Steam Cleaning
chickenstrip
PostPosted: 08:02 - 07 Mar 2014    Post subject: Steam Cleaning Reply with quote
Knowing that I should avoid wheel bearings, shock linkages, electrics etc, is it a bad idea to steam clean a bike?
I used to do it with older air cooled Jap stuff with no problems, but not so sure on the painted finish of a Fazer thou engine. I'm wondering if it might just take all the paint off, especially where it's already a little flaky at the front of casings.
Thing is, I ACF'd it for the first time ever this winter, and have let the crud build up; looks like it'll be quite a job to remove it all, especially down pipes etc.
Advice?
ws4936
PostPosted: 08:27 - 07 Mar 2014    Post subject: Re: Steam Cleaning Reply with quote
Advice?
Elbow grease, and soap?
That acf50 is a magnet for crud, but I wouldn't take a steam cleaner to the bike. Pressure washer at a distance for sensitive areas, closer up for hardier grimy areas
If everything seems under control, you're just not going fast enough.
panrider_uk
PostPosted: 09:19 - 07 Mar 2014    Post subject: Reply with quote
I'd use a pressure washer rather than steam clean.
Water vapour can get into more bits than water droplets.
c-m
PostPosted: 12:08 - 07 Mar 2014    Post subject: Reply with quote
If you can do it on a car engine then you can do it on a bike engine. It's not like cars don't have bearings too, and engines are similar (or even the same if you have a NC700 and Honda Jazz)
The last post was made 12 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 40 Kb
