SV650 Scorpion 54mm link pipe
tinychaos42
PostPosted: 12:39 - 03 Mar 2014    Post subject: SV650 Scorpion 54mm link pipe Reply with quote
Hi everyone,
got a scorpion slip on can off ebay, title said it has 54mm link pipe diameter, and that's seems to be a correct measurement.
Bought it in January for a relatively cheap price, just got round to fitting it. Obvious issue is that I am missing the link pipe itself, and the SV's stock exhaust pipe is pretty much the same size, so the link pipe is definitely needed. Any ideas where I could find one / get one made?
Searched on ebay for the last day and no dice, there are loads of link pipes for viper cans, but looks like the viper slip-ons have a 50-51mm end.
Thanks for the help
Matt B
PostPosted: 12:47 - 03 Mar 2014    Post subject: Reply with quote
Why don't you email Scorpion and see what they say?
[email protected]
tinychaos42
PostPosted: 12:49 - 03 Mar 2014    Post subject: Reply with quote
thanks for the email, will try to do so
tinychaos42
PostPosted: 16:39 - 03 Mar 2014    Post subject: Reply with quote
So turns out scorpion is not selling link pipes separately
UnknownStuntm...
PostPosted: 17:15 - 03 Mar 2014    Post subject: Reply with quote
do you need a link pipe? If it's the standard system on the SV, there's a blob welded on the exhaust to indicate where to chop it off... And 'pretty much' is not quite accurate enough to rule out a small chop under the pipe and doing the bugger up tight?
tinychaos42
PostPosted: 17:23 - 03 Mar 2014    Post subject: Reply with quote
So basically the diameter of the exhaust outlet is 54mm, the pipe coming out of the exhaust is about 5cm straight alu pipe.
https://i.ebayimg.com/t/Carbon-Fiber-Scorpion-Motorcycle-Exhaust-54mm-Link-Pipe-Diameter-SV650-Bandit-/00/s/NjAwWDgwMA==/z/Gm0AAOxy4dNS0IX7/$_12.JPG
the outer diameter of the pipe coming from the engine is also 54mm. The main issue is that on the current stock exhaust setup, the pipe starts to make a slight bend about 2cm after the exhaust can ends. So fitting the two together would involve some nasty work..
NooBish-AbbZ
PostPosted: 09:31 - 04 Mar 2014    Post subject: Reply with quote
i've looked at getting an end can for my SV, and all i've read fitting for involves hack-sawing the OEM system and silicon-ing the end can on to it
SV650S - Feb '14-March '19
XJ6N- Apr '19 -Present
tinychaos42
PostPosted: 09:38 - 04 Mar 2014    Post subject: Reply with quote
This is what I got from the seller:
"The item included the exhaust, the bracket and the link pipe.
The link pipe is show in the attached photo. The link pipe is a single metal collar with two clamps at either end.
Step 1: Use a hack saw or angle grinder to cut the original SV650 exhaust
Step 2: slip the scorpion exhaust (with link pipe attached) over the cut pipe
Step 3: do up clamps"
Don't quite get how he managed to do step 2, as the diameters are almost the exact same (external diameter 1mm bigger on the SV end.
clancy
PostPosted: 10:58 - 04 Mar 2014    Post subject: Reply with quote
Try heating up the link pipe before sliding it on, might work
KLX 300r
UnknownStuntm...
PostPosted: 11:20 - 04 Mar 2014    Post subject: Reply with quote
First, have you got the stock exhaust on the bike? The standard system is one piece, and you need to hacksaw the end can off to fit an aftermarket end can. That's where the blob helps you pick your spot to cut. If you've got an aftermarket can on it already, someone has already done the hardest part.
This pic shows a clamp with 2 bolts, (it's a bit of a stretch to call that a link pipe, but whatever!) I reckon it's sturdy enough to open out and slide over another pipe if it's the same diameter 'closed'.
The last post was made 12 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 62.64 Kb
