High revs
Dave M
PostPosted: 16:33 - 30 Mar 2014    Post subject: High revs Reply with quote
Hi all,
I just bought a cheap Hyosung gt125 comet 2010 as a bit of a project. Having a slight problem with idling as in it's idling at about 8000 rpm. I had carbs out to give them a clean. They were bad but not the worst I've seen. I sprayed wd40 on all rubber manifolds and revs get even higher. I've noticed a ring clamp missing from the air box to carb manifold. Could this be the problem or could it also be something else? I am going to fit a new clamp tomorrow. Also when I blip the throttle it is very unresponsive and cuts out. It's a v2 engine. Thanks.
Dave M
PostPosted: 17:36 - 30 Mar 2014    Post subject: Reply with quote
Update.
Managed to get it to idle now but it won't rev past 3000 rpm without it wanting to die. Had a ride and got going only for it to bog down and die after about 5 seconds on road. At my wits end now. Please help!!!
Sounds like you have a leak in the carb -> inlet rubbers.
I'd assume that the last owner got as far as undoing the air box to carb rubbers, then thought better of it and decided to punt it on to some other mug instead of putting more time into it. Whistle
[UPDATE]
Whoa, what did you do to get it to idle?
All you've really said is "engine busted how fix?". Details, chap.
Also, if you put a location in your profile, Paddy someone might be minded to swing by and hold your hair back while you throw up.
Dave M
PostPosted: 17:37 - 30 Mar 2014    Post subject: Reply with quote
Thanks for that Very Happy
Dave M
PostPosted: 18:05 - 30 Mar 2014    Post subject: Reply with quote
I reset both mixture screws and it idles ok now. Throttle response is a bit better. I put my helmet on to go for a ride and it wouldn't rev past 3k rpm and cut out. That's all I can tell you? It will not rev past 3k. It just bogs down.
PostPosted: 20:51 - 30 Mar 2014    Post subject: Reply with quote
How's the air filter?
Done a plug chop? Rev as long as you can, killswitch and clutch in, stop, plugs out and have a look. It's either running rich or lean, you'll have to find out which.
bladerunner
PostPosted: 21:01 - 30 Mar 2014    Post subject: Reply with quote
Another option is the last owner dicked about with the carb trying to get it to idle by adjusting float height. Jets ...needle position etc....get it set to spec first and take it from there
PostPosted: 21:17 - 30 Mar 2014    Post subject: Reply with quote
That's why I'd suggest diagnosing what the issue is before "dicking with the carb". Wink
Dave M This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
PostPosted: 23:16 - 30 Mar 2014    Post subject: Reply with quote
It's not my fault that your bike is shagged, and I'm not minded to be a whipping boy for the queue of chimps who designed, built, shipped, sold and fiddled with it.
Best of luck.
Teflon-Mike
tl;dr
PostPosted: 07:44 - 31 Mar 2014    Post subject: Reply with quote
An awful lot of presumed carburettor faults eminate in the exhaust.
I seem to recall, that the Hyasungs have rivited on headers, something to do with anti-tamper measures in some durastictions.
If any-one has tried removing the exhaust for any reason... this might have been a problem! could be blowing from the flange.
Worth a check.
Also worth checking for pin-holing in the pipe and rust in the low-point of the system / collector where two pipes join, as well as any dicking to de-baffle the silencer.
Any and all can screw carburation; so always should be first thing to investigate/eliminate when carb probs are encountered.
Next? Plugs. Tell you more about what carbs doing than anything. Run it up with clean plugs and then check colours against comparison photo's in pretty much any Haynes.
Remember to kill the ignition under circumstances giving grief, though, or you only ever get indication of how engine is running at idle when you turn ignition off.
Dave M
PostPosted: 16:57 - 31 Mar 2014    Post subject: Reply with quote
Best of luck.
I bet you have the best bike going!
Az
PostPosted: 17:00 - 31 Mar 2014    Post subject: Reply with quote
weedave wrote:
I came here for help and you're not helping. Middle Finger
I'd say he was helping… you even thanked Roger for helping lol
Dave M
PostPosted: 17:04 - 31 Mar 2014    Post subject: Reply with quote
Worth a check.
Exhaust looks to be ok at headers and at joints were you said. I've ordered replacement inlet manifolds. Old ones look a bit perished. Checked both plugs after a chop. Rear plug was spot on with a sandy brown colour. Front plug was a bit sooty but not too bad? Spark on both are orange colour. When I checked gaps there were only about .2 when should be .7 to .8 so readjusted both. Started up better but still have this issue. Haven't looked at it today yet. Thanks for the reply. Thumbs Up
Dave M
PostPosted: 18:21 - 31 Mar 2014    Post subject: Reply with quote
Just found out from seller that carbs are replacement ones he put in himself but didn't have time to set up Rolling Eyes Not sure if exhaust is stock or not? Went to have another look. Fired her up and first time on the button without choke although idling very low at around 1k. Started to piss down so tomorrow I will take pics of carbs, exhaust and fuel lines (that's another story)
The last post was made 12 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 88.42 Kb
