Clutch plate replacement... Now bite point changes when hot.
mysterious_rider
PostPosted: 18:16 - 22 Mar 2014    Post subject: Clutch plate replacement... Now bite point changes when hot. Reply with quote
Hello guys, I recently changed the plates on my clutch. I fitted the metal plates etc correctly (soft edges facing same way etc).
I soaked the plates in oil for 14 hours beforehand.
But when I ride, if I'm in traffic and slipping the clutch, the bite point changes. It's very annoying because I'll find rather than at the end of the clutch lever, it'll start biting at the handlebars.
I've even noticed the bike juddering drag trying to pull me forwards when its really being used.
And if i adjust the bite point to where i want it, if i let the bike cool down it's well over adjusted...
Why is this? It happened with a previous bike too, I used cheap plates then, but I bought EBC this time....
KAWASAKIIIII
PostPosted: 18:19 - 22 Mar 2014    Post subject: Reply with quote
What bike?
mysterious_rider
PostPosted: 19:31 - 23 Mar 2014    Post subject: Reply with quote
zzr600. 95 e3 model.
Thing is, clutch never did this before (just slipped at high rpm). Which is why i replaced it.
KAWASAKIIIII
_mjs_
PostPosted: 19:54 - 23 Mar 2014    Post subject: Reply with quote
Did you use change / use different springs?
mysterious_rider
PostPosted: 20:39 - 23 Mar 2014    Post subject: Reply with quote
Yeah EBC heavy duties. I re used the metal plates because they seemed fine.
KAWASAKIIIII
DMCpro
PostPosted: 21:19 - 23 Mar 2014    Post subject: Reply with quote
What oil are you using? Did you torque or atleast tighten securely all important bolts?
Honda CB-1, TS125X
VW Golf Estate
mysterious_rider
PostPosted: 21:25 - 23 Mar 2014    Post subject: Reply with quote
10-40 semi synth.
All bolts are tight.
Just to make certain, it's only the metal plates that need to go in a certain way isnt it? The friction plates just fit in. I haven't read anything about friction plates needing to go in a certain way, from what i could see they were identical.
Cheers.
KAWASAKIIIII
_mjs_
PostPosted: 08:13 - 25 Mar 2014    Post subject: Reply with quote
Any progress on this... could have sworn my clutch slipped a little bit on the way home from work Shocked
temeluchus
PostPosted: 13:35 - 25 Mar 2014    Post subject: Reply with quote
very odd. Did you reassemble the plates in the order they were removed?
Did the fingers on the clutch basket have any notches on them?
https://www.cmsnl.com/kawasaki-1997-e5-zx600-north-america_model12858/partslist/E1350.html#results
(before you say, the ZZR600 IS a ZX600, the names are not the same across all markets and as far as I know the engine didn't change at any point.)
mysterious_rider
PostPosted: 11:30 - 26 Mar 2014    Post subject: Reply with quote
clutch basket was fine. Metal plates were fine (refitted the correct way). Only thing I just threw in were the friction plates. But I think they can go in any way.
Still does it, so mayday may get interesting if im constantly slipping the clutch.
It has stopped juddering for now, and it seems to be doing it a bit less. So maybe it's bedding in (done nearly 200 miles).
KAWASAKIIIII
yen_powell
PostPosted: 12:27 - 26 Mar 2014    Post subject: Reply with quote
In Temulthingy's link to a parts diagram, can you see part number 13102.
If that works the same as it does on my Varadero, that will sit in one of the crank case covers and has a couple of small bearings it turns in when you use the clutch lever.
The bearings in mine had seized due to the old salty rain getting in causing my clutch to slip badly as it wasn't returning properly. Replacing those small bearings returned my clutch to normal with no slipping.
XT1200Z and a DR350 in bits
The last post was made 12 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 67.99 Kb
