Mod 1 & 2 on the horizon
Mumrah
PostPosted: 13:36 - 03 Apr 2014    Post subject: Mod 1 & 2 on the horizon Reply with quote
Hi all - it's been a while. . . I hope you're all well!
Apologies in advance for the long post, so you can dispense with the TL;DR comments and jog on now if you wish Wink
I signed up a some time in January and introduced myself. I had just passed my CBT (or was due to complete it, I can't remember which). I then bought a CBR125 Repsol which I've been using to gain confidence - it has worked wonders but I'm not there quite yet.
I passed my theory test on 18 March and so booked my Mod 1 & 2 with three training sessions on a JX600. First session will be 13 April, then 16 April, finally 29 April with the Mod 1 booked for 30 April - I've held off booking the Mod 2 until I've passed Mod 1.
I've been practising slaloms, u-turns and figure of eights around some make-shift cones (plastic cups weighed down with stones - what am I like?!) in a car park and feel quite confident that I can do that. I haven't been able to practice the avoidance or emergency stop as there isn't the room to pick up sufficient speed so hoping the training sessions will help on that. I'm getting really impatient though and wonder if, depending on my progress on the bigger bike and availability of tests, I could move the Mod 1 closer? Is this wise or should I stick to my plan? Am I going to notice a huge difference in terms of the bike sizes and my performance?
Also, can anyone confirm if the test spacing is as follows:
Slalom - 4.5m cone distance
Figure 8 - 6m cone distance
U-turn - 7.5m
If these are too generous then I'd better go back to the drawing board. I have been trying to do u-turns in between two parking spaces but it's tough and I often put my foot down so I'm hoping the distance on the test is as above.
Cheers Smile
ficedula
PostPosted: 14:12 - 03 Apr 2014    Post subject: Reply with quote
Mod1 dimensions are at:
https://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_197120.pdf
...but yes, your figures are correct.
If you're good on the slow manoeuvres then frankly that's the tricky bit. For all that they call it an emergency stop you have plenty of room to stop in and the most likely way to stuff that up is braking too hard and skidding - firm but controlled braking and you'll stop with room to spare.
You might take a bit of time to get used to the bigger bike - took me a while to get clutch / throttle control at low speeds sorted because it behaved differently to my 125 - but if you have a few lessons booked, that should be fine.
You could always see how the first lesson goes and then decide whether to move the mod1 up, but you might not be able to get a slot closer anyway, tbh.
Bike history: YBR125 -> XJ600
Az
PostPosted: 14:16 - 03 Apr 2014    Post subject: Reply with quote
Mod 1 Layout
https://i789.photobucket.com/albums/yy178/AzAndBikes/mod1layout_zps99ab6547.png
Mumrah
PostPosted: 14:29 - 03 Apr 2014    Post subject: Reply with quote
Thanks to you both, that's really useful. I think I'm most concerned about the avoidance because I've not done much of that to date. Slow moving is down to a consistent 3mph on my 125 so I'm at least happy with that.
There's definitely no turning back now as I have an appointment with a custom leathers shop on Saturday to be kitted out with a two-piece. That or I'll get them to find something they stock 'off the shelf'. It'll probably take the time up to my tests to start wearing the damn thing in. I foresee plenty of evenings on the sofa, stiff as a board, clad in leather! Very Happy
I'm off to check out clothing threads but if any women passby, please let me know of any decent fitting (and looking) leather gear you know about. The only nice looking stuff I've seen is, at best, designed for a pillion. I don't do pink or patterns which is limiting the market for me somewhat - hence the custom route - it's gonna cost though Smile
Edit/ Found the GirlsBike2 thread but I've already approached them and the only range I liked had zero armour (except on the forearm - not even elbow) and no hip protection. Looked great but next to useless! I may go through with the custom idea.
ficedula
PostPosted: 14:50 - 03 Apr 2014    Post subject: Reply with quote
FWIW, something my instructor told me about the avoidance was that you have to go through the speed trap at the right speed (2kph margin aside), you have to swerve around the cones without hitting them, and you have to get back in line again afterwards, but you don't have to stop in between the final set of cones.
If possible you should but it's only a minor if you ride between them and pull up past the specified stopping point ... so if you have to prioritise, get your speed up, do the swerve, and if you've taken longer than planned to get back in line, don't panic, slam the brakes on and skid to a halt - that'll get you failed. Just ride through the final set of cones and pull up safely beyond them. Better to have the minor for going beyond the stopping point than a serious fault for losing control and locking up under braking.
Of course, a bit of practice with an instructor and you should be able to get it down pat anyway Thumbs Up
Mumrah
PostPosted: 14:55 - 03 Apr 2014    Post subject: Reply with quote
Thanks again, that's good to know Smile
I'm hoping I'll have an instructor who is full of useful tips on what to do and what not to do. The last couple of days I've been reading through the Mod 1 pass/fail threads and there's a lot to pick up there too. It's also what made me get the 'cones' out last night! I just had to know if I could even begin to do it right.
PostPosted: 15:02 - 03 Apr 2014    Post subject: Reply with quote
Where is this "right speed" idea coming from? Eh?
It's at least 50kph, with a minor for doing 48-49. I'm not aware that there's any prohibition on doing it at a higher speed, as long as you're in control.
2nd gear, pin it, pass. Really, don't sweat it, it's not nearly as hard a test as the early horror stories made out, and it's been made easier and more sensible in the past couple of years.
I wouldn't wait, you want to be as fresh and familiar as possible on the XJ.
ficedula
PostPosted: 15:07 - 03 Apr 2014    Post subject: Reply with quote
Sorry, yes; I should have said at least the required speed.
I know you don't have to hit 50 exactly because I went through at 58 making sure I was up to speed Wink
EDIT: Thinking about it, I suppose the reason some instructors are keen to stop you from giving it too many beans is because then people panic when they do have to brake and lock up the wheel/s. But given the large amount of space you get to stop, still better to give it a bit too much welly than not enough.
Mumrah
PostPosted: 15:16 - 03 Apr 2014    Post subject: Reply with quote
Thanks. . .and yes, XJ - of all the typos. . . Smile
i.p.phrealy
PostPosted: 15:55 - 03 Apr 2014    Post subject: Reply with quote
if you have been riding for the last few months on the road you'll have done a few emergency stops and swerves or you'd be deaded by now!
if it helps, my instructor explained it was 50kph originally, but they looked at combining the Mod 1 & 2 on road so lowered it to 48kph as that is 30mph, and they couldn't really ask you to break the speed limit on your test. Laughing
for the record on my Mod 1, I clocked 57kph on the stop and 51kph on the swerve.
it looks far scarier than it is, it is the slow stuff and the U turns that people fail on. Thumbs Up
Mumrah
PostPosted: 16:04 - 03 Apr 2014    Post subject: Reply with quote
Thanks, IP.
Actually, I must be really (un)lucky - I've not needed to swerve once yet. Actually, there was one time where I had to get knee-down PDQ because I didn't turn for a corner AT ALL and another time I was just enjoying the bike and didn't notice the traffic slowing in front but I'd left plenty of room so it was fine - just gave me a hot flush for a second. No major issues yet, unless you're suggesting I'm swerving all the time and not even realising?
Baffler186
PostPosted: 16:30 - 03 Apr 2014    Post subject: Reply with quote
Mumrah wrote:
Thanks, IP.
Also it's not really a swerve as such. If you go through the speed trap already at an angle, you only have to swerve back in line. This will all be clearer and less daunting when your instructor takes you through the actual course. I was fretting a bit, but found it quite easy. I got a minor on the emergency stop because I didn't react quick enough to the chap's hand going up. I'm sure if he pushed a pram in front of me I would have reacted sooner though.
gbrand42
PostPosted: 20:09 - 03 Apr 2014    Post subject: Reply with quote
Mumrah wrote:
I foresee plenty of evenings on the sofa, stiff as a board, clad in leather!.
I think we've all been through this phase Twisted Evil
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
wr6133
PostPosted: 20:33 - 03 Apr 2014    Post subject: Reply with quote
Practice with the cones much tighter than for real and doing the stop and avoidance faster. My instructor did that to me and I managed to to e-stop at 68 and avoidance at 67 on the test because getting on the real course with such huge gaps between cones seemed a breeze compared to the day before on an almost half size one!
And don't get worked up about it, it really is easy especially on a big bike
Mumrah
PostPosted: 22:08 - 03 Apr 2014    Post subject: Reply with quote
Wow, not sure I could reduce the cone distance by half but I see your point and will give that a go next time I'm out.
Baffler, thanks for the angle tip. That'll definitely take the edge off!
It's amazing how wound up everyone gets over these tests. For me it's the desire for a bigger bike and not missing out on a summer riding it. I should put that out of my mind - easier said than done Very Happy
mic
PostPosted: 00:08 - 04 Apr 2014    Post subject: Reply with quote
for what its worth, i personally think the build up towards the test is so exageratted and more hype than anything. i know everyone is different and pick things up in their own way, but after a day practising for mod 1 id say its definantly enough for the test Very Happy cant imagine practising for days, specially on a 125 when the test is on a bigger bike.
just my 2p, hope it all goes well however you do it but as always im sure youll come back pleased as punch and didnt know what all the fuss was about Cool Laughing
zzr600
Mumrah
PostPosted: 09:10 - 04 Apr 2014    Post subject: Reply with quote
Thanks mic! I was mulling it over last night and I think the other part is the pressure of the expense.
I believe it's a case of deep breaths and remembering that I'm not 17 anymore and that tests are just BS and part of life. It'll be nerves that prevent me from passing and so if I can avoid that, I should be fine Smile
trevor saxe-coburg-gotha
PostPosted: 09:43 - 04 Apr 2014    Post subject: Re: Mod 1 & 2 on the horizon Reply with quote
U-turn - 7.5m
I made a point of practising those with as short/small distances as I possibly could. E.g. slalom with cups with stones in (I used them too iirc!) down to 3m, the 8 to 4.5m, the U to between 5 and 6. Get them as small as you can - then do them as slowly as you can, and as fast as you can. This is how you finesse that slow manoeuvre shit. It's how you get good, and make the all-the-gear-no-idea DAS ponces look like total twats when you're all on the 600s in the playground, and they're putting feet down right left and centre, have never dreamt of keeping the bight just so, having a few more revs if necessary and dragging the back break to iron out any slight remaining unsteadiness the bike might want you to carry.
Of course, the degree to which you can decrease the respective dimensions will to a certain extent be limited by the bike's lock. But even the gayest little fancy dress plastic ones like yours will be pretty good. So no excuses there, I'm afraid. Mr. Green
Mumrah
PostPosted: 10:02 - 04 Apr 2014    Post subject: Reply with quote
Ah, glad to hear I'm not the only one to have the cups and stones idea. Felt a bit pikey putting them out but it'll be worth it in the end. I'll give your measurements a go, Trevor.
Thanks for the description of my bike - you're probably right but hey, I like it. Even if people do approach it in awe, quickly followed by laughter when they see the Ls and 125 Very Happy
PostPosted: 10:22 - 04 Apr 2014    Post subject: Reply with quote
There was a repsol blade at the place where I get my bike worked on - the colours are great and the bike looked ace, but I just don't like to see brand names everywhere so much.
Mumrah
PostPosted: 10:48 - 04 Apr 2014    Post subject: Reply with quote
Sadly, I think they don't age well either.
When I first got it, I was half tempted to upgrade to the 600 version but I've quickly become bored with it. Probably going to go for a CBR600RR in black and custom paint the rims in some sickeningly, garish colour! That'll do me nicely Smile
wr6133
PostPosted: 12:08 - 04 Apr 2014    Post subject: Reply with quote
We know in reality you want this
https://i1249.photobucket.com/albums/hh504/wr6133/images_zpsdeae0715.jpg
Mumrah
PostPosted: 12:11 - 04 Apr 2014    Post subject: Reply with quote
You've seen right through me Sad
Although, to be fair, it's certainly garish!
The last post was made 12 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 125.74 Kb
