Anti social neighbouring
1cyl
PostPosted: 14:16 - 08 Mar 2014    Post subject: Anti social neighbouring Reply with quote
Hey folks.
Bit of a waffle:
Wondering if anyone can comment on a minor inconvenience that's manifested in my life.
When I first moved in to my house in 2010, my neighbour agreed verbally to let me cleat a wire along the bottom of her fence, up over her garage and into mine as had been done by the previous occupant. But subsequently removed before sale.
Great! I did it. (green)
Recently however, she's become a more difficult individual to communicate with. (I think it's the fact I'm half her age and have a fractionally bigger plot, I bought a dog bark last year, and now have a baby cry as well. Plus shes no longer out puffing in her garden so I think she's quit smoking, making her irritable).
I'm a considerate neighbour in all aspects. (2 cars, and no revving motors or late night 6 hours of grinder action)
But now she wants me to remove it as she's getting her fence replaced at the end of the month and doesn't want it there anymore, as she might be thinking about moving (yeah right!).
I use the power daily. So running an extension lead from a socket off my own fence every time I want to flip a switch or charge a drill is easy, but obviously a tad annoying after nearly 4 years of the good life of garage power!
I'm thinking of just leaving the SY cable i used (light weight armoured) from my fence to my "P"(yellow), across her access, in a bit of this: https://bit.ly/1cDB7nu. As a permanent fixture that could be removed in seconds.
But I'm sure she's going to be difficult about it and look for a reason to stop me.
Can anyone see a reason why this plan may not succeed? Legislation regarding communal/shared access or cables? Shes the sort that will try to make my life a misery by the book, although I wouldnt put a deliberated trip and suing past her :-/, or finding evidence that a sharp edged spade has attempted to hack through my 3core 1.5mm.
Why can't people just be reasonable hey!?
Any other ideas for a win win solution? Or is it going to just be a case of suck it up for me, and get used to uncoiling/coiling.
Had thought about a pole in my garden and an over head steel cable line but I think 3m length is the maximum allowed and it'd be well over that. Or perhaps a genny with an akra pipe running for a few hours a day, just for lols Mr. Green
Painted pics attached.
Cheers for any "light" that you feel inclined to shine in my direction Smile.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Ribenapigeon
PostPosted: 14:29 - 08 Mar 2014    Post subject: Reply with quote
Your screwed. You may as well try and run a cable to a garage in the next town. She has evry right to deny your cable. Most likely a friend or reletive has told her your cable is dodgy.
Do any of the other garages have power? maybe you could do a deal with another garage owner?
berzerker
PostPosted: 15:10 - 08 Mar 2014    Post subject: Reply with quote
Dig a metre deep trench and sink a cable
or
Solar panels, leisure batteries and an inverter.
jeddy11
PostPosted: 15:22 - 08 Mar 2014    Post subject: Reply with quote
Can you not run it as i have marked on map rather too obvious is that the front of the garages ?
As mentioned ask neighbor if you can dig it under ground in a nice thick armored cable or underground as marked on my diagram ..
https://i185.photobucket.com/albums/x232/jeddy11/image_470_zpsd607f7a5.jpg
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
1cyl
PostPosted: 15:36 - 08 Mar 2014    Post subject: Reply with quote
Digging a trench would mean digging up the car park. I'm not that desperate.
Just considering what issues I'm likely to face running the cable above ground around what would be the perimeter of her propery (but essentially across what is a communal car park) on what would appear to be a temporary basis, but for a permanent duration.
Ribenapigeon
PostPosted: 15:42 - 08 Mar 2014    Post subject: Reply with quote
Mains cables run across communal/other peoples land would mean a heap of planning permission shit. A good generator would be cheaper and a 12v system run of some solar panels on the roof.
Nope.
PostPosted: 18:47 - 08 Mar 2014    Post subject: Reply with quote
Just buy a genny and run it on an open pipe at all hours of the day. When she complains just explain that you had no choice since you had to remove your cable.
panrider_uk
PostPosted: 19:12 - 08 Mar 2014    Post subject: Reply with quote
Noisy Genny + bonfire on washday
Ribenapigeon
PostPosted: 19:44 - 08 Mar 2014    Post subject: Reply with quote
Why not build a workshop in your garden and rent out the garage to pay for it?
Dischord
PostPosted: 20:40 - 08 Mar 2014    Post subject: Reply with quote
Run it on a Catenary wire from your house straight to your garage, cheapest and easiest way. And while you're at it hang a little flag off it with 'haha sucker' written on it Middle Finger
2012 KTM EXC 250
1cyl
PostPosted: 21:00 - 08 Mar 2014    Post subject: Reply with quote
I have considered this as mentioned.
The whole car park is, as you can see in the diagram, accessed under my property, so there is actually a height restriction. So I could have a strong case if I stay above that height. It's just the distance Issue. I'm fairly sure I'm only allowed 3m in a domestic setting. Although I don't have a copy of the 17th edition wiring regs to hand.
Dischord
PostPosted: 21:10 - 08 Mar 2014    Post subject: Reply with quote
Don't quote me on this but I'm not sure there is a set distance specified in the regs, just a minimum height. What size is the supply cable? The garage supply from my house-garage (gable end to gable end) is over 15m and that also goes over shared access. I bet if you did it during the day when she's out she wouldn't even notice it Laughing
2012 KTM EXC 250
Dischord
PostPosted: 21:13 - 08 Mar 2014    Post subject: Reply with quote
I've just looked at the layout diagram again, your property is set out almost exactly like mine. We're hoping to get the house on the market this year and move to somewhere more private, it's a right pain in the ass!
2012 KTM EXC 250
1cyl
PostPosted: 21:21 - 08 Mar 2014    Post subject: Reply with quote
Yeah it does suck being all ontop of one another. And new builds are slung up so fast its worrying. But you do get alot of square footage for your quids and they do have to meet all the up to date regs.
The other issue would be passing over her space. She'd be on at me about the possibility of it breaking and damaging her jag parked underneath. I suppose I could go further out/away and increase cable length.
So the pink option:
https://bit.ly/1ckRQvq
Would just need to find a sutible pole to cement and bolt to one of my fence posts.
defblade
PostPosted: 12:15 - 09 Mar 2014    Post subject: Reply with quote
I'd already thought "tell her you'll have to run a genny instead then" before I'd even finished your post; looks like I was beaten to it; it's still the best advice here (overhead wire might be good if that fails though!)
PostPosted: 22:06 - 10 Mar 2014    Post subject: Reply with quote
Could you bury some armoured cable in the (what looks like gravel) bit where the bins are stored up to the corner of the fence then lift the (again, what looks like) bricks in the parking area, run it under those and re-lay them?
1cyl
PostPosted: 12:02 - 13 Mar 2014    Post subject: Reply with quote
I did consider this in the early days after moving in. But again it's still along the perimeter of her property and therefore I predict she's likely to be difficult and unreasonable if I approach her about it.
I'm thinking caternary is my strongest option at the mo, from a 3.5m post in my garden, (which will also be for a high fly washing line to my house) and terminating on the right of my garage door, which is further but will keep the height up and the wire further away from her property/parking space.
Measured it and its about 15m. So I've ordered some 3mm stainless steel wire rope Thumbs Up. With a dozen SS zip ties.
Thanks for all the advice Auntie BCF. Will update if she kicks off.
Conzar
PostPosted: 12:16 - 13 Mar 2014    Post subject: Reply with quote
Burn the witch?
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
PostPosted: 13:31 - 13 Mar 2014    Post subject: Reply with quote
I wasn't suggesting you asked her. Wink
Be interesting to see EXACTLY where her property finishes.
You can get a land registry extract for less than a tenner.
syl
PostPosted: 22:50 - 13 Mar 2014    Post subject: Reply with quote
Mole it from the bottom of the garden, underneath the driveway and bring it up inside the garage.
Current bike: Kawasaki Z750S
1cyl
PostPosted: 23:05 - 13 Mar 2014    Post subject: Reply with quote
That's got to be expensive? And surley require just as much paperwork and hassle before they'll commit?
Giz a Quote? Wink
syl
PostPosted: 00:48 - 14 Mar 2014    Post subject: Reply with quote
Won't be cheap, but do it while they're away and they'll never know it's there - unlike a wire over the top of their garden. Couple of hundred for a short distance I suspect, done in an afternoon - try getting someone who works for the local water/electric company to do it on the side.
1cyl
PostPosted: 21:57 - 19 Mar 2014    Post subject: Reply with quote
Just thought i'd update for the hell of it.
So i just went ahead and pushed the button. She flipped....
Within 5 minutes of me stringing the catenary, she lived up to my expectations and got straight on my case with hostile aggressive tones. Complaining that she wasn't happy about this 'eye sore' passing over "her property". (Corner of her parking space). She demanded that i remove it and accused me of 'council estate antics Razz.
Rather than responding equally on the offensive, or giving her the finger,
I remained civil and understanding, and simply stated that: I appreciate she no longer wants a wire along her fence, so this has forced me to consider other alternatives, such as 'this' and possibly a generator Wink . I continued by reiterating that of course I'd rather not have a ghastly over head eye sore. I'd much prefer that while her new concrete post fence is put in the bloke buries an SWA cable for me underneath it and bill me for any additional cost, while she produces a written agreement to cover any legal aspects, (what ever they might be Rolling Eyes ). Surprisingly, she decided to exercise some self restraint, and loosely agreed to consult her fencing bloke, and get back to me. I concluded to her that the catenary will currently remain as a temporary solution.
Off she went.
I'll be incredibly surprised if she even asks him. But i can at least hope. Instead I predict that she'll put the time and energy into trying to round up the other neighbours while getting on the blower to the council, making a case to force me to remove the catenary, because that's what many would do now adays.
I'll then remove it without a fuss, as I'm not a fighter. Then i'll buy the Genny Wink
1198
PostPosted: 08:00 - 20 Mar 2014    Post subject: Reply with quote
Can you get a straight through carbon fibre exhaust for a generator?
map
Mr Calendar
PostPosted: 11:47 - 20 Mar 2014    Post subject: Reply with quote
You bad, bad man. You're going straight to hell Wink Very Happy
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 136.7 Kb
