Bike cuts out when put into gear
Serendipity
PostPosted: 14:50 - 26 Mar 2014    Post subject: Bike cuts out when put into gear Reply with quote
It's an old 1994 CBR600.
Checked the side stand switch and it seems to be working fine. Side stand warning light goes on and off with the switch, but the engine still cuts out just like the stand is down, regardless of position.
Any suggestions?
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
doggone
PostPosted: 14:56 - 26 Mar 2014    Post subject: Reply with quote
How have you checked the switch?
You need disconnect it and join the two wires to test it.
Almost has to be that really.
Not a good idea to ride it bypassed though.
Serendipity
PostPosted: 15:05 - 26 Mar 2014    Post subject: Reply with quote
It's a rotary switch on the rear of the stand. I unbolted it and rotating it switches the stand warning light on and off. To me that suggests that the switch functions as it should and there's something else at fault.
yen_powell
PostPosted: 15:18 - 26 Mar 2014    Post subject: Reply with quote
Clutch lever switch?
XT1200Z and a DR350 in bits
Pigeon
PostPosted: 16:57 - 26 Mar 2014    Post subject: Reply with quote
Sticking clutch plates?
Islander
PostPosted: 16:59 - 26 Mar 2014    Post subject: Reply with quote
If the sidestand switch is working then the problem is most likely with the clutch switch.
Islander
PostPosted: 17:00 - 26 Mar 2014    Post subject: Reply with quote
The OP didn't mention the bike trying to leap forward... It doesn't does it OP?
weasley
PostPosted: 17:05 - 26 Mar 2014    Post subject: Reply with quote
Doesn't the clutch switch just lock out the starter motor, if the engine is in gear? After all, when riding you are constantly using the clutch and therefore opening and closing the clutch switch, yet the engine continues to run whether in gear or in neutral.
I guess we need to know if the engine is 'cutting out' or 'stalling' when put into gear (does it jump forwards or not?).
map
Mr Calendar
PostPosted: 17:07 - 26 Mar 2014    Post subject: Reply with quote
Usually a micro-switch. Take off lever and clean. If still fubar then replacement can be made, usually screwed onto lever.
You might be able to test by taking out the wires and shorting Thinking Believe closes/clicks when lever pulled so it's a normally open switch. If on a connector use a paper-clip (or similar).
The last post was made 12 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 59.86 Kb
