Electric problems!
charrington96
PostPosted: 21:33 - 20 Mar 2014    Post subject: Electric problems! Reply with quote
I have a derbi senda 50cc sm 2002
I have no headlight, tail light or speedometer light, but everything else is fine
Any suggestions?
Thanks
PostPosted: 21:46 - 20 Mar 2014    Post subject: Reply with quote
Check your fuses first off.
charrington96
PostPosted: 21:50 - 20 Mar 2014    Post subject: Reply with quote
Main fuse is fine...
Is there any more?
PostPosted: 21:56 - 20 Mar 2014    Post subject: Reply with quote
Is there any more?
Some Sendas do, some don't. If it did, it would be in with the main fuse.
charrington96
PostPosted: 21:58 - 20 Mar 2014    Post subject: Reply with quote
Its only the one fuse, I've checked all connections and been looking at diagrams
PostPosted: 22:23 - 20 Mar 2014    Post subject: Reply with quote
Have you checked the bulbs? What about the battery terminals?
charrington96
PostPosted: 22:28 - 20 Mar 2014    Post subject: Reply with quote
Checked them both as well
WD Forte
PostPosted: 22:51 - 20 Mar 2014    Post subject: Reply with quote
looking at the diagram below,
the Green/black then brown ( after the connector block)
wire from the igntion switch ( 5)
feeds the head, tail and speedo back lights
I'd be looking for a voltage here
If the headlight will flash but not run in normal hi/lo mode
and the brake lights work too
that would tend to confirm my suspicions.
Might just be a bad connection at the switch.
https://i675.photobucket.com/albums/vv118/hmmmnz2/randoms/derbisenda.jpg
bikers smell of wee
charrington96
PostPosted: 07:38 - 21 Mar 2014    Post subject: Reply with quote
Thanks I'll check today
The last post was made 12 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 59 Kb
