iffy ignition barrel
mudcow007
PostPosted: 14:43 - 25 Mar 2014    Post subject: iffy ignition barrel Reply with quote
the barrel on my Bandit is iffy to say the least - is there much you can do with them or is it just a replacement?
fuel cap an seat lock all use the same key so ideally i dont want to have different keys
ive tried the two keys that come with the bike - both have issues
Minty
PostPosted: 14:46 - 25 Mar 2014    Post subject: Reply with quote
Iffy in what way? Has you oiled it and given it a good rogering with the key?
My fingers smell of your mum.
mudcow007
PostPosted: 14:49 - 25 Mar 2014    Post subject: Reply with quote
its difficult to turn, an when it does its crunchy Shocked
i have tried sticking the key an dribbling oil down it, buts no better
also tried grease on the end of the key
CaNsA
PostPosted: 14:54 - 25 Mar 2014    Post subject: Reply with quote
Go get a new key cut.
orac
PostPosted: 15:00 - 25 Mar 2014    Post subject: Reply with quote
get another cut, best off from one that isnt quite so worn, it normally faily high up on the list when i get a new bike.
also suzukis tend to have this weird thing when they start to get worn, if you put the key in and push the key towards the clocks while turning they will often turn better in my experiences
Busa1340R
You could try graphite powder to lube the barrel...I believe it's what Johnny Locksmith uses for sticky locks.
Just do a search on Ebay...tubes of it for a cupplaquid upwards.....
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
Copycat73
PostPosted: 18:05 - 25 Mar 2014    Post subject: Reply with quote
my yamaha was exactly the same and this method worked for some time but eventually it mostly refused to move..
so
https://i867.photobucket.com/albums/ab232/copycat73/24k%20Service%2014th%20jan%202013/Photo1042_zpsf7e254d4.jpg
I stripped it down as there was very little wear on the keys.. even the red key refused to work and that had only been used once or twice..
it was full of old grease & crud.
the key in the jpg. is inside the lock barrel, the tumblers had worn on the inside and were stickin proud when they should have been flush allowing the lock to turn.
I ground them flush re-assembled, clean & re-greased and so far problem solved.
caveat emptor
Bezzer
PostPosted: 18:42 - 25 Mar 2014    Post subject: Reply with quote
You're on the Bandit Forum, take it you never bothered to look in the FAQs/How Tos section then Rolling Eyes .
https://www.banditforum.co.uk/forum/index.php?topic=21097.msg223827;topicseen#new
mudcow007
PostPosted: 22:11 - 25 Mar 2014    Post subject: Reply with quote
Dammit - cheers Bezzer will check there....
thanks all
The last post was made 12 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 15 - Page Size: 64.35 Kb
