dfgdfhbfgnf
PostPosted: 18:15 - 29 Mar 2014    Post subject: .. Reply with quote
Boris the spider
PostPosted: 18:21 - 29 Mar 2014    Post subject: Reply with quote
Be interesting to see if it works.
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
stevo as b4
PostPosted: 18:33 - 29 Mar 2014    Post subject: Reply with quote
I know as well as anybody that noise does not necessarily equal power, but if your wanting to increase performance it has to be at the expense of something else normally, and in most cases the first thing to be sacrificed is noise level.
I'll be doing an airbox lid mod on my KMX125 when it's run in, and I will have a back to back dyno run carried out and see if it's as restrictive as I think it might be. I might be slightly over jetted at the moment, so it will be interesting to see the effect on fuelling with no airbox lid etc.
Is your YBR injected or carb fed? And what are you doing about fuelling when you change the intake/exhaust set up etc?
CaNsA
PostPosted: 13:33 - 30 Mar 2014    Post subject: Reply with quote
Today I decided to experiment with my air box of my ybr125 to make it draw more air into it. At the top of it under the seat there is the airbox inlet and it has a rubber intake. I could removed it but at idle there is an odd ticking noise that can be heard so I wanted to improve it but not removing it completely. I cut the middle bit so that the hole have a bigger area. That's the only thing you can do to improve some throttle response without make the bike unbearable to drive because I had tried fitting a cone filter directly to the throttle body with a silicone hose but the drone at wot was unbearable.
https://i.imgur.com/utT4apk.jpg
https://i.imgur.com/rhWxWah.jpg
https://i.imgur.com/s47TwIG.jpg
https://i.imgur.com/PwBdTxj.jpg
https://i.imgur.com/68sVtFd.jpg
PostPosted: 13:54 - 30 Mar 2014    Post subject: Re: .. Reply with quote
You really think that center divider is restrictive? Look at the size of the carb throat and the size of the passages in that rubber boot. It's probably got ten times the cross-sectional area of the carb.
The last post was made 12 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 45.72 Kb
