All electrics cuts out
DynamiteBoy
PostPosted: 17:27 - 17 Mar 2014    Post subject: All electrics cuts out Reply with quote
Hi All,
I am currently experiencing an odd electrical problem with my Kawasaki ER6 2007 that I can not resolve.
Issue: The bike will start and run from around a few seconds to 2 minutes. At a certain point ALL the electrics will cut out, no light, display... nothing. Its like the battery has been disconnected. The battery still has power as my heated grips will work. Turning the key in the ignition then becomes temperamental. Sometimes the everything will re-work and display, FI etc all come on. Most of the time I have to keep turning the key until all the power returns. Upon re-starting I am back to square one, will run for short period (feels shorter) and will then suddenly cut-out.
I have check battery volt reading with multimeter when off and also running, all looks fine. I have checked all fuses including the main fuel and inspected wires under tank and seat. So far no luck and it is driving me nuts.
Does anybody have any suggestions or come across anything similar in past? Don't want to go spending lots of money replacing parts in hope of resolving.
"I dont like my Job anymore - I dont think i'll go" OfficeSpace
Honda CG125 (sold) - Kawasaki GPZ500s (sold) - Kawasaki Zephyr 550 (sold) - Kawasaki er6n (current work horse)
331X2
PostPosted: 17:30 - 17 Mar 2014    Post subject: Reply with quote
Sounds like a dodgy ignition switch. Measure the resistance across it when both open and closed, open should measure infinite (or out of range) and closed (ignition on) should measure very little i.e. 0.1 Ohms.
I take it your heated grips are not fed from the ignition live?
Edit: If it is a high resistance contact on the ignition switch this will cause heat build up on the contact leading to higher resistance leading to higher heat leading to... You see where I'm going with this?
J.M.
PostPosted: 17:37 - 17 Mar 2014    Post subject: Reply with quote
You checked the fuses, but did you check their condition? A corroded surface can lead to an intermittent connection.
I'd also be checking the connections of the ignition barrel plug, and generally tracing the 12v right from the start of the battery, and keep probing it along the wire until I find the point at which the 12v is lost.
2004 R1 & 2018 XSR900
DynamiteBoy
PostPosted: 17:40 - 17 Mar 2014    Post subject: Reply with quote
My heated grips are connected direct to battery so do not need the ignition on to work.
Thanks for the suggestion, ill try this. Anyone else have any ideas or where to look? Planning on making a day testing.
PostPosted: 17:44 - 17 Mar 2014    Post subject: Reply with quote
fatjames had an issue on here (sure it was him) that ended up being a relay.
Scrap that, was a relay for headlight, might be similar though - https://www.bikechatforums.com/viewtopic.php?p=3794950
Copycat73
PostPosted: 17:44 - 17 Mar 2014    Post subject: Re: All electrics cuts out Reply with quote
yep .. was the ignition contacts at the bottom of the barrel was corroded & full of crap... strip & clean to fix.
caveat emptor
Dischord
PostPosted: 19:08 - 17 Mar 2014    Post subject: Reply with quote
Check all earths are good?
2012 KTM EXC 250
DynamiteBoy
PostPosted: 11:07 - 23 Apr 2014    Post subject: Reply with quote
Fixed: Quick update if anyone has same problem in the future.
Turned out 2 wires on the loom were corroded and needed replacing along with the starter relay. Since these have been changed the bike is running fine.
Thanks for all the suggestions.
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 55.61 Kb
