| chrisjose1913 |
 chrisjose1913 Nova Slayer
| Fisty |
 Fisty Super Spammer
| dextersaurus |
 dextersaurus World Chat Champion
| temeluchus |
| bladerunner |
 bladerunner World Chat Champion
| chrisjose1913 |
| Kickstart |
 Kickstart The Oracle
| Ariel Badger |
 Ariel Badger Super Spammer
| chrisjose1913 |
 Posted: 00:46 - 20 Mar 2014 Post subject: |
| chrisjose1913 |
| Ariel Badger |
| Kickstart |
 Posted: 00:54 - 20 Mar 2014 Post subject: |
Nope. 15mpg is hideous (unless you are thrashing an RG500). 30mpg might be possible with a highly tuned 125 2 squeak being thrashed, but 55~60mpg is probably not a major issue. My RS125 averaged 55mpg over a few thousand miles when I kept a record (with a best of 74.5mpg when taking things very easy during the fuel strikes).
To the OP. Check the carb carefully. Is it the standard carb? Check the main jet size, that the carb needle valve is sealing, etc.
| chrisjose1913 |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 08:30 - 20 Mar 2014 Post subject: |
| Ariel Badger wrote: | Do you mean 15 MPG is acceptable Keith? |
MCM managed to get a Yamaha DT175 down to 32mpg back in 1978... though they did that by romping it around an enduro course for a few hours in second and third gear..... bike made 15bhp... double the power, double the fuel consumption... guess if you tried hard enough you could get a hi-po trailie down to those sort of numbers, without seriouse motor malady or leak... but you'd have to be pretty darn heavy handed with it, I think!
Leaky exhaust in this case, possibly a hinderance, but expansion chamber pushes 'lost' charge back into the cylinder, doesn't really effect how much gets sucked into the crank case each cycle; likely to cause loss of power and weak mix pinking, that would incline rider to open the taps more to make up for lost power, and hence use more fuel, but to get 1/4 anticipated consumption? I dont think that's going to be the sole problem.
Might not be that dire though, £7's worth, just about 5l ish, in a dry tank; could still be unknown quantity of juice in the tank under the reserve take-off, or whatever level sediment up the filter gauze lets the res take of drain from.
Says it 'ran out'... does that mean the tanks actually dry again and used all the fuel that was put in? Specs I found say 14l tank... which is a £20 fill, £7 is going to be barely 1/3 full, possibly little over reserve, and sucking shit from the bottom of the tank, clogging fuel-tap, float or main jet, stopping fuel get to motor will give same symptoms as running out of fuel.
Fix exhaust, that ent going to help regardless. Clean carb. Clean fuel tap, probably clear the problem; but, fill the thing up to the top; look for leaks... have jerry can handy just in case you find one, to decant fuel into so as not to be wasted; then ride it 20miles, fill it to the top again, note how much you have to put in to get to the same fill level... note suggested consumption. Repeat to get more accurate sample. And prob will probably have gone away.
Add on Edd:-
| chrisjose1913 wrote: | Hello i have a cagiva w8, with exhaust issues. i will be doing a temp fix as i want to make/get a race exhaust for it. |
The exhaust on a two stroke is critical to good running. 'Exhaust Issues' that demand or suggest finding a replacement pipe dont really sound like merely a missing or leaky gasket.......
Tackling these 'exhaust issues' could then be key to all.
In the mean time, if you value your piston and combustion chamber.... dont run it with 'exhaust issues'...they have a habit of melting if the expansion chamber isn't doing its job.
However; fact that the thing is running at all, may imply that to combat knackered exhaust causing lean mix detonation, some-one has upped the fueling with massive carb jets or jammed the choke enritchement plunger in the 'on' position to get it to run moderately clean enough to flog on. Could be worth looking at. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
 - Super Spammer
| chrisjose1913 |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:49 - 20 Mar 2014 Post subject: |
You put petrol in the tank.. and it starts dripping out of the exhaust?
Without kicking the engine over or anything?
It just runs right through?
Well... doesn't sound possible, TBH!
Obeying gravity; Fuel goes in tank filler, comes out tap, through pipe, into carb float bowl, via needle valve controlled by float; from float bowl, up through jets... into carb venturi under throttle slide.
Can then go two ways, depending which way is lower.. towards air filter or towards crank case. Crabk case is probably lower... so path would follow the inlet tract, down the inlet manifold, past the reed block into the crank case. At that point, I would expect it to stop.
Crank case is sealed, its a two stroke; it would probably take about 50cc or so to fill bottom of the crank case to the level of the crank seals of bottom of the reed block... would litterally be swimming in neat petrol.
To get up into the cylinder, from which it might start dribbling down the exhaust port and into the pipe to escape at the manifold gasket; it would have to completely fill the crank case, flood up above the level of the cylinder and transfer ports, which would usually be higher than the inlet tract, which means that long before the crank case was that full, it would have been going both ways out the carb and dripping out the air-filter, and well, probably every fucking where!
Dont make sense; to get to the exhaust flange, excess fuel would have to be pumped back up against gravity by the motor being turned over.
Are you sure its leaking from the exhaust flange, or is fuel dripping from there, having dribbled out of a split or pin hole in the tank, or a spl;it hose, onto the outside of the exhaust pipe, and run down to lowest point of pipe, where you see drip as if coming through the joint?
OR, have you kicked the motor over and then its dripped from manifold?
Follow the logic.
Investigate leak more carefully; lift the tank and check it for leaks off the bike, if you have to.
After that; then back to list; remove and clean carburettor; if float valve sticking, then could be flooding the engine, and if turned over to pump excess into the cylinder, leaking from pipe flange; but only if you have turned the engine over. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
