briggs and stratton engines
mic
PostPosted: 20:14 - 03 Apr 2014    Post subject: briggs and stratton engines Reply with quote
ok probably basic 101 engine stuff here but ill ask anyway!
i got an old 3hp rotavator. the guy who sold me it showed it working. i took it away, the next day eventually got it started then it died after about a minute. its got fresh petrol and the last owner claimes to have replaced the points etc recently.
the spark plug looks old. ive taken it out and cleaned it up. if you pull the starter rope, petrol goes thru ok so its not blocked. ive cleaned the spark plug up but still no joy. is it really as simple as a new spark plug to make it work? how would that explain it stop working all of a sudden?
cheers
zzr600
gdj444
PostPosted: 20:21 - 03 Apr 2014    Post subject: Reply with quote
Could be carb diaphragms, common problem with these engines. From memory there are two (?) a small side one part number 270026, and a bigger one with a spring which I think was part number 391681.
Worked in a lawn mower parts dept for 10 years and obviously still have some memory filled up with what is now useless information Very Happy
May be completely wrong though, am sure a mechanic will be along shortly to prove the ex parts monkey an idiot Cool
Jonesy
smegballs
PostPosted: 20:22 - 03 Apr 2014    Post subject: Reply with quote
Good chance it is the fuel pump diaphragm in the carb. The rubber goes floppy with age and hence doesn't do much pumping.
Good news is that they cost less than a fiver delivered from ebay! Thumbs Up
I replaced one on a rotavator last summer, bloody thing would very occasionally fire for a few seconds but that was it. New diaphragm and it fire up and ran lovely.
If this engine is old enough to have points, I'd strongly recommend replacing the diaphragm as a matter of course, they are dirt cheap, and it is something quick and simple to rule out when trying to diagnose intermittent problems.
PostPosted: 20:37 - 03 Apr 2014    Post subject: Reply with quote
I don't know about the horizontal shaft engines but every vertical shaft non-starter I ever had was tight valve clearances. Fixed in a few minutes by filing the pushrods down a bit.
Snodvan
PostPosted: 20:42 - 03 Apr 2014    Post subject: Reply with quote
Carb diaphragm I bet. Went on my rotovator. Bugger to get at but cheap to replace.
I did also have the magneto fail (the machine is near 40 years old) and that costs a lot more.
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
doggone
PostPosted: 20:50 - 03 Apr 2014    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?p=3852866
mic
PostPosted: 21:23 - 03 Apr 2014    Post subject: Reply with quote
Could've updated a previous thread i suppose.
Still stands it doesn't work and I've thought about it more since then.
zzr600
Raffles
PostPosted: 21:24 - 03 Apr 2014    Post subject: Reply with quote
The B&S engine on my lawnmower can be a right bugger to start. I reckon that it's probably just the carb that needs overhauling but I'm too lazy to do it so I just whip the plug out, squirt Easy Start down the plug hole and it's away.
mic
PostPosted: 14:32 - 05 Apr 2014    Post subject: Reply with quote
New spark plug £2.99 and it starts first time and does a great job Very Happy thanks for the advice and whatnot
zzr600
stevo as b4
PostPosted: 14:38 - 05 Apr 2014    Post subject: Reply with quote
Glad you got it going again!
I like olds Briggs motors, simple and crudely appealing too! I'd rather surround myself with B&S motors than mess with another Flymo 2stroke with the Tecumseh motor, they are all hateful buggers and I've never yet seen one that doesn't take lots of stripping down messing around and swearing like a trooper to start.
mic
PostPosted: 14:54 - 05 Apr 2014    Post subject: Reply with quote
Turned over the bit between the black matting and rotavator with a fork the other day and it's take about 30 mins to cut it all down to normalish soil. Will start to pull weeds etc out when I've done more.
https://i547.photobucket.com/albums/hh470/mic8310/2F944544-680A-4CAE-8799-39824ED6C942_zpszesynrpv.jpg
zzr600
Snodvan
PostPosted: 17:00 - 05 Apr 2014    Post subject: Reply with quote
Ah, same machine as I have. I have not used it for a few years but it is stored in a nice dry garage and I am sure would be ok if I needed it.
When I bought it I also bought the wheelbarrow kit ie Take off the digging tines and replace them with a pair of big tread wheels. A wheelbarrow scoop then fits on top of the platform and - behold, a powered wheelbarrow. I shifted a lot of stuff in mine over the years. I still have the wheels and barrow scoop but have not used it for ages. Some of the "bits" that attach the scoop to the machine are missing - but given a need I could improvise. However, much of the need has gone as I gave up my allotment around 2004.
Snod
The last post was made 12 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 72.62 Kb
