Changing Gear
dolly3900
PostPosted: 15:51 - 05 Mar 2014    Post subject: Changing Gear Reply with quote
Daft question, but apart from starting and stopping, does anyone else not bother with the clutch in normal, every day riding?
With the sequential gearboxs on bikes, it is much easier to slip into gear, both up and down, without the need for the left hand input, so I was just wondering if I am alone in this.?
I know when knocking down a couple to overtake, the hand does come in useful for a smoother change, but in day to day riding? not needed.
Something I have always done (I say always, me with less than 12 months onthe road), but then again, I tend to do it in the van as well (at least, going up the gears anyway).
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
SQL
PostPosted: 15:59 - 05 Mar 2014    Post subject: Reply with quote
Should use it going down gears, but going up is fine.
PostPosted: 16:05 - 05 Mar 2014    Post subject: Reply with quote
Anything other than 1st>2nd and 2nd<1st is clutchless for me.
dolly3900
PostPosted: 16:13 - 05 Mar 2014    Post subject: Reply with quote
Glad it is not just me then Smile
DrDonnyBrago
PostPosted: 16:19 - 05 Mar 2014    Post subject: Reply with quote
I use the clutch on 99% of gear changes.
groovylee
PostPosted: 16:41 - 05 Mar 2014    Post subject: Reply with quote
Same here. I find clutches are easier and cheaper to replace than gearboxes. Thumbs Up
That said, it is always worthwhile knowing the right way to carry out clutch less gear changes for the one time that your clutch cable snaps Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
David072
PostPosted: 16:55 - 05 Mar 2014    Post subject: Reply with quote
I always use the clutch, and didnt realise you could do so without Embarassed
CyrilSwan
PostPosted: 17:02 - 05 Mar 2014    Post subject: Reply with quote
This!
Current: Honda 2015 MSX125.
Previous: Honda 2012 CBF125.
MattJ
PostPosted: 17:13 - 05 Mar 2014    Post subject: Reply with quote
It's really not very hard. My clutch cable snapped when I was at Donington last year on a track day and I had to ride 60 miles home without a clutch and I didn't really have many problems apart from when I had to stop twice, put it in neutral before I had to stop then run with the bike, jump on and ram it into first. Laughing Admittedly, most of it was on the motorway so it just stayed in 6th gear, but changing up and down wasn't a problem at all, was just setting off.
Depends on the bike though, changing up without a clutch shouldn't be an issue with any bike really but I can imagine downshifting without a clutch on something like a 1litre V-Twin might be a little hairy, on my IL4 600 it wasn't a problem.
That said, for normal riding I almost always use the clutch, just because my bike is a bit old and gearbox probably a bit worn, it's more prone to find a neutral between gears (not 1 & 2) without using the clutch. If I had a newer bike with a better gearbox I probably wouldn't use the clutch.
Suntan Sid
PostPosted: 17:41 - 05 Mar 2014    Post subject: Reply with quote
I'd agree with this, although I'd qualify it by saying that I pull the clutch lever in when changing gear. Whether or not the lever is pulled in enough to engage/disengage the clutch is another matter.
Whilst doing some work on my, old, CBR600 I reckoned I probably wasn't using the clutch, once I was out of first, because the bite point was a lot further in than the amount I normally pulled the lever in!
Moral of the story, (if you're worried about it), is check and adjust your clutch lever when necessary!
Old Git Racing
PostPosted: 18:33 - 05 Mar 2014    Post subject: Reply with quote
Hardly ever up, always down.
OGR
thewhyoffry
PostPosted: 19:53 - 05 Mar 2014    Post subject: Reply with quote
MichuNo9 wrote:
This!
This! x2. My mind is blownnnn
unluckyluke
PostPosted: 20:03 - 05 Mar 2014    Post subject: Reply with quote
I always use the clutch when shifting, but I'm a mechanical sympathy kinda guy. It takes milliseconds to pull the clutch in so why wouldn't you?
PostPosted: 20:29 - 05 Mar 2014    Post subject: Reply with quote
Force of habit. I always use the clutch.
Vracktal
PostPosted: 20:40 - 05 Mar 2014    Post subject: Reply with quote
I use the clutch unless it's cold, then I keep my paws wrapped firmly around the heated grips.
Even when I do use the clutch though, I only dip it very slightly, enough to slip it a little while I slide the next gear up/down.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
Clutchy
I like to mix it up, if riding fast I sometimes forget about the clutch.
I'm a bit clutchy when it comes to it Wink
Wonko The Sane
PostPosted: 21:08 - 05 Mar 2014    Post subject: Reply with quote
Always used the clutch on my own bikes,
On my CBT I realised there was a lot of play in the E reg CG so started shifting without and carried on doing so for the rest of the day.
Rigga
PostPosted: 21:19 - 05 Mar 2014    Post subject: Reply with quote
As others have said, I pull the clutch in just by habit but I know full well that sometimes I've only just feathered it.
Current bike: Honda CBR 1100xx
Dave70
PostPosted: 21:25 - 05 Mar 2014    Post subject: Reply with quote
I always use the clutch myself, except on the odd occasion when I've messed up for one reason or another. However, my gearbox didn't seem to like it very much, judging by the loud 'clunk' sound it made.
Are there any rules of how you're supposed to do this and what are the risks, or indeed advantages?
Alex A
PostPosted: 21:55 - 05 Mar 2014    Post subject: Reply with quote
I rarely clutchless shift down (when I do, it's more for the novelty than anything else), and occasionally clutchless shift up when riding hard. But as with others above, 99% of the time I use the clutch. Smoother, and offers much better control metering in the power and engine braking. It doesn't take any longer really, and I personally feel that frequently downshifting without the clutch would be no good for the gearbox or engine.
delsol
PostPosted: 22:35 - 05 Mar 2014    Post subject: Reply with quote
Clutch-less gear changes are just fine, with only a little thought needed to 'timing' the change on a chain drive.
I feel less comfortable with clutch-less changes on a shaft drive, timing of change is more critical so I find.
I hate feeling the 'lash' on the drive shaft when I get it wrong, maybe I should not be doing it at all.
Advice readily accepted.
sabian92
PostPosted: 22:48 - 05 Mar 2014    Post subject: Reply with quote
I shift up without a clutch sometimes although never down.
That being said the bite on my clutch is basically just as you pull the lever in so I hardly have to touch it as it is. Cool
Kari-On This post is not being displayed because the poster is banned. Unhide this post / all posts.
i.p.phrealy
PostPosted: 02:07 - 06 Mar 2014    Post subject: Reply with quote
Try driving a car without using your clutch pedal. I had to in an old Sierra as the cable snapped and my ex wife chose that night to go into labour!
So no pressure then! Laughing
The last post was made 12 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 127.08 Kb
