| Dave M |
 Dave M Scooby Slapper
| Dave M |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:36 - 30 Mar 2014 Post subject: |
Sounds like you have a leak in the carb -> inlet rubbers.
I'd assume that the last owner got as far as undoing the air box to carb rubbers, then thought better of it and decided to punt it on to some other mug instead of putting more time into it.
[UPDATE]
Whoa, what did you do to get it to idle?
All you've really said is "engine busted how fix?". Details, chap.
Also, if you put a location in your profile, Paddy someone might be minded to swing by and hold your hair back while you throw up. ____________________ Biking is 1/20th as dangerous as horse riding.
| Dave M |
| Dave M |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:51 - 30 Mar 2014 Post subject: |
How's the air filter?
Done a plug chop? Rev as long as you can, killswitch and clutch in, stop, plugs out and have a look. It's either running rich or lean, you'll have to find out which. ____________________ Biking is 1/20th as dangerous as horse riding.
| bladerunner |
 bladerunner World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:17 - 30 Mar 2014 Post subject: |
That's why I'd suggest diagnosing what the issue is before "dicking with the carb".  ____________________ Biking is 1/20th as dangerous as horse riding.
| Dave M |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
| Rogerborg |
 Rogerborg nimbA
 Posted: 23:16 - 30 Mar 2014 Post subject: |
It's not my fault that your bike is shagged, and I'm not minded to be a whipping boy for the queue of chimps who designed, built, shipped, sold and fiddled with it.
Best of luck. ____________________ Biking is 1/20th as dangerous as horse riding.
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 07:44 - 31 Mar 2014 Post subject: |
An awful lot of presumed carburettor faults eminate in the exhaust.
I seem to recall, that the Hyasungs have rivited on headers, something to do with anti-tamper measures in some durastictions.
If any-one has tried removing the exhaust for any reason... this might have been a problem! could be blowing from the flange.
Worth a check.
Also worth checking for pin-holing in the pipe and rust in the low-point of the system / collector where two pipes join, as well as any dicking to de-baffle the silencer.
Any and all can screw carburation; so always should be first thing to investigate/eliminate when carb probs are encountered.
Next? Plugs. Tell you more about what carbs doing than anything. Run it up with clean plugs and then check colours against comparison photo's in pretty much any Haynes.
Remember to kill the ignition under circumstances giving grief, though, or you only ever get indication of how engine is running at idle when you turn ignition off. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Dave M |
| Az |
 Az World Chat Champion
| Dave M |
| Dave M |
 Posted: 18:21 - 31 Mar 2014 Post subject: |
Just found out from seller that carbs are replacement ones he put in himself but didn't have time to set up Not sure if exhaust is stock or not? Went to have another look. Fired her up and first time on the button without choke although idling very low at around 1k. Started to piss down so tomorrow I will take pics of carbs, exhaust and fuel lines (that's another story) |
The last post was made 12 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
