engine flush
woll89
PostPosted: 21:14 - 13 Mar 2014    Post subject: engine flush Reply with quote
hello
im going to change the oil and filter on my yam fzs6 its a bit black has any one used engine flush on bike engines? do you recommend it or not?
Peugeot speedfight 50cc, yamaha dt 125r, honda cb 125, Branson 125 thing, zenco by 125, current bike yamaha fzs 600
Fisty
PostPosted: 21:23 - 13 Mar 2014    Post subject: Reply with quote
Get engine hot
Drain oil
Change filter
Replace oil
Ride.
Fatter and faster than Fret
Llama-Farmer
PostPosted: 21:26 - 13 Mar 2014    Post subject: Re: engine flush Reply with quote
woll89 wrote:
hello
https://www.bikechatforums.com/viewtopic.php?t=192049
Consensus seems to be that it's pointless on a bike.
With my car I do a flush, but I usually do 6000 miles between changes. On a bike you're better off doing a 2nd oil change after maybe 100-200 miles.
Bikes use a lot less oil than a car, so won't be too expensive, even if you go for super duper fully synthetic oil. Once you've done that and cleaned most of the crap out of the oil system, keeping on top of oil changes regularly should make sure it's all good.
The oil in my bike is still dark golden coloured, probably due a change next month but I've not ridden much this year, probably less than 2000 miles.
woll89
PostPosted: 21:33 - 13 Mar 2014    Post subject: Reply with quote
thanks dont no when the bike was last serviced got it December time don around 5-700 mile now got 19000 on it so thought best get it done before she gets some hammer in the summer, thanks for the link
paul
Llama-Farmer
PostPosted: 21:42 - 13 Mar 2014    Post subject: Reply with quote
Did the oil change on my car today actually. I've got a pair of these that only ever get worn when changing oil.
https://www.diy.com/nav/fix/protective-clothing-workwear/gloves/gloves/B-and-Q-PVC-Gloves-12217504?skuId=12748210
Oil resistant and keep most of the heat from your hands.
You'll want to drain the oil when it's hot... (within a few minutes of a 20-30 minute ride) it's runnier then and also all the "bad stuff" thats caught up in the oil won't have time to separate, so it'll come out with the oil rather than get left behind.
Sump and nut will get rather hot so normal latex gloves or bare skin is not wise.
I'd suggest you go for a leisurely ride for about half an hour, then let the bike idle for a few minutes while you get everything to hand, like drain pan, new filter, paper towels etc.
Oh and state the obvious time... don't start the engine until you've filled up with fresh oil.
(I have done it before, accidentally. I left the oil draining from sump, then changed pollen/odour filter, spark plugs & leads, cleaned air filter, then decided to finish off with the front of the car, so fitted the new oil filter and backed the car off the ramps. Realised as I was halfway down the ramps. Fook it another 2 seconds isn't gonna hurt while I finish getting off the ramp. Fresh oil, 12,000 miles later, no apparent damage done.)
woll89
PostPosted: 21:56 - 13 Mar 2014    Post subject: Reply with quote
just seen the bit in small text Laughing not done that myself yet but touch wood n all that. got to do my van next then the mrs car, she had only had the car a month (pug206) i told her dad i wanted a service he say no it dont but i went ahead and did it pulled the oil filter housing off to find the filter had disinterested, so much for not needing a service 3 weeks later a bit of the old filter got caught up in the oil pressure sensor
(he is a tight arse his car has not been serviced for 6 years Confused )
Llama-Farmer
PostPosted: 22:08 - 13 Mar 2014    Post subject: Reply with quote
Ha yeah I've learnt from my mistake. Now when I service a car, first thing I do I leave the new 5 litre bottle of oil on the drivers seat. Cant start the engine without noticing now.
Disintegrated filter? Never seen that before, must have done a lot of miles since it was put in haha.
Some people just don't even consider servicing... my sister didn't have her car done for years, then she went to Thailand/Vietnam/Cambodia for a month and her car needed an MOT. It failed on 7 things, so I fixed all those, sorted out all the Advisories too and thought I'm on a roll I may as well service it too. Oil, filters & spark plugs only came to 10% of the cost of everything! I donated my time for free. Next year I nabbed her car when she went on holiday again and did another service.
Now she's got a new Fiat 500 on PCP so has to get it done at a VAT garage to keep the warranty valid. Left to me to actually book it in and get the car there and back though wasn't it! (So I made sure I took it to Stoneacre Fiat Rotherham... 2 minutes walk from Rainbow BMW motorcycles - how convenient)
woll89
PostPosted: 22:18 - 13 Mar 2014    Post subject: Reply with quote
when i did the service it was on 98k and a boy racer had had it tinted windows led rear lights it dont look to bad but im betting he had never done a full service on it all that needs doing now is the cambelt but im not to confident doing that never done one but i suppose you have got to learn one way then i can do it on my van if all goes well
Llama-Farmer
PostPosted: 22:53 - 13 Mar 2014    Post subject: Reply with quote
Never done a cam belt myself, was planning to do it last summer on my car, then in february the water pump shaft seal went. Car was 9 years and 3 months old. Cambelt interval is 10 years.
I wouldn't have had the time to do it for several weeks, I was down south yet all my stuff was up north, and my bike was going in for MOT & going away for dyno jetting, so needed car for transport.
Local privately owned garage did it in one morning for just over £200. Better than having to wait several weeks, and a lot better than if I'd got it wrong and needed an engine rebuild/swap.
PostPosted: 22:54 - 13 Mar 2014    Post subject: Reply with quote
To be honest the consensus seems to be it entire massively screws up your engine, or offers no noticeable gains. I wouldn't bother.
Robby
Dirty Old Man
PostPosted: 23:01 - 13 Mar 2014    Post subject: Reply with quote
The idea of using a flush is to shift sludge. Unless your engine happens to be an ancient, iron-block car engine that has missed several services and only been run on the cheapest 20W50 mineral oil, you don't have any sludge.
Northern Monkey
PostPosted: 09:39 - 14 Mar 2014    Post subject: Reply with quote
paul
Edited due to an inability to read.
Just swap the oil for whatever is recommended in the manufacturers hand book. Don't chuck in any extra bonus chemicals. It's never a good idea
PostPosted: 11:01 - 14 Mar 2014    Post subject: Reply with quote
Look at it like this - anything that's suspended in the oil will come out with the oil. Anything that's not suspended in the oil is harmlessly resting in the bottom of the sump. Why would you want to deliberately loosen any of that crap then pump it round all your shell bearings?
DrSnoosnoo
PostPosted: 11:08 - 14 Mar 2014    Post subject: Reply with quote
I know of a guy who sold a 350z to my mate, who showed a receipt to him, proud that he had the oil changed 5 years ago .... What is wrong with people?
bikenut
PostPosted: 15:50 - 14 Mar 2014    Post subject: Reply with quote
:D see cmsnl for the exploded views.....
note clutch basket seem to act as centrifugal crap traps on bikes, difficult to clean the crap from them unless clutch baskert removed........
also lots of noooks and crannies, oil troughs etc etc etc which trap crap also, so oil goes black relatively quickly.....
if "sump floor" is get at able, the crap lying there could be flushed out with low pressure spray and solvent........like a car w/washer type spray and solvent.....
high pressure will tend to splatter the crap all inside the engine.........!!!
regular oil and filter changes and invest in a magnetic sump plug, money well spent! :karma:
nuts about bikes
The last post was made 11 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.84 - MySQL Queries: 13 - Page Size: 88.93 Kb
