Screen trimming
nelmo
PostPosted: 17:13 - 25 Mar 2014    Post subject: Screen trimming Reply with quote
I've just bought a large Givi screen for my bike but it catches on the (non-OEM) handguards on full lock and it's tricky to put the steering lock on.
I'm planning on just cutting some small cut-outs from the screen - is there a recommended tool for doing this?
I was planning to use a basic electric jigsaw but I'm worried about cracking the plastic, or will that be ok?
PostPosted: 17:17 - 25 Mar 2014    Post subject: Reply with quote
Heat it, push bars into it, let it cool.
Tamsin
PostPosted: 17:42 - 25 Mar 2014    Post subject: Reply with quote
jigsaws can be lairy little fuckers so prob best not to.
Heating the screen is a tricky one too as you dont want to risk burning or distortion outside of the immediate area.
if it was something I really had to do, I'd be looking at a junior hacksaw and a steady approach...
map
Mr Calendar
PostPosted: 17:56 - 25 Mar 2014    Post subject: Reply with quote
Depends how much needs to come off.
I'd just resort to a file and elbow grease to try and prevent cracking the perspex.
Post up a picture, there may be an alternative solution.
Tamsin
PostPosted: 18:02 - 25 Mar 2014    Post subject: Reply with quote
i agree Map if its only a smidge that needs to come off....
PostPosted: 19:20 - 25 Mar 2014    Post subject: Reply with quote
I would use a tile saw.
Looks like a coping saw but with a sharp wire instead of a conventional blade.
PostPosted: 19:38 - 25 Mar 2014    Post subject: Reply with quote
Mini-grinder and a worn grinding dosc or flapwheel. I am doing one this evening, cutting up a 'busa screen to make a small screen for my Bandit.
nelmo
PostPosted: 19:54 - 25 Mar 2014    Post subject: Reply with quote
The screen is like the one in this ebay ad:
[url] https://www.ebay.co.uk/itm/like/271278588298?hlpht=true&ops=true&viphx=1&lpid=95&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=95&ff19=0[/url]
I need to take about 5-10mm of the top edge of those wings...I haven't got the other tools, so I'll try the hacksaw....
Thanks all.... Thumbs Up
PostPosted: 20:07 - 25 Mar 2014    Post subject: Reply with quote
Can't you just slacken the bar clamps and swing the bars back a little for more lock? You might find it more comfortable to ride too now you have a screen.
Llama-Farmer
PostPosted: 22:04 - 25 Mar 2014    Post subject: Reply with quote
That'd only work if he had clip ons fitted?
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 22:09 - 25 Mar 2014    Post subject: Reply with quote
No, you can adjust regular bars by slacking off the risers.
PostPosted: 22:34 - 25 Mar 2014    Post subject: Reply with quote
Hacksaw and file to finish is fine. Tile saw sounds great, but you're unlikely to have one lying around.
No to a jigsaw. It melts the perspex which then reseals behind the blade, so you have to chase it with another saw anyway to actually separate the piece, and then clean up all the blobs with a file. There is some danger of snapping it if it catches.
mudcow007
PostPosted: 22:45 - 25 Mar 2014    Post subject: Reply with quote
dremel with a cutting disk
i always tend to snap the disks when ever i use mine though, so might be worth wearing safety bins
map
Mr Calendar
PostPosted: 10:08 - 26 Mar 2014    Post subject: Reply with quote
From experience (and also confirmed by comments above) I'd be careful of any cutting that heats and melts the perspex. Especially if you're just nibbling a little bit off (it's sort of ok if you're careful for cutting large sheet).
So power tools would be too aggressive imo. Hacksaw would do, depends on size being cut.
nelmo
PostPosted: 11:24 - 26 Mar 2014    Post subject: Reply with quote
Hmm, that's an interesting idea - I'll look into it. Not got clip-ons but I can see I should be able to move the bars back. Then again, I like the riding position as is...
DrSnoosnoo
PostPosted: 13:29 - 26 Mar 2014    Post subject: Reply with quote
Soldering iron, slowly melt it off. That's what I'd do, or even, attempt
lihp
PostPosted: 15:02 - 26 Mar 2014    Post subject: Reply with quote
That's why I don't leave my soldering iron lay around at work Laughing
map
Mr Calendar
PostPosted: 15:15 - 26 Mar 2014    Post subject: Reply with quote
I'd leave it laying around switched on. It's an intelligence test depending on which end is picked up.
Rogue_Shadow
PostPosted: 18:10 - 26 Mar 2014    Post subject: Reply with quote
I would attempt to file it down rather than take chunks out of it.
Yes it would take a lot of work, but at least you can make it identical on each side and now worry about putting to much force into the Perspex and snapping it Thumbs Down
Corse sand paper for the bulk of it, then some wet & dry to polish the edges and make it smooth again.
But that's me Rolling Eyes
The last post was made 12 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 103.77 Kb
