Tight nuts n shizz
mudcow007
PostPosted: 12:30 - 03 Apr 2014    Post subject: Tight nuts n shizz Reply with quote
Why is it, that some people tighten stuff to within an inch of their life, so the next time you go to remove what ever has been tightened its a bitch!!?
just replacing the bottom bracket on my pedaller an have so far snapped an impact socket (sealey) an bent a long allen key socket thingy
weasley
PostPosted: 12:50 - 03 Apr 2014    Post subject: Reply with quote
It's not a left-hand thread is it?
PostPosted: 12:55 - 03 Apr 2014    Post subject: Reply with quote
BBs are famous for seizing. Fine pitch thread tightened to nearly 70Nm in some cases.
I presume you're trying to undo the crank bolt rather than the BB itself though if you're using an allen key? Even some conventional crank bolts need doing up to 50Nm
I had to stand on a six foot piece of scaffolding tube over a breaker bar with the tool bolted in to remove the factory-fitted BB from my bosses bike.
Remember the left side of the BB is reverse threaded. (the crank bolt is not).
Heat is your friend.
Spamalittle
PostPosted: 13:42 - 03 Apr 2014    Post subject: Reply with quote
I know the feeling. I decided to refurb my really old hard-tail a couple of years ago. After about 12 years of careful and diligent neglect the bottom bracket was stuck solid. Wound up taking a blow torch, about 5ft of scaffolding leverage and 3 burly blokes from the ye olde bike shoppe to get it shifted. Was rusted completely solid - worst the shop had seen with barely enough thread left to fit a new BB Laughing
Shit of it being the bike was nicked about 6 months later. Wish I'd left it looking like a wreck.
Story so far: RV125 VanVan > SV650 > Indian Scout > Triumph Thruxton, SV650 (again) & CG125
mudcow007
PostPosted: 13:45 - 03 Apr 2014    Post subject: Reply with quote
cheers all, its one of them new fangled external bearing dealies
https://i25.photobucket.com/albums/c81/mudcow007/shimano-new-ult-bb-zoom_zps283331ae.jpg
i got it off in the end, after much swearing, puffing an panting
quite surprised how much play there was in the bearings
i woudlnt mind but the bike is only about 16months old, done a fair bit of mileage though
PostPosted: 13:59 - 03 Apr 2014    Post subject: Reply with quote
Worth knowing that you do get threadless BBs designed for just such an eventuality. The two parts of the BB screw together in the middle rather than the BB screwing into the frame. Downside is you need to hold both ends still to tighten it down fully which might require two BB tools.
smegballs
PostPosted: 16:03 - 03 Apr 2014    Post subject: Reply with quote
Sounds like something that would be well suited to putting modern BB's (and hence crank options) on old raleigh-threaded 3 speeds.
Commuter_Tim
PostPosted: 18:54 - 03 Apr 2014    Post subject: Reply with quote
Because thick fuckwits such as myself get paranoid it will come undone (admittedly through ignorance) and so tighten with almost all the strength we have.
I only just learned you can over-tighten an Axle nut to the point of crushing bearings... fail!
I ride a Bandit 600... badly.
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 57 Kb
