aprilia rs 125 clutch problem?
ice.shark
PostPosted: 21:16 - 03 Mar 2014    Post subject: aprilia rs 125 clutch problem? Reply with quote
Hi,
I have a full power rs 125. I changed the gear oil 3 days ago with 75W80 (silkolene light gear oil for wet clutch). I took the bike for a ride today.
Bike was running fine. I stopped for a break after 20-30 minutes of riding @ 30-40mph. At that point, when I shifted in 1st the engine died. Then I couldn't shift into neutral and 1st appeared to be gone.
Eventually this went away after some play with the gear liver. Nonetheless, I couldn't go anywhere because as soon as I shifted into 1st (with clutch lever compressed) the bike would die. Reving to 5-6k (even higher) didn't change the outcome.
So I played with the clutch cable adjuster that's on the lever itself. I unscrewed it as far as It can go. This caused the bike to rev but give no pull (expected). Also, when I compressed the clutch and released the throttle, the revs would stay up for some reason.
Anyway, so I screwed the clutch cable back again but not by much. Now the engine would die again but unlike initially it would not die as soon as I shifted (with clutch compressed) but will die when I released the clutch even if I did it slowly and with the revs quite high (5-6-7k). Revs will go down to 1- 2k and then after a moment it would die.
Based on all this I think:
1. Initially, clutch cable was loose so I must have been burning the clutch?
2. Now the problem is to adjust the clutch cable?
I am a novice with little experience so I could be wrong. I don't understand why when the bike was cold, this problem didn't appear - it only reared it's ugly head when I had been riding for a while.
EDIT: the clear window that shows gear oil level on this bike is plastic and it looks like the bottom of it (the piece that comes in contact with the oil) has been melted. This is how I got it from the previous owner so maybe an issue there?
ice.shark
PostPosted: 21:57 - 03 Mar 2014    Post subject: Reply with quote
I'm seeing what this guy is seeing -> https://netrider.net.au/threads/aprilia-rs125-keeps-stalling-after-stopping-and-taking-off.134684/
PostPosted: 22:47 - 03 Mar 2014    Post subject: Reply with quote
Unless the clutch is dragging very badly it shouldn't stall when you put it in gear.
How did you adjust the clutch? Should slacken the cable off at the bars, undo the lock nut in the middle of the clutch, undo the screw and then gently tighten it until it just starts to have resistance (ie, as it starts to push on the clutch), then undo it a bit (from memory half a turn) and hold it steady while you tighten up the lock nut. Then just adjust the cable at the bar to suit yourself.
ice.shark
PostPosted: 01:09 - 04 Mar 2014    Post subject: Reply with quote
Thanks Keith,
I haven't touched the clutch myself since I bought the bike. The only adjustment I've done is undo the screw at the lever a bit.
So, I've had another go and I think what was probably happening was that I wasn't reving it enough when taking off. Now, it doesn't stall when I take off and I rev it to 8-9k (and it drops to 4k when I release the clutch).
What I still find strange is that bike would stall with clutch compressed when I shifted into 1st. I think what must have been happening is that the cable wasn't tight enough and due to heat expansion the clutch might have been engaged even with lever compressed. That's the only explanation I can come up with.
EDIT: I have found the source of the problem. I had my stand down and the electronics would kill the engine if you shift with the stand down...all those explanations and it boils down to such a simple thing.
ice.shark
PostPosted: 10:48 - 04 Mar 2014    Post subject: Reply with quote
_Iain_ wrote:
Couldnt tell you about the problem, however Silkolene light gear oil is the stuff to use, if you look on the back of the bottle you'll see its actually 10w40.
If you'd put 75w80 in it you'd likely see some problems! Laughing
I'm a bit confused - you say the oil is the stuff to use but that I'll see some problems?
I've heard 75w90 (which is what manual recommends) is too thick for full power bikes. I've seen people recommend 75w80 (i.e. 10w40) for the transmission.
stirlinggaz
PostPosted: 18:56 - 04 Mar 2014    Post subject: Reply with quote
hi,
75/90 is what rotax & aprilia recommend, i always used "lite gear oil",(semi-synthetic) either rock-oil or silkolene with good results.
most folk forget that the clutch is adjustable at BOTH ends.
set the adjuster at 1/3rd out on the bars, & then adjust at engine end with box spanner supplied in the original bike tool-kit or use a socket (13mm? Thinking) from a 1/4 inch socket set, hold it with mole-grips & adjust via the grub screw with a flat bladed screwdriver, iirc, & lock nut you'll find under the plastic cap on side of engine.
its all in the rotax 122 engine manual & the aprilia wsm, both of which are available for download for free.
cheers,
GAZ
The last post was made 12 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 63.7 Kb
