yamaha tzr125 upside down gearbox help
drae2013
PostPosted: 14:48 - 20 Mar 2014    Post subject: yamaha tzr125 upside down gearbox help Reply with quote
My tzr 125 just bought is 1up 4 down for gears but am usto 1down 4 up normal gears but how do a change or go about changing it from 1up 4dwn to normal 1dwn 4 up any help would be appreciated dont know much about gearboxes just hate driving my tzr because cant get usto it bike is in ayr(scotland) and good mechanic to do the nob n price would be good
D rae
Islander
PostPosted: 16:10 - 20 Mar 2014    Post subject: Reply with quote
Erm has someone bolted a direct gear change lever on (opposite way round of course) instead of the normal linkage type?
drae2013
PostPosted: 16:15 - 20 Mar 2014    Post subject: Reply with quote
I dont know what u mean by that lol
D rae
Islander
PostPosted: 16:19 - 20 Mar 2014    Post subject: Reply with quote
Does your gear lever look like the one in this eBay ad?
www.ebay.co.uk/itm/Yamaha-TZR125RR-TZR125-RR-Gear-Lever-Selector-Pedal-Linkage-/310898484315?pt=UK_Motorcycle_Parts_13&hash=item4862fe645b
Or is it one like this bolted on so that the rubber end faces back towards the rider:
https://www.ebay.co.uk/itm/YAMAHA-TY250-TWIN-SHOCK-SHORT-GEAR-LEVER-/301079814459?pt=UK_Motorcycle_Parts_13&hash=item4619c1613b
drae2013
PostPosted: 16:31 - 20 Mar 2014    Post subject: Reply with quote
Its facing normal way towords front wheen but aint thensame gear changer as u sent me in link look at photo full size an zoom in ul see the one I have on it only photo I have sorry
D rae
Islander
PostPosted: 16:34 - 20 Mar 2014    Post subject: Reply with quote
Well it isn't 1st April yet...
Kari-On This post is not being displayed because the poster is banned. Unhide this post / all posts.
drae2013
PostPosted: 17:04 - 20 Mar 2014    Post subject: Reply with quote
Sorry folks wrong photo lol my fault heres the correct one lol Laughing
D rae
Islander
PostPosted: 17:08 - 20 Mar 2014    Post subject: Reply with quote
That doesn't look as if it's fitted correctly. Have a look at this image:
[url]2.bp.blogspot.com/-LiZHzgOxTnw/Tow1tNzgHuI/AAAAAAAAAjw/0x3kw_FtGwc/s1600/1997-YAMAHA-TZR1125-TZR-125.jpg[/url]
Islander
PostPosted: 17:21 - 20 Mar 2014    Post subject: Reply with quote
Nuts. Just paste the bit between the tags into a browser.
drae2013
PostPosted: 17:26 - 20 Mar 2014    Post subject: Reply with quote
Okay had a look at it looks differant from mine will have mechanic look at it anyway aswell
D rae
drae2013
PostPosted: 17:27 - 20 Mar 2014    Post subject: Reply with quote
D rae
Islander
PostPosted: 17:29 - 20 Mar 2014    Post subject: Reply with quote
If you've got the tools it's a simple job to put it right. Thumbs Up
Islander
PostPosted: 19:54 - 20 Mar 2014    Post subject: Re: yamaha tzr125 upside down gearbox help Reply with quote
mpd72 wrote:
Spinning the arm on the gear selector spline so it's the other way up will reverse the selection pattern, but I doubt you'd have the clearance from the sprocket case to do this.
This is the most likely case if the OPs original report is correct. I'd initially thought that the linkage mechanism may have been replaced with a reversed short direct lever but as there appears to be a linked lever in place, for the sequence to be reversed then the gear selector link must be reversed. I'll be interested to see how this one works out. Mr. Green
PostPosted: 01:05 - 21 Mar 2014    Post subject: Reply with quote
Is it the original engine? Think the DT125 engine is basically the same but some models have the gear change the other way round.
If you are unsure check the engine number. On a Yamaha of that age I think it should match the frame number. The first 3 digits (probably should be 2RK) are the model code of the bike.
bladerunner
PostPosted: 08:29 - 21 Mar 2014    Post subject: Reply with quote
OP had a 5 speed TZR?
bladerunner
The last post was made 12 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 105.15 Kb
