Upright Bike Storage
Snipet
PostPosted: 13:17 - 13 Mar 2014    Post subject: Upright Bike Storage Reply with quote
Im about to convert my front garden into a drive for my bike, and have been looking at different ways to keep the bike stored.
Ive come across this:
https://i.ebayimg.com/t/MOTORBIKE-STAND-FOR-FRONT-WHEEL-FOR-TIRES-530-670mm-DIAMETER-MOTORCYCLE-SUPPORT-/00/s/MTIwMFgxMjAw/z/t8UAAOxyf1dTINyN/$_12.JPG
https://www.ebay.co.uk/itm/MOTORBIKE-STAND-FOR-FRONT-WHEEL-FOR-TIRES-530-670mm-DIAMETER-MOTORCYCLE-SUPPORT-/121293757088?pt=UK_Motorcycle_Parts&hash=item1c3dabdaa0
And was wondering, if I place up against a wall and secure it in place. Would it be secure enough to keep the bike upright.
Obviously the bike would still be chained, but was thinking it would be so easy to just ride up, slot the wheel in and bobs your uncle it parked.
What are peoples thoughts on this, would it work, how long for, would it be strong enough for storing a bike for a long while or just an hour or two maintenance.
First Bike: Pulse Rage 125cc Second Bike: Kymco KR Sport 125cc Third Bike: Kawasaki ZR7-S 750cc
Forth Bike Honda VFR 750cc Fifth Bike Honda NT650 Deauville Fifth Bike Suzuki GSX650F
PostPosted: 13:21 - 13 Mar 2014    Post subject: Reply with quote
Most bikes have a stand, you kinda flick it out with your foot... usually makes it not fall over? Wink
Shinigami
PostPosted: 13:23 - 13 Mar 2014    Post subject: Reply with quote
^this
I see no benefit to doing what you're thinking of doing...
orac
PostPosted: 14:39 - 13 Mar 2014    Post subject: Reply with quote
there ok for keep the thing up right while working on the machine with it strapped down, but as soon as the is a breeze the thing will fall over unless strapped down.
just use the stand, or a good quality padock stand. the onyl time the bake needs ti be up right is when checking the oil or dong other work on the machine
_Troy_
PostPosted: 14:49 - 13 Mar 2014    Post subject: Reply with quote
*Fourth.
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
BTTD
PostPosted: 15:36 - 13 Mar 2014    Post subject: Reply with quote
It'll most probably work fine - I have a trailer with something similar albeit much heavier duty and welded to the frame of the trailer so more stable, but the biggest ball ache will be pushing the bike back off, over the hump immediately behind the front wheel which is the pivot point for the holder bit. If your bike is light, and the pivot not to high then it'll be no big deal, but if the bike is close to 270 kilos and the hump is quite pronounced it'll be a pain. Especially if the fronts gone a bit soft and you can't get to the valve.
Wonko The Sane
PostPosted: 16:58 - 13 Mar 2014    Post subject: Reply with quote
Should hold it up happily for some time, not sure how well after a few British 'summers' or rain storms as they're usually known.
Snipet
PostPosted: 17:32 - 13 Mar 2014    Post subject: Reply with quote
Yes I know it has a thing on the side that pops down for it to stand up with, but I saw this;
https://www.youtube.com/watch?list=UU8ZUcPTpwolWtXquBHXnoPw&v=htPp1BBJfH8
and thought 'ohhhh that could be a good idea, wonder whether I could build a version myself' sort of thing.
map
Mr Calendar
PostPosted: 18:01 - 13 Mar 2014    Post subject: Reply with quote
I would suggest if converting to drive combine storage and security with something like this...
https://www.nutz4bikes.co.uk/WebRoot/BT/Shops/BT3428/4ADD/D40D/7A95/2240/651A/0A0A/33E9/42CA/sep2002.jpg
Site info click here.
Bolt stand into concrete base obviously.
I'm sure there are other variations around at different price points.
-Matt-
PostPosted: 18:25 - 13 Mar 2014    Post subject: Reply with quote
Do like the look of that thing - although for the price/hassle of it all, i'd just get a good ground anchor and chain and whack an alarmaed disc lock on it if you're mainly doing it for security. Can shuffle it around with some point-turns to get it in tight spaces most of the time.
PostPosted: 18:36 - 13 Mar 2014    Post subject: Reply with quote
How would that wheel chock help with storage as it just looks like an unnecessary expense?
CaNsA
PostPosted: 18:42 - 13 Mar 2014    Post subject: Reply with quote
Drilling holes in a solid base?
I hear-by revoke your mancard for bitching about drilling holes.
-Matt-
PostPosted: 18:58 - 13 Mar 2014    Post subject: Reply with quote
Forgot to quote Razz I was commenting on thing in the link https://www.youtube.com/watch?list=UU8ZUcPTpwolWtXquBHXnoPw&v=htPp1BBJfH8
Although that is still just 4 drill holes installation wise Whistle - bit large to lumber around though for a de-carded weakling Sad
Hugh Farking Cant
PostPosted: 20:10 - 13 Mar 2014    Post subject: Reply with quote
You thinking about that for your garage like Matt?
Did you ever get that sorted ?
-Matt-
PostPosted: 20:26 - 13 Mar 2014    Post subject: Reply with quote
Yeah Embarassed it sort of just... fitted, with a bit of back n' forth Whistle its still in Bristol at the moment as i've been too lazy to install the ground anchor and other security rubbish yet, but it will go in fine with the car.
Seems my space-judgement is non-existent Doh! [half way down] https://www.bikechatforums.com/viewtopic.php?t=282761&start=125
Hugh Farking Cant
PostPosted: 20:30 - 13 Mar 2014    Post subject: Reply with quote
The last post was made 12 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 90.43 Kb
