| stranger12 |
 stranger12 World Chat Champion
| stranger12 |
| Doovy |
 Doovy World Chat Champion
| P.addy |
 P.addy Red Rocket
| stranger12 |
| stranger12 |
| Doovy |
| stranger12 |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 01:34 - 03 Apr 2014 Post subject: |
Cyclones are good - particularly with a disc lock alarm already - and generally, i'd be much more worried about having no anchor point. Alarmed or not if its easy to cut whatever its chained to it could be in a van very quickly mammoth double bridged anchors are decent and only cost 30-40 quid. |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| The Disapproving Brit |
 The Disapproving Brit World Chat Champion
| stranger12 |
 Posted: 11:48 - 03 Apr 2014 Post subject: |
well below are the picture of what I used to tie the chain around. They are hollow and have two bolt/nuts on each leg to secure it to the floor.
https://i60.tinypic.com/34pi1pf.jpg
2
https://i57.tinypic.com/hrzrzl.jpg
are anchor points easy to install? do i need drilling etc ?
I am thinking of getting one from Almax which is around £50 but seems very expensive .
if the anchor point is going to be screwed in they i guess the thief can just unscrew it and no need for cutting .
I may be missing something hence why am I asking . ____________________ SV650 Red
R6 Red |
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 12:15 - 03 Apr 2014 Post subject: |
pretty sure anchor points, are "normally" drilled into the floor then ball bearings are hammered into the head of the bolt so they cant be undone
like dis
| -Matt- |
 Posted: 12:19 - 03 Apr 2014 Post subject: |
Do you own the property - if its somewhere you own/staying longterm you may be able to ask permission to concrete something like this in. These are the most secure as theres litearlly nothing to attack besides the chain itself - you simply dig a hole, whack some gravel in the bottom to help drainage and then fill it with concrete and plonk the 'Y' inside. You can get non-branded anchors like this for very cheap maybe 10-20 quid.
https://50.6.224.4/images/new-copy-trans.gif
https://yanchor.com/images/ground%20anchor%20300.JPG
If thats not an option you're looking at about 30-40 quid minimum for a decent retail one. They're near impossible to remove [get permission if you're renting before installing it]. They use raul-bolts placed into drilled holes [I use resin inside the holes too personally to additionally reinforce it]. Then you hammer small ball-bearings into the heads of the bolts so they can't be unscrewed [again - I squirt a load of resin over the bolts on top of the bearing to further block it off].
https://www.demon-tweeks.co.uk/oncirrus/3/images/product/enlarge/pjb_red-alert-anch.jpg |
| GhostRider |
 GhostRider World Chat Champion
 Posted: 12:52 - 03 Apr 2014 Post subject: |
Could always get one of these as an additional measure:
https://www.ebay.co.uk/itm/Car-Vehicle-Children-Personal-GPS-Tracker-GPS-GSM-GPRS-Realtime-TK102B-Magnet-/161060205514?pt=UK_In_Car_Technology&hash=item257fefb3ca&clk_rvr_id=613695142058
Using one on mine, and the GPS is very very accurate.
On standby (no fence enabled) the battery lasts about a week and a half for me. Now you can wire it up to your lighting system, for example, so it charges only when the bike is on. I wouldn't recommend hooking up directly to the battery, as it'll flatten the battery (as happened to me earlier this week!!). But in any case, you can either remove the unit to charge it, or as said wire it up so it charges in a non-detrimental way.
Should it even got pinched you simply ring the sim card in the unit, 30 seconds later you get a text message with google map co-ordinates showing where it is.
Might not work so well if the bike is stored indoors somewhere, but better than nothing imo.
GhostRider ____________________ I have all the characteristics of a human being: blood, flesh, skin, hair; but not a single, clear, identifiable emotion, except for greed and disgust. Something horrible is happening inside of me and I don't know why. My nightly bloodlust has overflown into my days. I feel lethal, on the verge of frenzy. I think my mask of sanity is about to slip. |
| bugeye_bob |
 Posted: 13:24 - 03 Apr 2014 Post subject: |
 Posted: 13:45 - 03 Apr 2014 Post subject: |
Now this I like the look of. I may have to invest. ____________________ Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13 |
| GhostRider |
 Posted: 13:52 - 03 Apr 2014 Post subject: |
| TheDisapprovingBrit wrote: |
Now this I like the look of. I may have to invest. |
For £25 you can't argue really, compared to a "proper" device that will cost ~£300 to purchase + installation fee + £100 annual subscription for the service.
I use that in conjunction with a cheap alarm (not cyclone but very similar), almax chain and Xena alarmed disc lock. Can't really do much more than that apart from ground anchor.
| map |
 map Mr Calendar
| GhostRider |
 Posted: 14:21 - 03 Apr 2014 Post subject: |
| map wrote: |
...but based on this thread is it any good? | Ghostrider wrote: | The tracker had died completely...I stuck it into the USB charger, checked at lunch time and it was at 50% so figured everything was going ok, till 5pm came around... |
Genuine question as I was interested in the same unit. |
To clarify, when I say the tracker had died completely, I meant the battery was fulled drained, after a week and a half on standby, where every other day I would call the device to monitor the battery life (it gives battery % along with the GPS co-ords).
So my check at lunchtime showed the battery at 50% i.e it was charging ok. My bike battery hadn't faired so well - but again I don't know how old the bike battery is so might not be the best example of what to expect.
In any case, a wiring mod to rig up to the lighting system , followed by a check of what is going back to the battery at revs, should clear up any doubt as to whether its a good idea to charge in situ or reside to sticking it in a charger at home every 1.5 weeks (the pain in the arseness of this will depend on placement of the device naturally).
| Ribenapigeon |
 Ribenapigeon Super Spammer
| woo |
 woo World Chat Champion
 Posted: 18:00 - 03 Apr 2014 Post subject: |
or if you can afford it get a real tracker from www.tracker.co.uk ____________________ Elen sila lummen omentielvo! |
| stranger12 |
 Posted: 20:27 - 03 Apr 2014 Post subject: |
Does this particular one work without a sim card? It doesn't mention anything about sim card and says built in gsm ____________________ SV650 Red
R6 Red |
| raesewell |
 raesewell Traffic Copper
| GhostRider |
 Posted: 20:41 - 03 Apr 2014 Post subject: |
| raesewell wrote: | The problem with trackers is that they only tell you where the bike is after it's been nicked. Best not to get it nicked in the first place |
Hence the prior advice regarding almax chains, ground anchors, cyclone alarms and disc locks.
BUT should the worst happen, you want another trick up your sleeve - I believe if I'd had one in my GSXR I'd have stood a good chance of getting it back, or at least getting the cunts who robbed it arrested/knuckle dusted their jaw off when I went round their house.
Dayum, £500 on the nose? The other problem is that if it does get taken, there's every chance they'll set fire to the bastard, meaning an additional £350 down the drain, as opposed to £25 from a cheapy unit. Obviously the more expensive one had more advantages, but you gotta weigh up all the pros and cons really.
The last post was made 12 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
