| mintex |
 mintex Nova Slayer
 Posted: 12:21 - 08 Mar 2014 Post subject: Camera tank mount |
I ordered a mount of ebay with a with a suction cup on it to mount on the tank, the cup is larger than i thought but i guess that's not a bad thing.
The camera is not the best but its ok, its also got some thing vibrating inside it but i plan on changing it soon but i want one i can charge and record at the same time.
What do you think of the view though,i'm not doing it to be a vloger or anything, just to record while im out on the bike to capture any events that might happen lol.
https://www.youtube.com/watch?v=mW-OX3Ay-D4&list=UUwQCIxNPJvH3NJhbTf8beSQ |
| doggone |
 doggone World Chat Champion
| mintex |
 mintex Nova Slayer
 Posted: 16:18 - 08 Mar 2014 Post subject: |
The sound thing is quite annoying, would sound ok if it was not for that. It does it if you rev it while standing still too so some things vibrating.
I could move the mount further forward as its quite near to me at the minute, that should show less instrument panel in the shot  |
| ScaredyCat |
 ScaredyCat World Chat Champion
| mintex |
 mintex Nova Slayer
| Ali in Austria |
 Ali in Austria Nitrous Nuisance
 Posted: 12:19 - 16 Mar 2014 Post subject: |
Vibration is an issue with many of these cameras and is responsible for the "Jello" you see in many of the videos. Even GoPro's, as good as they are, require the rubber insert to be secured in the mount to stop shaking (not that noticeable in the video) which causes the clicking noise in the audio (really annoying)
The head and neck are still the best natural shock absorbers making a good fitting helmet still the best place to mount a camera from a results perspective. Back Packs also do a reasonable job such as the VuVantage or Wizmount.
Audio is always an issue with most action cameras. Those in a waterproof case such as GoPro are very muffled. Those that are already waterproofed such as the Drift HD have waterproof material covering the Mic. All lead to poor audio. The only way around it is to fit an external Mic. Drift do a silicon boot to cover the open back door and allow a Mic to be plugged in. Not waterproof but water resistant.
GoPro do a skeleton case which allows a Mic to be plugged in (not "The Frame" as it covers the port). Obviously it is not waterproof.To get around it ideally you need to drill a waterproof case to allow access for the Mic Lead and have a good fitting cable grommet designed for that purpose or use some sort of silicon. I find Black Tac, a heavy duty version of Blue Tac does a good job and is easily removed and reapplied. Not waterproof but very water resistant. ____________________ A Petrol Head in The Alps
https://www.youtube.com/user/PensionHausMaria
https://facebook.com/pension.haus.maria |
| doggone |
| Speedfreak13 |
 Speedfreak13 Two Stroke Sniffer
 Posted: 06:49 - 20 Mar 2014 Post subject: |
I've got a suction cup mount but I use it on the side faring great view and done a few tests all is good! Just use a lanyard or strap incase it fails! I also had a noise issue which turned out to be one of the button loose and rattling inside waterproof case! I'll post a test video above it's not me ov course because wheelies are nauthgy but a friends friend with same camera/mount and rattle(sorted now) lol
https://youtu.be/Kq63M-_sThc |
| ScaredyCat |
 Posted: 23:01 - 20 Mar 2014 Post subject: |
Where are you that you get roads that empty?
I just picked up a contour roam to gopro converter so I can use gopro mounts. They seem much better with less shake. Took it out for a quick test, handlebar mount works well.
https://dl.dropboxusercontent.com/u/188253/_nc700x/rearfacing1.png
Want to find some angles that are much more interesting eg looking down at the rear tyre or front forks. Hopefully because there are more gopro mounting options the converter will help. ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
| Speedfreak13 |
 Posted: 05:33 - 21 Mar 2014 Post subject: |
| ScaredyCat wrote: |
Check my onboard zx9r video that's a gopro suction cup mount it gos on any flat-ish surface and is very very strong! I would alway use a safely line just incase tho!! Video is above/below lol
Want to find some angles that are much more interesting eg looking down at the rear tyre or front forks. Hopefully because there are more gopro mounting options the converter will help. |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| image riot |
 image riot Renault 5 Driver
 Posted: 08:47 - 21 Mar 2014 Post subject: |
https://www.youtube.com/watch?v=yHX9ipC0gWQ
This is a video I made to demonstrate the main mounts I use on my bike. As already said, noise is a factor on gopros and I've never eliminated it so usually add music. The suction mount is rock solid, I've never used a backup lanyard and it's held there just fine. ____________________ GSXR750 > GSXR1100 > ZX9R > CBR900RRP >CBR929RR>K1200S |
| Llama-Farmer |
| mintex |
 mintex Nova Slayer
| sheriffHD |
 sheriffHD Derestricted Danger
 Posted: 17:48 - 01 Apr 2014 Post subject: |
I use a GoPro Hero 3 Silver. Ive tried several differnt mounting positions. Suction cup on tank, top of helmet. looking back in my face (A bit distracting) on an extension arm from my helmet. Etc.
Ive finally settled on a set up.
https://imgur.com/0HA0KG7.jpeg
Its high enough up to not be viewable from while wearing the helmet. While still being low enough for the video to not seem too high up which I think doesnt look nice. Also can throw the mount backwards to get an over the shoulder view as well as reversing it for a look down on my face. So pretty happy with it as it is right now. |
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
