Removing standard exhuast
Conzar
PostPosted: 10:29 - 02 Apr 2014    Post subject: Removing standard exhuast Reply with quote
As its never been changed before and tips for getting it off without hassle, plenty of WD?
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
map
Mr Calendar
PostPosted: 10:35 - 02 Apr 2014    Post subject: Reply with quote
Take it you just mean end can or is it full exhaust, headers as well on the CBR600F ?
c_dug
PostPosted: 10:37 - 02 Apr 2014    Post subject: Reply with quote
Plus gas is what you want, it works miles better than WD40.
Plus lots of luck on not rounding bits. 6 sided sockets are preferable.
Conzar
Yeah sorry the end can, just guessing it will need a good pulling to get it off after 14 years!
ficedula
PostPosted: 10:38 - 02 Apr 2014    Post subject: Reply with quote
Plus gas preferable to WD, it's actually meant for the job.
Try applying heat if the bolts don't want to shift.
If they won't loosen, try tightening them slightly - if you get any movement at all, it'll break the corrosion sealing them.
If they're rounding off before you get anywhere with them, you could try hammering a smaller socket over the bolt to get a better grip.
Last resort, cut a slot in the bolt and use an impact driver.
I ended up using all the above on my last exhaust. Have to get 8 nuts off made me appreciate the elegance of a large single... Wink
EDIT: Although if it's just the end can - probably not such a big job. Mine practically fell off once I started on it...!
Bike history: YBR125 -> XJ600
PostPosted: 10:40 - 02 Apr 2014    Post subject: Reply with quote
Start soaking the nuts in penetrating fluid now. Give them a squirt a couple of times a day for a few days before tackling the job. Best case scenario is that they all undo, worst case they all shear off. You may find that some of the studs unwind from the head as you turn the nuts.
Conzar
PostPosted: 10:48 - 02 Apr 2014    Post subject: Reply with quote
I Had a small go yesterday but as i was on my ones, i was giving it a good yank and just left it as i didn't want to potentially risk the bike falling over
map
Mr Calendar
PostPosted: 10:54 - 02 Apr 2014    Post subject: Reply with quote
Conzar wrote:
I Had a small go yesterday but as i was on my ones, i was giving it a good yank...
Yes, but how did you get on with removing the bolts? Wink
Conzar
PostPosted: 10:56 - 02 Apr 2014    Post subject: Reply with quote
Bolts from the hanger and the clamp came off fine with a socket just need to get the can off
Conzar
PostPosted: 11:24 - 02 Apr 2014    Post subject: Reply with quote
Still half asleep at work went strait over my hed Rolling Eyes
Baffler186
PostPosted: 12:25 - 02 Apr 2014    Post subject: Reply with quote
Conzar wrote:
......went strait over my hed Rolling Eyes
Impressive, hope it didn't go in your hair.
Can you tie up the bike so it won't fall over? A good wiggle side to side should do it, plus the penetrating oil. COuld try a few taps with a hammer and screwdriver on the join, but depends how old/new it is and whether you want to risk scratching it?
Motorhate
PostPosted: 14:13 - 02 Apr 2014    Post subject: Reply with quote
I recently replaced the end can and connector pipe on my CB500 and it was reasonably easy. You need to be careful with the muffler though (small metal collar that acts as a type of gasket between connector pipe and can). Mine was stuck fast and I needed a few squirts of WD40 and a wood chisel to prise it off. The clip between the can and connector pipe really took some loosening up but eventually came free.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
The last post was made 12 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 87.57 Kb
