Need Help Adjusting Chain on CB500 (Noob problems)
Icon
PostPosted: 19:21 - 04 Mar 2014    Post subject: Need Help Adjusting Chain on CB500 (Noob problems) Reply with quote
Hey Guys,
I was trying to adjust the chain today on my 2001 CB500 for the first time as it was a bit loose. It's my first bike.
I put the bike on the centrestand and put it into neutral. I loosed the 2 lugnuts and the axle nut.
I then tried to to move the adjuster nuts with a 14 spanner. The nuts moved along the adjuster but I didn't see any change in the adjustment markings. It just left a space between the adjustmen nuts and the end of the swingarm
I somehow ended up overtightening the chain and have had to loosen the axle nut to untighten it.
What am I doing wrong? Sad
Saltire
PostPosted: 19:24 - 04 Mar 2014    Post subject: Reply with quote
Not much more knowledgable than yourself but make sure you get the 'sweet spot' before adjusting.
Spin your back wheel and check the chain tension, you'll find a spot that is tighter than the rest, that is the bit you take measurements from. Tightening the chain at one of it's slackest points wont be pretty when you sit on the bike (which also tightens it a bit) and give it some power.
flumpy7
PostPosted: 21:31 - 04 Mar 2014    Post subject: Reply with quote
Effectively what you are doing when you adjust the chain is moving the rear wheel backwards or forwards. Therefore, you may need to give the wheel a kick forward or pull it back manually a bit to complete the adjustment. The adjustment plates may only move position once you tighten the axle nut. What you may have done is kept tightening the chain because you couldn't see movement along the markings but then when you went to tighten the axle nut the adjuster plates moved into the new position. Tightening the axle nut tensions the chain a little further and this is probably how you ended up going too far. You need to slacken the adjusters off a bit each side, remember only a eight of a turn at a time until you have the desired slack measured by movement of the chain up and down at the centre point between the sprockets. I always leave a small amount of extra slack to account for doing up the axle nut.
Wheel alignment is best not done by the markings. They are notoriously unreliable. Google the string or plank of wood method, or, if you're lazy like me, count the threads on the ends of the adjusters to make sure they are the same each side. Once you have the alignment about right, future adjustments will be easier as you will just need to make sure you turn the adjusters the exact same amount each side. If you are doing this at regular intervals it will only mean a tiny adjustment each time which makes it easier to keep both sides the same.
Hope this helps
2012 Sinnis apache
The last post was made 12 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 36.89 Kb
