Helmets: What the hell is "thermoplastic"
Ribenapigeon
PostPosted: 20:23 - 19 Mar 2014    Post subject: Helmets: What the hell is "thermoplastic" Reply with quote
You see helmets manufactureres say are made of thermoplastic, what exactly does that mean though?
Minty
PostPosted: 20:25 - 19 Mar 2014    Post subject: Reply with quote
Moulded to shape via the medium of heat?
My fingers smell of your mum.
Fisty
PostPosted: 20:36 - 19 Mar 2014    Post subject: Reply with quote
Inb4 unhelpful wall of text from teffers.
A thermoplastic, or thermosoftening plastic, is a polymer that becomes pliable or moldable above a specific temperature, and returns to a solid state upon cooling
Fatter and faster than Fret
Ribenapigeon
PostPosted: 20:57 - 19 Mar 2014    Post subject: Reply with quote
Yes, fellas, but, what type of plastic are these helmets made from. I ask because im interested in what kind of paints and coatings are safe to use on helmets.
Fisty
PostPosted: 21:00 - 19 Mar 2014    Post subject: Reply with quote
Boozehawk wrote:
Yes, fellas, but, what type of plastic are these helmets made from. I ask because of im interested in what kind of paints and coatings are safe to use.
Would you like me to cut your food up for you too?
https://en.wikipedia.org/wiki/Thermoplastic
PostPosted: 21:08 - 19 Mar 2014    Post subject: Reply with quote
In terms of helmets, thermoplastic means "not a composite". Thumbs Up
PostPosted: 21:20 - 19 Mar 2014    Post subject: Reply with quote
We teach that the cheaper end of the spectrum of helmets, thermoplastic etc are not designed to be painted or have stickers on them. Fibreglass ones you can paint and put stickers on.
Apparently some paints and resins can react with the plastic composite.
haroman666
PostPosted: 21:23 - 19 Mar 2014    Post subject: Reply with quote
Thermoplastics are able to be re-heated and re-moulded.
Thermo-set plastics can be formed once and once only. The only state change you can then achieve from heat is chemical breakdown (The plastic burns/blisters).
As for the type of plastic I couldnt tell you. I'd imagine some companies use one type and others use another type. Most major properties will be similar.
Ribenapigeon
PostPosted: 22:18 - 19 Mar 2014    Post subject: Reply with quote
I didnt look on wikipedia because I thought "thermoplastic" was just some science sounding bolloks thought up by marketing so they didnt have to say "cheapoplastic" Smile
Shaft
PostPosted: 23:52 - 19 Mar 2014    Post subject: Reply with quote
Actually, I reckon you aren't far from the truth there, I've always taken thermoplastic to be a modern euphemism for polycarbonate, which is what plastic lids were made of in my day.
Poly lids had a bit of a stigma attached to them, not helped by the fact that they nearly always had a very clear seam down the middle, where the two halves of the moulds were fused.
I've always assumed they changed the name to get away from the cheap, shitty rep that poly had.
Nick 50
PostPosted: 23:58 - 19 Mar 2014    Post subject: Reply with quote
This Thumbs Up
A lot of plastic used in impact resistant products are usually made from ‘Bisphenol A’ polycarbonate which is very tough (used in Riot Shields).
However, stick something like Acetone (nail polish remover and found in paints) on it and it becomes very brittle instantly.
Like such:
https://www.youtube.com/watch?v=5VF77eU5xfg
tracks
PostPosted: 00:06 - 20 Mar 2014    Post subject: Reply with quote
Nick 50 wrote:
What are those oddities on his feet?
Cool vid Thumbs Up
Shaft
PostPosted: 00:25 - 20 Mar 2014    Post subject: Reply with quote
This Thumbs Up
Like such:
Back in the 80s, when I was a bike instructor specialising in safety equipment, I did an experiment involving GRP and polycarbonate lids.
I got two of each (all equally well used) and did an all over design on one of them, using ordinary vinyl striping tape, which is the stuff they make stickers out of and has some kind of solvent in the adhesive.
Having done that, I left them for a week, then attacked them with a normal weight hammer, in front of the class.
The GRP helmets both behaved the same way, they took repeated hits and it took real effort to penetrate the shell.
The poly lids both broke first hit, the plain one along the seam I mentioned earlier, the striped one just shattered.
I also should point out that the received wisdom of the time, was that poly also deteriorated when exposed to UV light.
I appreciate that materials and manufacturing processes may have changed since then, but I still wouldn't put stickers on a plastic lid.
Ribenapigeon
PostPosted: 00:27 - 20 Mar 2014    Post subject: Reply with quote
Tracks wrote:
Cool vid Thumbs Up
They are his feet. Smile
Ariel Badger
PostPosted: 00:28 - 20 Mar 2014    Post subject: Reply with quote
Rubber fetish safety socks.
PostPosted: 00:33 - 20 Mar 2014    Post subject: Reply with quote
Also likely to not be petrol proof.
Ribenapigeon
PostPosted: 00:52 - 20 Mar 2014    Post subject: Reply with quote
I just bought a new helmet. Im going to see if I can find any plastic identifier markings on the old one.
smegballs
PostPosted: 00:59 - 20 Mar 2014    Post subject: Reply with quote
Well it's obviously a good thing that rioters can't into materials science.... Rolling Eyes
A good barrage of acetone-filled water balloons into police lines before the charge... Shifty
Llama-Farmer
PostPosted: 02:37 - 20 Mar 2014    Post subject: Reply with quote
I thought most plastics, including those used in helmets/knee sliders/boots & gloves etc were a composite. because they were formed with two or more different materials with differing properties. (Might be wrong, any chemists care to correct or clarify?)
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 106.04 Kb
