Routine oil change turned into disaster.
doggone
PostPosted: 16:09 - 01 Apr 2014    Post subject: Reply with quote
Fortunately the worry pills were at hand.
map
Mr Calendar
PostPosted: 16:10 - 01 Apr 2014    Post subject: Reply with quote
Congratulations on getting broken bit out.
I think I'll order original replacement for mine.
Rogue_Shadow
PostPosted: 16:56 - 01 Apr 2014    Post subject: Reply with quote
Buy cheap, buy often Laughing
Congrats on the recovery though, could of been worse.
Ribenapigeon
PostPosted: 18:39 - 01 Apr 2014    Post subject: Reply with quote
Are you going to speak to M&P about it?
Wonko The Sane
PostPosted: 18:55 - 01 Apr 2014    Post subject: Reply with quote
It's not a tapered thread is it where the bolt gradually gets bigger and thus a tighter fit as it goes in?
I sheared the temp sensor bolt on my first car as I didn't realise it was a tapered thread
PostPosted: 19:19 - 01 Apr 2014    Post subject: Re: Routine oil change turned into disaster. Reply with quote
PillMonster wrote:
I did not over tighten it
I wonder, what would have happened to your sump if you'd gone for another 1/4 turn and it hadn't snapped? Thinking
Flatbadger
PostPosted: 21:45 - 01 Apr 2014    Post subject: Reply with quote
I went for that 1/4 turn (and more) a while back with one of those, it did a great job of smoothing out the hole in the strainer cap.
I managed well for 6 months or so, with the old plug upside-down in the hole with sealant to keep it oilproof. It probably doesn't make my street cred any better though.
Now happily helicoiled and with a non magnetic bolt, put in by a professional Laughing
You're in ISIS
toadoftoadhal...
PostPosted: 19:34 - 03 Apr 2014    Post subject: Reply with quote
I was just going to buy one of these from mnp, so wont bother now, thanks for the heads up
-Matt-
PostPosted: 19:38 - 03 Apr 2014    Post subject: Reply with quote
I bought one of these [can't remember the exact seller] a while back - avoided using it in the end as the threaded bit was significantly shorter than the stock bolts when I got it out during the oil change. Maybe its not a problem, but it didn't seem like it would be quite as secure to me Confused
ZRX61
Victor Meldrew
PostPosted: 00:14 - 04 Apr 2014    Post subject: Reply with quote
PillMonster wrote:
The magnetic hollow pos was £6.50 from m_and_p on ebay.
Of course they're hollow, that's how they stick the magnet to the bolt. The good ones are longer so the hollow bit passes through the case before it gets tight
They're not one night stands, they're auditions.
janner_10
PostPosted: 05:21 - 04 Apr 2014    Post subject: Reply with quote
Whats wrong with just using the stock one?
bamt
PostPosted: 06:06 - 04 Apr 2014    Post subject: Reply with quote
The idea is that whilst being run your engine is subject to wear, so tiny bits of metal end up in the oil (hopefully caught by the oil filter). The magnetic sump plug attracts any bits that make it into the sump, keeping them out of circulation and allowing you to get rid of them by wiping the plug when you empty the oil out.
A decent oil filter and regular changes should be good enough.
PostPosted: 08:37 - 04 Apr 2014    Post subject: Reply with quote
Why not just buy a Neodymium magnet (or a stack of 'em) from eBay and stick one on top of your stock steel plug? It's not going to leap off into the sump.
weasley
PostPosted: 09:30 - 04 Apr 2014    Post subject: Reply with quote
Or, indeed, just whack one on the bottom of the sump. You get to be seen by inductive loop sensors in the road too, for free.
Hugh Farking Cant
PostPosted: 18:43 - 04 Apr 2014    Post subject: Reply with quote
You did right; it is a big problem when torqued or done up by hand to what used to be the right spec.
Being shorter ;it strips the sump threads.
ADSrox0r
PostPosted: 19:24 - 04 Apr 2014    Post subject: Reply with quote
That just looks like a cheapo shit magnet that's been Araldite'd to the end of a cheapo shit bolt.
anthony_r6
PostPosted: 19:32 - 04 Apr 2014    Post subject: Reply with quote
Got one myself from WeMoto and didn't have any real issues. It was a little shorter than the standard one, but so far, no leak.
The last post was made 12 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 101.24 Kb
