| kawasakizxr |
 kawasakizxr Derestricted Danger
 Posted: 17:52 - 18 Mar 2014 Post subject: Bleeding the Radiator |
Hi doing a coolant change on my zxr 400 today I have done this job before.
Drained the old coolant by disconnecting one of the radiator pipes.
The manual says there are drain plugs on the engine however i have never used these as i worry i wont get them to reseal.
I let the old coolant drain for a good 30 mins. Fitted the pipes back and filled slowly with coolant. At just over 1 litre the radiator was full.
I squeezed the radiator pipes then ran the bike for a few seconds and put a bit more in. I have around 1.25 litres in the radiator. i ran the bike again for a few minutes.
I have rocked the bike side to side and also squeezed the pipes again. I have seen some air escape but not much. I have now filled the reserve tank to the upper level and i have used a total of 1.75Litres
The manual says with both the radiator and the reserve tank full i should need 2.3L so i am a bit concerned that i dont have enough coolant and dont want to overheat my engine.
If anyone could give me a idea of whats wrong that would be great.
Thinking about it maybe i still had some coolant left over in the engine that didnt drain fully ?
Thanks  |
| Aff |
 Aff World Chat Champion
| kawasakizxr |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| ws4936 |
 ws4936 World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 08:40 - 19 Mar 2014 Post subject: |
Run until hot but don't wait for fan it will not come on unless the system is pressurised as the fan switch trips at 102 C and water boils at Sea level air pressure at 100 C !!
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| kawasakizxr |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| kawasakizxr |
| Wafer_Thin_Ham |
| SQL |
 SQL World Chat Champion
| kawasakizxr |
| Wafer_Thin_Ham |
| kawasakizxr |
 Posted: 11:14 - 19 Mar 2014 Post subject: |
Yeah will do
Thanks for your help |
| Llama-Farmer |
| kawasakizxr |
 Posted: 13:10 - 19 Mar 2014 Post subject: |
yeah doing both the oil and filter  |
| kawasakizxr |
 Posted: 13:36 - 19 Mar 2014 Post subject: |
Drain bolt washer is now stuck on the drain bolt
Normally they just fall off
I have always replaced the washer evrey oil change, The bolt was new a year and a half ago
Have tried pressing it of with my hands and its stuck on there. The washer has marks on looking as though its been crushed too much.
Not having the best of luck with this bike simple jobs i have done before  |
| Aff |
| Llama-Farmer |
 Posted: 16:52 - 19 Mar 2014 Post subject: |
| kawasakizxr wrote: | Drain bolt washer is now stuck on the drain bolt
The last time I replaced a sump plug washer (on my car) was when I replaced the sump plug with a magnetic one, about 2 years and 4 oil changes ago.
Use a torque wrench and tighten the old one up to the specified tightness, fill with oil then run the engine and let it warm up,
check for leaks etc.
Once it's warmed if it's still not leaking, rev the engine a bit, keep checking for leaks.
If there's still no leaks, cable tie a bit of kitchen paper around it, go for a quick ride 5-10 minutes round the block a bit and check the kitchen paper when you're back.
That'll tell you if it's leaking or not. If it is, stick a second washer on and retighten to correct torque. If it isn't then just get a new washer and/or plug for next time.
Cannot stress the use or importance of a torque wrench enough. Sump plug isn't too critical but there are plenty of other bolts/threads you'll ruin if you over tighten, and that can cause a world of pain |
| CaNsA |
 CaNsA Super Spammer
 Posted: 18:47 - 19 Mar 2014 Post subject: |
| Hetzer |
 Hetzer Super Spammer
| Llama-Farmer |
| Robby |
 Robby Dirty Old Man
 Posted: 10:52 - 20 Mar 2014 Post subject: |
This is why you should always follow the manual to do a coolant change. Half of it is in the rad, half of it is in the engine.
If the coolant is old, then I tend to drain it, fill with water, run the engine up to temp, then drain the water and refill with the correct coolant. Don't mix different coloured coolants.
If you're not getting enough coolant in and the thing is overheating, then you haven't filled it properly.
From an empty system, I tend to do the following:
1. Put in half of the coolant through the radiator.
2. Slacken off the lowest drain screw and make sure that just coolant comes out - it may also work as a bleed screw. Tighten it back up.
3. Put the rest of the coolant in until the radiator is full.
4. Look for any other bleed screws, open them and make sure only coolant comes out.
5. Fill the header tank to the min line.
6. Start the engine with the rad cap off. Run it until the thermostat opens, at which point the coolant may drop. Turn off the engine, let it sit for a minute, top up the rad.
7. Put the rad cap back on, fill the expansion bottle to the max line.
8. Run the engine up to temp. If there is any air in the system, it will get forced out of the rad cap into the expansion bottle.
9. Let the system fully cool before doing anything. This is the most important bit, as the system cools it will draw in any required fluid from the expansion bottle. This will not happen if you remove the rad cap.
The easiest way to cock up a coolant change is to try to take a short cut, then worry too much and keep removing the rad cap. It's a self-balancing pressurised system, but if you remove he rad cap it won't self-balance. |
The last post was made 12 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
