them led ones are abit of a rip of when you can do it my way
    Are look around for some bar end ones as that sounds good
    Thanks all Smile
    Islander
    PostPosted: 11:15 - 03 Mar 2014    Post subject: Reply with quote
    Led relays are dear
    Thanks all Smile
    Errrrm, that's about as wrong as wrong can be.
    An electromechanical relay with a higher load rating won't work with the extremely low load that LED indicators present to it - you need to go the other way. Use a higher rated electromechanical relay and it just won't operate at all - it depends on the load to heat a bimetallic strip to make it flash.
    Also, electronic flasher relays (LED relays) are as cheap as chips - I linked one from Amazon for around £3 the other day. In fact this one:
    https://www.amazon.co.uk/Universal-Flasher-Relay-Motorcycle-Signal/dp/B00I3XKYLQ/ref=pd_rhf_dp_p_t_1_KY0P
    The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
    Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 58.9 Kb
