GPZ500 Rear wheel/chain/brake
stephen_o
PostPosted: 21:32 - 04 Apr 2014    Post subject: GPZ500 Rear wheel/chain/brake Reply with quote
Hi all, can you help me with a problem so I can sort it before it becomes something bigger please.
Had new chain (tight links) and new boot on rear brake, these were needed for mot. On picking bike up all is fine, and rear wheel spins freely however the back brake was poor. Ive done 200 miles on the bike over 5 days and noticed tonight the rear is begining to bind or drag again. I cant see or hear any clunking in the chain and the back brake has become more effective which leads me to think maybe the brake is binding or dragging...How do I sort it before I have a bigger issue...Its been really nice to ride the bike with everything right for a week almost and want to keep it that way.
Thanks
Stephen
current scoot 2009 Yamaha YBR250 + Current Pootle 2013 Nissan Leaf
PostPosted: 21:47 - 04 Apr 2014    Post subject: Reply with quote
With a GPZ500 (with a drum brake) the pivots for the operating cam for the brakes can seize up. I would suggest taking the wheel off, taking off the drum brake plate, take off the brake shoes and push out the operating pin (you will need to remove brake arm), clean it up and lube it then reassemble
stephen_o
PostPosted: 21:50 - 04 Apr 2014    Post subject: Reply with quote
Thanks for the quick reply, my apologies but because I had just answered in another post from someone about my old clapped out CG I was thinking that the GPZ had drum brakes (will never forget the horrendous power charge through the stop box on mod 1 in pouring rain fuming with myself that I had blown it because I couldn't stop the bike quick on dual drums in the wet for the examiner to say.."yes youve passed because your entitled to extra leeway for an old bike") so typed drum instead of disc. The GPZ has disc brakes front and back.
PostPosted: 21:55 - 04 Apr 2014    Post subject: Reply with quote
Ah, thought you mentioned drum, and the early ones have a drum rear brake.
If it has a disk rear brake then it is a single piston sliding caliper. they are a doddle to strip down and rebuild.
Check the wheel bearings while you are at it. Especially the sprocket carrier bearing, and also check that the spacer is in place between the sprocket carrier bearing and the wheel itself.
PostPosted: 22:25 - 04 Apr 2014    Post subject: Reply with quote
My 500 had a rear disc brake in the sense that there was a disc at the rear with a brake on it.
It is easy enough to clean out, you just need to pump the piston out and polish it, fish the seal out (I use a £1 shop dental pick filed blunt), and clean out thoroughly behind it (same tool), re-assemble and bleed (reverse bleed with a syringe by preference).
Then you'll have a disc at the rear with a brake on it that doesn't bind. Thumbs Up
PostPosted: 10:37 - 05 Apr 2014    Post subject: Reply with quote
'94 was the changeover year between disc and drum.
The rear discs are famously rubbish but shouldn't be binding.
In my experience, binding was normally caused by corrosion around one of the sliding pins.
One of the pins is fully enclosed inside the calliper casting, this one is usually fine. The other runs in an open hole right through the casting with a rubber boot over it, corrosion used to build up between the alloy of the calliper and the rubber boot. The pin itself was usually clean.
So a case of pull the calliper off the pins (this should be do-able by hand, if it isn't, this is definately the problem), try to get the rubber boot out without tearing it. Tear it. Order a new one, scrape/wiggle/polish the alloy corrosion out of the hole in the calliper while you're waiting for the new boot to arrive (may as well clean up the piston like Roger described too).
Grease both sides of the boot this time, reassemble.
i.p.phrealy
PostPosted: 11:19 - 05 Apr 2014    Post subject: Reply with quote
The last post was made 12 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 55.94 Kb
