GPU running at 100% all the time...
RhynoCZ
PostPosted: 12:05 - 07 Mar 2014    Post subject: GPU running at 100% all the time... Reply with quote
I'm really losing my temper here. Mad
ATi HD6790, vista 64bit,
When I boot up the system, it's alright, but after a couple of seconds the GPU runs at 95-100%, temp stands still at around 65°C and the whole PC case goes mental, because all the fans go at max revs.
What could it be? The system is nearly a fresh instal. Neutral
CaNsA
PostPosted: 12:08 - 07 Mar 2014    Post subject: Reply with quote
got any funky live backgrounds going on?
Tarmacsurfer
PostPosted: 13:21 - 07 Mar 2014    Post subject: Reply with quote
There are a fair few examples of mining malware around at the moment. As Cansa says, check your process list.
I'm immortal. Well, so far.
RhynoCZ
PostPosted: 13:30 - 07 Mar 2014    Post subject: Reply with quote
Spot on, well the GPU is alright now, but the all other fans still run at max revs no matter what I set in bios, the moment the system boots up, the case fans go at max revs. Confused
The speedfan app does not work at all. I mean I can't controll the speed in windows. Thumbs Down
GPU temp 37°C, CPU temp 42°C, System 38°C, not really a burning hot PC, is it? Confused
PostPosted: 14:29 - 07 Mar 2014    Post subject: Reply with quote
Mining bitcoins for a Russian botnet?
RhynoCZ
PostPosted: 18:39 - 07 Mar 2014    Post subject: Reply with quote
I found the bastard file: mnckxbrm.exe.
Now, how do I get rid of it?
It gest back with every re-boot, even got some bluescreens today. Mad
CaNsA
PostPosted: 19:26 - 07 Mar 2014    Post subject: Reply with quote
double check that filename.
google only shows this thread as a result.
RhynoCZ
PostPosted: 19:56 - 07 Mar 2014    Post subject: Reply with quote
The moment I stop the process, the GPU usage drops to the idle.
https://i970.photobucket.com/albums/ae184/RhynoCZ/Everything%20else/mnckxbrmfile_zpsbd89638c.jpg
CaNsA
PostPosted: 19:58 - 07 Mar 2014    Post subject: Reply with quote
disable restore points,
malware bytes
spybot search and destroy
ccleaner reg cleanup until there are no results.
RhynoCZ
PostPosted: 20:13 - 07 Mar 2014    Post subject: Reply with quote
I tried the ccleaner, there found the file and erased it, did re-boot and the file is no more. But the case fans still run like crazy. I set 60% speed in bios, everything alright, then when the system boots up they go 100% no matter how cold the HW is. Confused
CaNsA
PostPosted: 20:45 - 07 Mar 2014    Post subject: Reply with quote
malware bytes
RhynoCZ
PostPosted: 21:50 - 07 Mar 2014    Post subject: Reply with quote
Alright, how do I disable restore points?
CaNsA
PostPosted: 23:13 - 07 Mar 2014    Post subject: Reply with quote
Tut Tut
1st result on google when searching for :- How do i disable restore points.
https://www.howtogeek.com/howto/windows-vista/disable-system-restore-in-windows-vista/
RhynoCZ
PostPosted: 09:39 - 08 Mar 2014    Post subject: Reply with quote
It's done, I guess. Thumbs Up
The last post was made 12 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 80.73 Kb
