Decarbonising an engine with tap water... Myth?
Clutchy
PostPosted: 00:47 - 19 Mar 2014    Post subject: Decarbonising an engine with tap water... Myth? Reply with quote
I know it's a car in the video but would be the same for a bike right? Can anyone explain how this works to me or if this is a weird myth? Seems very weird and seeing as I've never heard of a manufacture recommending this at any service intervals i'm jubious as to what this does?
I don't want to do it to my car, just got me thinking and as we have some massively clever workshop peeps on this forum, it might create a interesting discussion:
https://www.youtube.com/watch?v=izvz18xgfA0
CaNsA
PostPosted: 00:51 - 19 Mar 2014    Post subject: Reply with quote
Give it a whirl,
https://i.imgur.com/LC2XTNB.jpg
Tungtvann
PostPosted: 01:24 - 19 Mar 2014    Post subject: Reply with quote
Seems pretty crazy, but I've seen lots of testimonials from people who have tried it with good results.
cb1rocket
PostPosted: 01:45 - 19 Mar 2014    Post subject: Reply with quote
It's just the light mist of water that cleans it, nothing more. Generally taken through the air intake. Some turbo cars have this as standard with water injection spray that not only lowers the intake temperature but cleans the pistons too!
gavbriggs
PostPosted: 05:29 - 19 Mar 2014    Post subject: Reply with quote
It works to clean the pistons very well when water gets into the combustion chamber of a v8 range rover!!!
Mind you that was from HGF tho!
PostPosted: 11:50 - 19 Mar 2014    Post subject: Reply with quote
I didn't believe you could clean a turbo charger with ground walnut shells.
You can.
DrDonnyBrago
PostPosted: 12:16 - 19 Mar 2014    Post subject: Re: Decarbonising an engine with tap water... Myth? Reply with quote
If you have a head gasket fail, coolant enters the combustion chamber and turns to steam. The pistons etc will look very clean as they have effectively been steam cleaned.
The idea of that method is that water is taken into the running engine, evaporates and the internals are steam cleaned in much the same way. Whether it is safe or not I have no idea. Other commercial methods I know of use various solvents (alcohols) etc rather than water. If it needed doing by a dealer, I suspect they'd remove the head and clean it mechanically.
I wouldn't do it to my car, but I wouldn't be too surprised if it did work at least a little bit.
PostPosted: 12:38 - 19 Mar 2014    Post subject: Reply with quote
There's nothing in inherently suspicious about water injection. The Saab 99 Turbo used it as stock, for cooling rather than cleaning though.
It's the sort of thing I'd try just for the lulz.
Ben90
PostPosted: 13:47 - 19 Mar 2014    Post subject: Reply with quote
I imagine distilled water would be better than tap or bottled as it will leave no dry residue.
There's also purpose made stuff, I think its called Revive, originally developed for jet engines but also sold as a lazy man's way of cleaning a coked up turbo diesel.
Yamaha FZ6 S2
skatefreak
PostPosted: 16:42 - 19 Mar 2014    Post subject: Reply with quote
Its actually recommended if you're running a car on vegetable oil to do this once in a while as the veg oil can leave a more deposits than derv/bio diesel.
The most popular method is using a wall paper stripper or other steam emitting device and just pipe the steam in via the air intake leaving the engine to run a little above idle running a litre or two of water through (can take a little while mind you).
Its worth noting that the engine should be brought up to temp first to avoid condensation within the engine and taken for a good rag after to ensure any moisture remaining is driven out of the system.
I can't see why it wouldn't work with a motorbike engine.
Try it out and let us know Very Happy
-Jvr
Ps, using steam avoids contaminants/hard water causing issues/further build up (mmm, limescaly!).
Tungtvann
PostPosted: 17:49 - 19 Mar 2014    Post subject: Reply with quote
Using bottled water might be better then. We had to use bottled water in the kettle out in Afghanistan and it didn't have a single bit of limescale in it after years.
stevo as b4
PostPosted: 18:11 - 19 Mar 2014    Post subject: Reply with quote
I can't see it causing any harm if your sensible, but IMO it would have to be a pretty old high mileage bike engine to get into a state where such cleaning would make any difference.
Also I don't think it's as effective at cleaning carbon off the valve stems and the back of the valves as it is at cleaning the actual combustion chamber.
If you have a well maintained sportsbike engine that's done say 25k and been run on decent premium fuel, I don't think there will be much to clean inside the chambers unless it's been running stupidly rich or burning shit loads of oil?
A 100k mile engine maybe it would make a worthwhile difference though.
Llama-Farmer
PostPosted: 19:11 - 19 Mar 2014    Post subject: Reply with quote
Never knew it was good for cleaning. I know people who run water injection or methanol injection for cooling the intake air (read more power) on turbo cars.
Kinda makes sense though, but I can imagine some muppet will just shove a hosepipe in there and bend all the con rods.
Wouldn't have thought a bike would need it. Diesels are much more likely as they can burn badly and leave filthy stuff and when the turbo starts to go it'll burn even worse and often they'll have 200,000+ miles done on morrisons* diesel. (*other terrible filling stations are available).
djrikki
PostPosted: 04:02 - 20 Mar 2014    Post subject: Reply with quote
It works.
BUt also reminds me of this ...
https://www.audiforums.com/forum/off-topic-5/hey-guys-please-help-my-mods-gone-wrong-80267/
Llama-Farmer
PostPosted: 04:28 - 20 Mar 2014    Post subject: Reply with quote
djrikki wrote:
Ah I remember that. Some people are just mad eh!
Tungtvann
PostPosted: 04:29 - 20 Mar 2014    Post subject: Reply with quote
Or the guy who put NOS (the energy drink) in his GSXR.
Teflon-Mike
tl;dr
PostPosted: 09:34 - 20 Mar 2014    Post subject: Reply with quote
I haven't heard of any-one decarbourising a petrol engine since they stopped making them with push-rods, or selling petrol with lead in it, that might have made three kids in bradford slightly more mentally dissabled than they were, and replaced it with benzene derivatives that could give any-one cancer, instead!
How many people remember....
a) Petrol station forecourt attendants actually putting petrol into the tank for you?
b) asking if you want a shot of 'redex' with it?
And I thought I was a practitioner of arcane technology!
Robby
Dirty Old Man
PostPosted: 09:47 - 20 Mar 2014    Post subject: Reply with quote
I think I'm agreeing with Tef again. That's twice in one year, not good.
Your petrol engine doesn't need to be decoked. The only petrol engines that still get dirty inside are 2-strokes, and they go bang long before the carbon deposits cause a problem.
Next you'll be wanting an engine flush to clear sludge, and a magnet on the fuel line to reduce fuel burn.
Teflon-Mike
tl;dr
PostPosted: 10:11 - 20 Mar 2014    Post subject: Reply with quote
Nah! I want to find that carburettors that made any engine make 200bhp, and return over 200mpg, that was such a threat to world ecconomic stability, the big oil companies put a hit out on the Canadian inventor, while the CIA burned all the patent applications, but is supposed to be an a Tartan Short-bread tin in Glasgow, where the inventor's grandson hid it after the oil cartel hit on his dad, before the sons own unfortunate accident in a ford Zephyr on the only straight part of the A71.
panrider_uk
PostPosted: 10:24 - 20 Mar 2014    Post subject: Reply with quote
I was that forecourt attendant.
In addition* to redex there was 2,3,4 and 5 star petrols to choose from.
I added extra redex to my moped to make more smoke
*no pun intended
djrikki
PostPosted: 13:31 - 21 Mar 2014    Post subject: Reply with quote
Ben-B wrote:
Some mother do av em Very Happy
The Artist
PostPosted: 13:54 - 21 Mar 2014    Post subject: Reply with quote
I remember reading a very long thread on an engineering forum about water injection.
It seems it can be done but not just willy nilly. It has lots of benefits for performance, increases CR slightly, cools the air as it goes in so it is more dense as well as displacing a certain amount of air.
No mention of cleaning the inside of the engine though.
djrikki
PostPosted: 14:53 - 21 Mar 2014    Post subject: Reply with quote
It does clean a bit too - though when youre getting more ponies having a shiny cylinder wall isnt high on the check list Very Happy
jjdugen
PostPosted: 16:46 - 21 Mar 2014    Post subject: Reply with quote
I, too was that petrol attendant, did it in the evenings after my actual job to save up or my first bike. What with the wages AND tips I soon had enough for my first Ducati. I used to fill up the cars, but made sure the loop of the pump line was emptied of the small amount of petrol into a can, by the end of the night I'd have nearly a gallon in there. Same with the oil, put a pint in, making sure that there was still a good amount in the bottom of the tin, that went into another handy can. We ran four bikes off the back of that job for a year or more.
Llama-Farmer
PostPosted: 18:03 - 21 Mar 2014    Post subject: Reply with quote
Well it beats letting it run out all over the floor which is what everyone seems to do with the diesel these days. Nearly decked it when I went in to pay after filling my car the other day, people are just careless.
The last post was made 12 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 127.4 Kb
