| stephen_o |
 stephen_o Spanner Monkey
| stephen_o |
 Posted: 21:55 - 04 Apr 2014 Post subject: |
Ah, thought you mentioned drum, and the early ones have a drum rear brake.
If it has a disk rear brake then it is a single piston sliding caliper. they are a doddle to strip down and rebuild.
Check the wheel bearings while you are at it. Especially the sprocket carrier bearing, and also check that the spacer is in place between the sprocket carrier bearing and the wheel itself.
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:25 - 04 Apr 2014 Post subject: |
My 500 had a rear disc brake in the sense that there was a disc at the rear with a brake on it.
It is easy enough to clean out, you just need to pump the piston out and polish it, fish the seal out (I use a £1 shop dental pick filed blunt), and clean out thoroughly behind it (same tool), re-assemble and bleed (reverse bleed with a syringe by preference).
Then you'll have a disc at the rear with a brake on it that doesn't bind.  ____________________ Biking is 1/20th as dangerous as horse riding.
 Posted: 10:37 - 05 Apr 2014 Post subject: |
'94 was the changeover year between disc and drum.
The rear discs are famously rubbish but shouldn't be binding.
In my experience, binding was normally caused by corrosion around one of the sliding pins.
One of the pins is fully enclosed inside the calliper casting, this one is usually fine. The other runs in an open hole right through the casting with a rubber boot over it, corrosion used to build up between the alloy of the calliper and the rubber boot. The pin itself was usually clean.
So a case of pull the calliper off the pins (this should be do-able by hand, if it isn't, this is definately the problem), try to get the rubber boot out without tearing it. Tear it. Order a new one, scrape/wiggle/polish the alloy corrosion out of the hole in the calliper while you're waiting for the new boot to arrive (may as well clean up the piston like Roger described too).
Grease both sides of the boot this time, reassemble. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| i.p.phrealy |
 i.p.phrealy World Chat Champion
The last post was made 12 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
