| Mumrah |
 Mumrah Nova Slayer
 Posted: 13:36 - 03 Apr 2014 Post subject: Mod 1 & 2 on the horizon |
Hi all - it's been a while. . . I hope you're all well!
Apologies in advance for the long post, so you can dispense with the TL;DR comments and jog on now if you wish
I signed up a some time in January and introduced myself. I had just passed my CBT (or was due to complete it, I can't remember which). I then bought a CBR125 Repsol which I've been using to gain confidence - it has worked wonders but I'm not there quite yet.
I passed my theory test on 18 March and so booked my Mod 1 & 2 with three training sessions on a JX600. First session will be 13 April, then 16 April, finally 29 April with the Mod 1 booked for 30 April - I've held off booking the Mod 2 until I've passed Mod 1.
I've been practising slaloms, u-turns and figure of eights around some make-shift cones (plastic cups weighed down with stones - what am I like?!) in a car park and feel quite confident that I can do that. I haven't been able to practice the avoidance or emergency stop as there isn't the room to pick up sufficient speed so hoping the training sessions will help on that. I'm getting really impatient though and wonder if, depending on my progress on the bigger bike and availability of tests, I could move the Mod 1 closer? Is this wise or should I stick to my plan? Am I going to notice a huge difference in terms of the bike sizes and my performance?
Also, can anyone confirm if the test spacing is as follows:
Slalom - 4.5m cone distance
Figure 8 - 6m cone distance
U-turn - 7.5m
If these are too generous then I'd better go back to the drawing board. I have been trying to do u-turns in between two parking spaces but it's tough and I often put my foot down so I'm hoping the distance on the test is as above.
Cheers  |
| ficedula |
 ficedula Scooby Slapper
 Posted: 14:12 - 03 Apr 2014 Post subject: |
Mod1 dimensions are at:
https://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_197120.pdf
...but yes, your figures are correct.
If you're good on the slow manoeuvres then frankly that's the tricky bit. For all that they call it an emergency stop you have plenty of room to stop in and the most likely way to stuff that up is braking too hard and skidding - firm but controlled braking and you'll stop with room to spare.
You might take a bit of time to get used to the bigger bike - took me a while to get clutch / throttle control at low speeds sorted because it behaved differently to my 125 - but if you have a few lessons booked, that should be fine.
You could always see how the first lesson goes and then decide whether to move the mod1 up, but you might not be able to get a slot closer anyway, tbh. ____________________ Bike history: YBR125 -> XJ600 |
| Az |
 Az World Chat Champion
 Posted: 14:16 - 03 Apr 2014 Post subject: |
| Mumrah |
 Mumrah Nova Slayer
 Posted: 14:29 - 03 Apr 2014 Post subject: |
Thanks to you both, that's really useful. I think I'm most concerned about the avoidance because I've not done much of that to date. Slow moving is down to a consistent 3mph on my 125 so I'm at least happy with that.
There's definitely no turning back now as I have an appointment with a custom leathers shop on Saturday to be kitted out with a two-piece. That or I'll get them to find something they stock 'off the shelf'. It'll probably take the time up to my tests to start wearing the damn thing in. I foresee plenty of evenings on the sofa, stiff as a board, clad in leather!
I'm off to check out clothing threads but if any women passby, please let me know of any decent fitting (and looking) leather gear you know about. The only nice looking stuff I've seen is, at best, designed for a pillion. I don't do pink or patterns which is limiting the market for me somewhat - hence the custom route - it's gonna cost though
Edit/ Found the GirlsBike2 thread but I've already approached them and the only range I liked had zero armour (except on the forearm - not even elbow) and no hip protection. Looked great but next to useless! I may go through with the custom idea. |
| ficedula |
 Posted: 14:50 - 03 Apr 2014 Post subject: |
| Mumrah wrote: | Thanks to you both, that's really useful. I think I'm most concerned about the avoidance because I've not done much of that to date. Slow moving is down to a consistent 3mph on my 125 so I'm at least happy with that.
FWIW, something my instructor told me about the avoidance was that you have to go through the speed trap at the right speed (2kph margin aside), you have to swerve around the cones without hitting them, and you have to get back in line again afterwards, but you don't have to stop in between the final set of cones.
If possible you should but it's only a minor if you ride between them and pull up past the specified stopping point ... so if you have to prioritise, get your speed up, do the swerve, and if you've taken longer than planned to get back in line, don't panic, slam the brakes on and skid to a halt - that'll get you failed. Just ride through the final set of cones and pull up safely beyond them. Better to have the minor for going beyond the stopping point than a serious fault for losing control and locking up under braking.
Of course, a bit of practice with an instructor and you should be able to get it down pat anyway  ____________________ Bike history: YBR125 -> XJ600 |
| Mumrah |
 Mumrah Nova Slayer
 Posted: 14:55 - 03 Apr 2014 Post subject: |
Thanks again, that's good to know
I'm hoping I'll have an instructor who is full of useful tips on what to do and what not to do. The last couple of days I've been reading through the Mod 1 pass/fail threads and there's a lot to pick up there too. It's also what made me get the 'cones' out last night! I just had to know if I could even begin to do it right. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:02 - 03 Apr 2014 Post subject: |
| ficedula wrote: | something my instructor told me about the avoidance was that you have to go through the speed trap at the right speed (2kph margin aside), |
Where is this "right speed" idea coming from?
It's at least 50kph, with a minor for doing 48-49. I'm not aware that there's any prohibition on doing it at a higher speed, as long as you're in control.
2nd gear, pin it, pass. Really, don't sweat it, it's not nearly as hard a test as the early horror stories made out, and it's been made easier and more sensible in the past couple of years.
I wouldn't wait, you want to be as fresh and familiar as possible on the XJ. ____________________ Biking is 1/20th as dangerous as horse riding.
| ficedula |
 Posted: 15:07 - 03 Apr 2014 Post subject: |
Sorry, yes; I should have said at least the required speed.
I know you don't have to hit 50 exactly because I went through at 58 making sure I was up to speed
EDIT: Thinking about it, I suppose the reason some instructors are keen to stop you from giving it too many beans is because then people panic when they do have to brake and lock up the wheel/s. But given the large amount of space you get to stop, still better to give it a bit too much welly than not enough. ____________________ Bike history: YBR125 -> XJ600 |
| Mumrah |
 Mumrah Nova Slayer
| i.p.phrealy |
 i.p.phrealy World Chat Champion
 Posted: 15:55 - 03 Apr 2014 Post subject: |
if you have been riding for the last few months on the road you'll have done a few emergency stops and swerves or you'd be deaded by now!
if it helps, my instructor explained it was 50kph originally, but they looked at combining the Mod 1 & 2 on road so lowered it to 48kph as that is 30mph, and they couldn't really ask you to break the speed limit on your test.
for the record on my Mod 1, I clocked 57kph on the stop and 51kph on the swerve.
it looks far scarier than it is, it is the slow stuff and the U turns that people fail on.  ____________________ it is impossible to lick your own elbow...
Finally allowed a big bike 19/03/14! |
| Mumrah |
 Mumrah Nova Slayer
| Baffler186 |
 Baffler186 World Chat Champion
| gbrand42 |
 gbrand42 Could Be A Chat Bot
 Posted: 20:09 - 03 Apr 2014 Post subject: |
| Mumrah wrote: | I foresee plenty of evenings on the sofa, stiff as a board, clad in leather!. |
I think we've all been through this phase  ____________________ Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
| wr6133 |
 wr6133 World Chat Champion
| Mumrah |
 Mumrah Nova Slayer
 Posted: 22:08 - 03 Apr 2014 Post subject: |
Wow, not sure I could reduce the cone distance by half but I see your point and will give that a go next time I'm out.
Baffler, thanks for the angle tip. That'll definitely take the edge off!
It's amazing how wound up everyone gets over these tests. For me it's the desire for a bigger bike and not missing out on a summer riding it. I should put that out of my mind - easier said than done  |
| mic |
 mic Brolly Dolly
 Posted: 00:08 - 04 Apr 2014 Post subject: |
for what its worth, i personally think the build up towards the test is so exageratted and more hype than anything. i know everyone is different and pick things up in their own way, but after a day practising for mod 1 id say its definantly enough for the test cant imagine practising for days, specially on a 125 when the test is on a bigger bike.
just my 2p, hope it all goes well however you do it but as always im sure youll come back pleased as punch and didnt know what all the fuss was about  ____________________ zzr600 |
| Mumrah |
 Mumrah Nova Slayer
 Posted: 09:10 - 04 Apr 2014 Post subject: |
Thanks mic! I was mulling it over last night and I think the other part is the pressure of the expense.
I believe it's a case of deep breaths and remembering that I'm not 17 anymore and that tests are just BS and part of life. It'll be nerves that prevent me from passing and so if I can avoid that, I should be fine  |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
| Mumrah |
 Mumrah Nova Slayer
 Posted: 10:02 - 04 Apr 2014 Post subject: |
Ah, glad to hear I'm not the only one to have the cups and stones idea. Felt a bit pikey putting them out but it'll be worth it in the end. I'll give your measurements a go, Trevor.
Thanks for the description of my bike - you're probably right but hey, I like it. Even if people do approach it in awe, quickly followed by laughter when they see the Ls and 125  |
| Mumrah |
 Mumrah Nova Slayer
 Posted: 10:48 - 04 Apr 2014 Post subject: |
Sadly, I think they don't age well either.
When I first got it, I was half tempted to upgrade to the 600 version but I've quickly become bored with it. Probably going to go for a CBR600RR in black and custom paint the rims in some sickeningly, garish colour! That'll do me nicely  |
| wr6133 |
| Mumrah |
 Mumrah Nova Slayer
 Posted: 12:11 - 04 Apr 2014 Post subject: |
You've seen right through me
Although, to be fair, it's certainly garish! |
The last post was made 12 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
