Random flat tyre
Shreeve
PostPosted: 08:20 - 03 Apr 2014    Post subject: Random flat tyre Reply with quote
Went out for a nice ride last night with no problems and everything was fine. Pulled the bike out of the garage this morning and it felt really strange.
Checked the back tire and it was completely flat! I put it on the paddock stand and checked all around, no screws or obvious punctures.
When I get him tonight I'll try blowing it up. Apart from that is there anything else I could check or do?
Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4
PostPosted: 08:28 - 03 Apr 2014    Post subject: Re: Random flat tire Reply with quote
Do the push bike thing and immerse in water to see where the leak is?
Check the valve opening and around the base of the valve with a bit of spit first.
Shreeve
PostPosted: 08:35 - 03 Apr 2014    Post subject: Reply with quote
Great I'll do that, cheers!
Amber Phoenix
PostPosted: 08:40 - 03 Apr 2014    Post subject: Re: Random flat tire Reply with quote
Do this first! I was recently battling with a slow puncture on my front tyre, got to point where I was putting in air everyday. Ordered new tyre (as shop had none in my size in stock). Following day, I twigged it was leaking from valve. Popped to Halfords, got a £5 valve key, tightened up, 30secs later, perfectly fine tyre again. Doh!
Did pick up some spare valve cores too, as only a couple of quid. These sometimes go, but simply screw in/out of valve.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
PostPosted: 09:06 - 03 Apr 2014    Post subject: Re: Random flat tire Reply with quote
You can get valve caps that have the tool to loosen/tighten valves on them.
In the past I've made a point of having one of them on each of my vehicles. Less than a fiver too Smile.
Shreeve
PostPosted: 11:40 - 03 Apr 2014    Post subject: Reply with quote
Cheers for the advice chaps.
Took a day off tomorrow to go on a long ride too, Sod's law...
Shreeve
PostPosted: 16:31 - 03 Apr 2014    Post subject: Reply with quote
Soapy water found a tiny puncture, ride it to a local tire place and they reckon it's not repairable, £150 for a new tire fitted Sad
PostPosted: 16:40 - 03 Apr 2014    Post subject: Reply with quote
Where is the puncture?
You could try using some tyre sealant in the mean time, though it's not ideal, especially on a bike for a known puncture - but I've ridden good distances with sealant blocking a hole fine.
You could probably get a second hand tyre for not too much, but may have to wait for delivery if local places don't have any in stock.
Shreeve
PostPosted: 16:58 - 03 Apr 2014    Post subject: Reply with quote
It was right down the spine, he said it couldn't be repaired because of the type of tire and not because of where it is.
Left the bike there and going back in the morning, I need it daily so a quick fix was in order unfortunately.
Thanks for the previous advice, the water suggestion saved me so much time Karma
MattEMulsion
PostPosted: 22:15 - 03 Apr 2014    Post subject: Reply with quote
They sound like they are spinning you a line. What possible 'type of tyre' is it that can't be repaired???
Yamaha YZF-R6
PostPosted: 22:22 - 03 Apr 2014    Post subject: Reply with quote
What do you mean by 'spine'?
AS in a groove?
You can't repair a sidewall, but generally can anything between the two sidewalls.
serlant
PostPosted: 23:11 - 03 Apr 2014    Post subject: Reply with quote
as spine, centre of body (sort of?), centre of book( sort of?) I guess he meant the center? i'd agree on it being bollocks. what tyre is it out of interest?
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
moonzoomer
PostPosted: 23:17 - 03 Apr 2014    Post subject: Reply with quote
Try putting a tyre on the bike, those foreign muck tires are prone to punctures.
Shreeve
PostPosted: 08:09 - 04 Apr 2014    Post subject: Reply with quote
Yeh I meant the centre of the tire.
It's a Michellin, not sure what kind though, brand new when I bought the bike and it's seen 1000 miles.
I thought they could be spouting a load of rubbish but I had no choice, it's my only transport.
I'll upload a photo later and find out what kind of tire it is as I'm clearly not explaining this very well!
PostPosted: 08:14 - 04 Apr 2014    Post subject: Reply with quote
That should have been plugged. Anything near the centre is simple, they were just being money grabbing cunts.
PostPosted: 08:49 - 04 Apr 2014    Post subject: Reply with quote
Centre of the tyre should be easy to plug, as above.
Shreeve
PostPosted: 08:53 - 04 Apr 2014    Post subject: Reply with quote
It's a Michellin P4 and apparently it can't be plugged because of the speed rating, when it heats up the fix breaks?
Meh.
PostPosted: 08:56 - 04 Apr 2014    Post subject: Reply with quote
I've had Z rated tyres plugged fine.
And, for the matter; used them at those sorts of speeds. Plenty have done trackdays with plugged tyres.
I'd avoid the place in the future.
Shreeve
PostPosted: 09:05 - 04 Apr 2014    Post subject: Reply with quote
Yeh I think I will, royally shafted, lesson learned I guess.
Thanks again for all the advice!
Shreeve
PostPosted: 12:00 - 04 Apr 2014    Post subject: Reply with quote
Sorry for milking this but I did promise a picture, might be useful to someone else at some point, who knows.
Tire:
https://www.revzilla.com/motorcycle/michelin-pilot-road-4-rear-tires
Picture:
https://i60.tinypic.com/25a8b3c.jpg
PostPosted: 12:06 - 04 Apr 2014    Post subject: Reply with quote
What a cunt, that is easily plug-able.
Loads of tread Sad
Hugh Farking Cant
PostPosted: 12:08 - 04 Apr 2014    Post subject: Reply with quote
Keep the tyre; take it to another tyre fitter to repair; you now have a spare or replacement when the new tyre is done for.
Simples.
Also I have never understood the logic on not repairing tyres due to speed ratings.
Just coz you got a 180mph bike with a 180mph rated tyre does not compute to 180 mph use ! Brick Wall
map
Mr Calendar
PostPosted: 12:11 - 04 Apr 2014    Post subject: Reply with quote
Tire:
If you're American (or even Canadian) then you're forgiven...but it's tyre Rolling Eyes
Shreeve
PostPosted: 12:13 - 04 Apr 2014    Post subject: Reply with quote
I'm a geordie, also a valid excuse I think Laughing
My phone keeps changing it is the honest answer.
Hugh Farking Cant
PostPosted: 12:15 - 04 Apr 2014    Post subject: Reply with quote
Seeing as your in the locality; Who did you use ?
The last post was made 12 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 124.63 Kb
