2 stroke bike really bad fuel consumption
chrisjose1913
PostPosted: 23:01 - 19 Mar 2014    Post subject: 2 stroke bike really bad fuel consumption Reply with quote
Hello my 2 stroke cagiva w8 is using way to much fuel. I filled it with, about £7 worth of fuel the other day. The tank was bone dry at the time. Anyway i got at most 15 miles out of it, and she ran out. any suggestions on what it can be ? i really don't want a 4 stroke again. this consumption can't at all be right. i will add the exhaust has a little leak.
1997 CB500
Fisty
PostPosted: 23:09 - 19 Mar 2014    Post subject: Reply with quote
Id suggest a leak. thats about 15mpg......
Fatter and faster than Fret
dextersaurus
PostPosted: 23:12 - 19 Mar 2014    Post subject: Reply with quote
Sounds like the exhaust has a leak
temeluchus
PostPosted: 23:13 - 19 Mar 2014    Post subject: Reply with quote
the thing must reek of petrol!
Check the overflow hoses from the carby, see if its dribbling any fuel out. Check the tank for leaks, follow the fuel line down as well.
It's probably a good idea to check the float height and replace the float needle whilst you are at it.
bladerunner
PostPosted: 23:47 - 19 Mar 2014    Post subject: Reply with quote
As said before....have a look if the carb is overflowing and draining your fuel. Would expect it to four stroke like hell if your jetting was allowing that much fuel to the engine. Was it on a run on national roads or start stop in town?
chrisjose1913
PostPosted: 00:03 - 20 Mar 2014    Post subject: Reply with quote
Some great reply here, thanks.
Anyone know the best mileage achievable i can get ? i am willing to sacrifice a little performance. if possible i would like to get around 55/60 MPG
1997 CB500
PostPosted: 00:36 - 20 Mar 2014    Post subject: Reply with quote
Suspect if set up reasonably and ridden reasonably that you could get that mpg.
Ariel Badger
PostPosted: 00:45 - 20 Mar 2014    Post subject: Reply with quote
Does it smoke a fair bit? If not the fuel is not going through the combustion chamber.
chrisjose1913
PostPosted: 00:46 - 20 Mar 2014    Post subject: Reply with quote
Thanks kickstart Very Happy you seem to be very helpful on BCF. almost all my threads you reply on. A++++++ member Thumbs Up I will see what i can do with this bike, i really do not want a 4 stroke again. All this best to you too ~chris Smile
1997 CB500
chrisjose1913
PostPosted: 00:47 - 20 Mar 2014    Post subject: Reply with quote
yes it smokes, from what i was explained by the past owner the exhaust gasket was missing, it is blowing a little, but not much.
1997 CB500
Ariel Badger
PostPosted: 00:49 - 20 Mar 2014    Post subject: Reply with quote
Do you mean 15 MPG is acceptable Keith?
PostPosted: 00:54 - 20 Mar 2014    Post subject: Reply with quote
Nope. 15mpg is hideous (unless you are thrashing an RG500). 30mpg might be possible with a highly tuned 125 2 squeak being thrashed, but 55~60mpg is probably not a major issue. My RS125 averaged 55mpg over a few thousand miles when I kept a record (with a best of 74.5mpg when taking things very easy during the fuel strikes).
To the OP. Check the carb carefully. Is it the standard carb? Check the main jet size, that the carb needle valve is sealing, etc.
chrisjose1913
PostPosted: 01:48 - 20 Mar 2014    Post subject: Reply with quote
Just out of interest will lowering the needle help ? from what i know it leans out out a little.
1997 CB500
bikersupermot...
PostPosted: 01:54 - 20 Mar 2014    Post subject: Reply with quote
my rs125fp / 3 gives about 35mpg. so u shud be getting at least double what you are.
what colours the smoke?
tinybikes
Teflon-Mike
tl;dr
PostPosted: 08:30 - 20 Mar 2014    Post subject: Reply with quote
MCM managed to get a Yamaha DT175 down to 32mpg back in 1978... though they did that by romping it around an enduro course for a few hours in second and third gear..... bike made 15bhp... double the power, double the fuel consumption... guess if you tried hard enough you could get a hi-po trailie down to those sort of numbers, without seriouse motor malady or leak... but you'd have to be pretty darn heavy handed with it, I think!
Leaky exhaust in this case, possibly a hinderance, but expansion chamber pushes 'lost' charge back into the cylinder, doesn't really effect how much gets sucked into the crank case each cycle; likely to cause loss of power and weak mix pinking, that would incline rider to open the taps more to make up for lost power, and hence use more fuel, but to get 1/4 anticipated consumption? I dont think that's going to be the sole problem.
Might not be that dire though, £7's worth, just about 5l ish, in a dry tank; could still be unknown quantity of juice in the tank under the reserve take-off, or whatever level sediment up the filter gauze lets the res take of drain from.
Says it 'ran out'... does that mean the tanks actually dry again and used all the fuel that was put in? Specs I found say 14l tank... which is a £20 fill, £7 is going to be barely 1/3 full, possibly little over reserve, and sucking shit from the bottom of the tank, clogging fuel-tap, float or main jet, stopping fuel get to motor will give same symptoms as running out of fuel.
Fix exhaust, that ent going to help regardless. Clean carb. Clean fuel tap, probably clear the problem; but, fill the thing up to the top; look for leaks... have jerry can handy just in case you find one, to decant fuel into so as not to be wasted; then ride it 20miles, fill it to the top again, note how much you have to put in to get to the same fill level... note suggested consumption. Repeat to get more accurate sample. And prob will probably have gone away.
Add on Edd:-
chrisjose1913 wrote:
Hello i have a cagiva w8, with exhaust issues. i will be doing a temp fix as i want to make/get a race exhaust for it.
The exhaust on a two stroke is critical to good running. 'Exhaust Issues' that demand or suggest finding a replacement pipe dont really sound like merely a missing or leaky gasket.......
Tackling these 'exhaust issues' could then be key to all.
In the mean time, if you value your piston and combustion chamber.... dont run it with 'exhaust issues'...they have a habit of melting if the expansion chamber isn't doing its job.
However; fact that the thing is running at all, may imply that to combat knackered exhaust causing lean mix detonation, some-one has upped the fueling with massive carb jets or jammed the choke enritchement plunger in the 'on' position to get it to run moderately clean enough to flog on. Could be worth looking at.
chrisjose1913
PostPosted: 15:57 - 20 Mar 2014    Post subject: Reply with quote
ok i think Teflon-Mike may be right, i put a fiver in today, so i can test and find the leak. Luckily it's also raining, this made it easier to locate a leak, with the rainbow affect on the ground. it appears to leaking out from the exhaust where the gasket should be ;/ it's leaking quit a bit too. i am thinking all this must be down to the exhaust and running way to rich ? i really hope the piston does not need replacing it only had around 500 miles on it i am glad i recovered it from the teen who owned it last. any suggestions ?
1997 CB500
cagiva gezzer
PostPosted: 22:29 - 20 Mar 2014    Post subject: Reply with quote
My similar bike would do 60 mpg when running it in / taking easy. 40 when thrashing.
It may have had some "tuning" in the past and this may have made it too rich and its wasting fuel.
The exhaust gaskets on these bikes are o-rings and they can break up. A pair of o-rings and some sealant / gasket will tidy it up.
Teflon-Mike
tl;dr
PostPosted: 22:49 - 20 Mar 2014    Post subject: Reply with quote
You put petrol in the tank.. and it starts dripping out of the exhaust?
Without kicking the engine over or anything?
It just runs right through?
Well... doesn't sound possible, TBH!
Obeying gravity; Fuel goes in tank filler, comes out tap, through pipe, into carb float bowl, via needle valve controlled by float; from float bowl, up through jets... into carb venturi under throttle slide.
Can then go two ways, depending which way is lower.. towards air filter or towards crank case. Crabk case is probably lower... so path would follow the inlet tract, down the inlet manifold, past the reed block into the crank case. At that point, I would expect it to stop.
Crank case is sealed, its a two stroke; it would probably take about 50cc or so to fill bottom of the crank case to the level of the crank seals of bottom of the reed block... would litterally be swimming in neat petrol.
To get up into the cylinder, from which it might start dribbling down the exhaust port and into the pipe to escape at the manifold gasket; it would have to completely fill the crank case, flood up above the level of the cylinder and transfer ports, which would usually be higher than the inlet tract, which means that long before the crank case was that full, it would have been going both ways out the carb and dripping out the air-filter, and well, probably every fucking where!
Dont make sense; to get to the exhaust flange, excess fuel would have to be pumped back up against gravity by the motor being turned over.
Are you sure its leaking from the exhaust flange, or is fuel dripping from there, having dribbled out of a split or pin hole in the tank, or a spl;it hose, onto the outside of the exhaust pipe, and run down to lowest point of pipe, where you see drip as if coming through the joint?
OR, have you kicked the motor over and then its dripped from manifold?
Follow the logic.
Investigate leak more carefully; lift the tank and check it for leaks off the bike, if you have to.
After that; then back to list; remove and clean carburettor; if float valve sticking, then could be flooding the engine, and if turned over to pump excess into the cylinder, leaking from pipe flange; but only if you have turned the engine over.
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 112.97 Kb
