Honda Nsr 125 - Engine won't turn off when I turn the key?!
wilzon3r3
PostPosted: 21:30 - 22 Mar 2014    Post subject: Honda Nsr 125 - Engine won't turn off when I turn the key?! Reply with quote
Ok, so I have a Honda Nsr 125 2000 plate.
My problem has been happening for the last couple of weeks.. The problem is, when I go to turn the bike off everything goes off as it should apart from the ENGINE?! The engine still runs & I have to use the kill switch to turn it off.
I am quite mechanically minded, so I'm more than happy to solve the problem myself.. But I need some advice/guidance as to what the problem is & how to fix it.
Any advice is greatly appreciated.
Cheers people!
wilzon3r3
PostPosted: 09:23 - 23 Mar 2014    Post subject: Reply with quote
Anybody?? Ideally want to strip it down today and fix the problem if possible.
wilzon3r3
PostPosted: 11:24 - 23 Mar 2014    Post subject: Reply with quote
Vincent wrote:
Sounds like it may be the ignition switch at fault. The bottom part can wear over time and short out.
Thanks for your reply, I'm going to take it apart today and have a look.
Could it be the actual ignition? Or are the wires from the ignition just as common to wear etc. ??
Cheers again.
Teflon-Mike
tl;dr
PostPosted: 22:10 - 23 Mar 2014    Post subject: Reply with quote
You have PM.
Reverse of 'fix' would let any-one by-pass your ignition switch!
The last post was made 12 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 49.88 Kb
