tyre spinning in neutral
PostPosted: 16:15 - 03 Apr 2014    Post subject: tyre spinning in neutral Reply with quote
i have recently split my engine and when starting it, the tyre spins in neutral when i hold the clutch then the spinning stops. And when I give it a gas the tyre spins faster. When I shift to 1st the wheel doesnt spin but i cant make it run with throttle, it just stalls. And it wont even shift to second gear. Is it the clutch wire that needs to be adjusted or have I have I fucked something up? Razz its a cbr125R btw
lihp
PostPosted: 16:21 - 03 Apr 2014    Post subject: Reply with quote
With the wheel off the floor?
YBR Ric
PostPosted: 16:24 - 03 Apr 2014    Post subject: Reply with quote
The btw model always did suffer gearbox problems.
c_dug
PostPosted: 16:26 - 03 Apr 2014    Post subject: Reply with quote
What he said ^
Could be a combination of slight drag in neutral and a dodgy clutch switch or sidestand switch or something causing it to cut out in first.
Orrr you could have messed something up big time.
When you say you split your engine I presume you mean the crank cases, i.e. had the whole thing apart?
Hugh Farking Cant
PostPosted: 16:31 - 03 Apr 2014    Post subject: Re: tyre spinning in neutral Reply with quote
770 wrote:
i have recently split my engine and when starting it, the tyre spins in neutral. And when I give it a gas the tyre spins faster. When I shift to 1st i cant make it run? And it wont even shift to2st . Is it the clutch wire that needs to be adjusted or have I have I fucked something up? Razz its a cbr125R btw
What the fuck is 2st. ?
770
PostPosted: 16:46 - 03 Apr 2014    Post subject: Re: tyre spinning in neutral Reply with quote
SECOND GEAR COMPRENDE
PostPosted: 16:47 - 03 Apr 2014    Post subject: Reply with quote
Have you tried skipping 2st and going to 3th?
770
PostPosted: 16:50 - 03 Apr 2014    Post subject: Reply with quote
i cant go longer up, when i pull the lever up the neutral light turns off but when i let my foot off the lever it goes back in neutral so technically it never reaches second gear? and also in neutral if i hold in the clutch the spinning stops. and the clutch lever also seems harder to pull in that it was original.
Hugh Farking Cant
PostPosted: 16:57 - 03 Apr 2014    Post subject: Re: tyre spinning in neutral Reply with quote
"SECOND GEAR COMPRENDE"
Not deaf; just never seen second defined in such a manner.
What is the clutch wire ?
Do you mean cable ?
770
SECOND GEAR COMPRENDE[/quote]
Do you mean cable ?[/quote]
yes i mean cluch cable sorry for my bad english
gavcarter
PostPosted: 16:58 - 03 Apr 2014    Post subject: Reply with quote
sound liek something is messed up if you ask me - check the selector forks are in right - with the drums in right position and you dont the forks reversed etc
Hugh Farking Cant
PostPosted: 17:07 - 03 Apr 2014    Post subject: Reply with quote
Accepted;
Sounds very much as you have made a # of the rebuild.
If you have a centerstand, take the spark plug out and see if you can cycle (go through) the gears using your hand on the gear change pedal and turning the rear wheel with the other hand. You don't need to use the clutch.
You should feel or hear if something is incorrect.
That way you are not stomping on the pedal and causing more damage.
Tungtvann
PostPosted: 19:14 - 03 Apr 2014    Post subject: Reply with quote
Is that threeth or firth?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:18 - 03 Apr 2014    Post subject: Reply with quote
I find that my back wheel spins Whilst I'm doing 50 mph when the roads are damp and I bang the throttle open hard in third gear.
Am I being enough of a hero or should I do it whilst half way round a bend?
Triumph Sprint ST 1050
dydey90
PostPosted: 20:15 - 03 Apr 2014    Post subject: Reply with quote
Sounds like the selector fork is set too low?
My CBR would spin the wheel in neutral, but you could stop it with your hand.
NO NOT try this until you have some sort of reassurance that it's ok and not actually in gear.
Fisty
PostPosted: 20:32 - 03 Apr 2014    Post subject: Reply with quote
Did you refit the powerbands?
Fatter and faster than Fret
770
PostPosted: 20:55 - 03 Apr 2014    Post subject: solution Reply with quote
i have now split the engine and i can see that i put one of the transmission sprockets the wrong way, well well..
Fisty
PostPosted: 22:02 - 03 Apr 2014    Post subject: Re: solution Reply with quote
Derp.
DottyDuck
PostPosted: 23:09 - 03 Apr 2014    Post subject: Reply with quote
dafuq did i just read?
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
pdg
PostPosted: 23:10 - 03 Apr 2014    Post subject: Reply with quote
Tyre spinning in neutral you say?
Make sure the tyre is the same size as the wheel, if it's bigger then it will spin and you'll have problems getting air to stay in.
HTH
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
The last post was made 12 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 103.07 Kb
