Gate Locks
Doomsnite
PostPosted: 11:44 - 18 Mar 2014    Post subject: Gate Locks Reply with quote
Putting a new wider gate in the garden for my bike and want to now have a lock put on which I can lock from the outside using a key when I go out on it. Any suggestions that would be weather proof?
Would rather not re-use an internal padlock on the outside but have heard that mortice locks and the like can rust in the weather.
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
delsol
PostPosted: 21:45 - 18 Mar 2014    Post subject: Re: Gate Locks Reply with quote
Low tech, low cost, open up the mortice lock casing and smother it in this https://www.toolstation.com/shop/White+Grease/p10203
Higher tech, open lock as above and ACF50 it, even less cost (if you already have some ACF50).
Tamsin
PostPosted: 21:58 - 18 Mar 2014    Post subject: Reply with quote
Just a quick point, no point in locking the gate if its a lift pin one...
Doomsnite
PostPosted: 22:07 - 18 Mar 2014    Post subject: Reply with quote
A latch? No its a new gate and not putting a latch on. Goin for a custom wide gate to go with my new concrete anchor 😃
James83
PostPosted: 22:10 - 18 Mar 2014    Post subject: Reply with quote
He means the hinge - common design for gate hinges is a hinge that simply slots over a barrel. Problem with that is, there nothing to stop someone lifting it off again, making the lock at the other end irrelevant.
Jonathan A wrote: tart.
Doomsnite
PostPosted: 22:38 - 18 Mar 2014    Post subject: Reply with quote
The one Ive found just moves a bolt across just like a pad bolt. you couldn't lift that gate up if the bolt is across ?
stevo as b4
PostPosted: 00:40 - 19 Mar 2014    Post subject: Reply with quote
I've used a 5lever mortice lock designed for a back door on my Gate. I lube it with WD40 every so often and it's fine. I would also have at least one HD locking bolt on the back of the gate though, and if you want it to be secure, I'd position it lower down on the back of the gate, so you can't put your arm over the top of the gate to reach it if possible?
Screw Loose
PostPosted: 13:53 - 19 Mar 2014    Post subject: Reply with quote
Never mind lifting the gate up, I've got a friend who went to get their bike out one day to find it missing, and a massive tyre mark going all the way up and over the 6ft fence, somehow the pikey gits had managed to lift the damn thing up and over. No idea how the hell they managed it, but they did Shocked
MBK Nitro 50cc -> CBF 125 <\s>
CBT: February 2012 - Full licence August 2013
Doomsnite
PostPosted: 14:55 - 19 Mar 2014    Post subject: Reply with quote
Would be easier to just drive right through it
map
Mr Calendar
PostPosted: 15:40 - 19 Mar 2014    Post subject: Reply with quote
Hinge side bolts would stop that.
Like these...
https://www.lowcosting-locksmiths.co.uk/perch/resources/hinge2-.jpgimage from here. Other sellers and cheaper prices available.
berzerker
PostPosted: 15:54 - 19 Mar 2014    Post subject: Reply with quote
I've used something similar to this https://www.locksonline.co.uk/acatalog/CISA-42311-50-Gate-Lock.html It has quite a deep 'throw'; the bolt moves back once when unlocked and then a bit further once the handle is pulled.
I finished it off with a nice chrome handle similar to this https://www.doorhandlesdirect.co.uk/20/section.aspx/3159/19mm_round_bar_euro_door_handles_paa
Doomsnite
PostPosted: 16:08 - 19 Mar 2014    Post subject: Reply with quote
I went for this one in the end..
https://www.gatewrights.co.uk/locks.html
cagiva gezzer
PostPosted: 19:17 - 19 Mar 2014    Post subject: Reply with quote
Have one of the above and works fine. Fit with anti tamper screws to prevent it being taken off too easily.
The last post was made 12 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 75.75 Kb
