primer cracking like mad
skikman
PostPosted: 15:11 - 06 Apr 2014    Post subject: primer cracking like mad Reply with quote
hi folks.i bought a yamaha fj1200 that was painted matt black.i want to do it in gloss black.i striped it down and sanded it.dont think it needs a prime coat as its pretty good,except for the belly pan which i have repaired,sanded and used a can of carplan hi-build primer.it cracked all over the place.not just the primer but through the matt to the original blue.sanded it down again and used plastic primer.went on ok but it is clear.so put the grey primer on it the next day and it started cracking as i was spraying.wtf is going on?
stickybackbob
PostPosted: 15:18 - 06 Apr 2014    Post subject: Reply with quote
The paint is reacting either to previous layers or to the plastic base. For plastic surfaces, running a blowtorch quickly over them and then wiping down with a solvent can get good results. For previously painted surfaces,an isolating paint may be required
gavcarter
PostPosted: 15:22 - 06 Apr 2014    Post subject: Reply with quote
get a power sander of some description, orbital , palm sander etc drill attachment and strip the whole thing back to bare plastic with 320 grit paper.
Give a good wash down with pre-paint panel wipe etc then start with a plastic primer. i would skip the high build primer unless you need a lot of little holes filling.
2 or 3 coats of normal primer with a light sanding of 600g will give a good firm base to start the colour on.
Tamsin
PostPosted: 17:18 - 06 Apr 2014    Post subject: Reply with quote
I agree with sticky.
Its a chemical reaction between the two paints, best thing to do is take it back to bare and start again...
misscrabstick
PostPosted: 18:08 - 06 Apr 2014    Post subject: Reply with quote
yep, reaction between paint products that do not agree with each other, you can buy isolator for spray guns that seals off the base layer from additional layers and stops this, don't think there is an aerosol equivalent though, rub it down to the plastic and start over.
skikman
PostPosted: 19:53 - 06 Apr 2014    Post subject: primer cracking like mad Reply with quote
thanks guys for the info.will sand right down and start again.i am going to use an air gun for the base coat and clear coat on everything.i have 2 pack paint.do i need an isolator for this?if so what do you recommend?
gavcarter
PostPosted: 19:57 - 06 Apr 2014    Post subject: Re: primer cracking like mad Reply with quote
Probably not once you are down to bare plastic.
have a read up on spraying with an airgun they can be a bit of an arsehole to get going right.
You need good dry air to lay down paint - any left over water in the lines will cause bubbling or crazing like you have already have experienced.
Get a LONG hose coil it in a bucket of cold water ( so it cools the air ) and then fit a GOOD filter to the line before the spray gun.
Strain the paint, be extra careful measuring the hardners and thinners - a mistake here can mean the pain never sets or just dries in the gun and doesn't get to the panel.
personally I find aerosols so much quicker and easier.....
sidewinder
PostPosted: 19:59 - 06 Apr 2014    Post subject: Reply with quote
2 pack you'll need a ventilated face mask.that stuff is bad if you breath it in Thumbs Up
lihp
PostPosted: 20:01 - 06 Apr 2014    Post subject: Reply with quote
This is far far easier to fix than everybody is suggesting.
Sand it back to remove all paint defects.
Leave for 24 hours and re-check for defects, then paint it with BARCOAT ISOLATOR (this will prevent the reactions) Then once that has cured paint whatever you want on top.
skikman
PostPosted: 22:25 - 06 Apr 2014    Post subject: Reply with quote
i just want to prime the belly pan.so sand right down,barcoat isolator then prime[right?]the rest of the bike[tank/panels in good shape]has been lightly sanded 320 then 400.do i still need to put barcoat isolator over everything before base coat
gavcarter
PostPosted: 22:33 - 06 Apr 2014    Post subject: Reply with quote
If your forking out for it instead of sanding right back then yes get enough to do whole bike.
If you using isolator only need to re-flatten the surface if paint is stuck well.
lihp
PostPosted: 22:54 - 06 Apr 2014    Post subject: Reply with quote
He still needs a 400grit finish, and no paint defects before the isolator.
You then paint your primer onto the Isolator, but you do NOT sand or do ANY prep to the Isolator, you can buy it in small quantities too.
gavcarter
PostPosted: 22:55 - 06 Apr 2014    Post subject: Reply with quote
Thats what a meant by flatten - should of expanded on it maybe....
lihp
PostPosted: 23:01 - 06 Apr 2014    Post subject: Reply with quote
Chances are, the paint on the rest of the bike is the same as what has been reacting.
So you're safest to do it all, if I am painting anything unknown, I always isolate, just to save any hassle later on for the sake of 2 hours time at the start.
Remember, reactions don't have to happen instantly, they may happen for up to 24 hours with 2-pack, and even a couple of days with Cellulose.
So getting the whole bike covered, in a nice finish, for it then to react is a real kick in the balls.
skikman
PostPosted: 23:34 - 06 Apr 2014    Post subject: Reply with quote
ok lads will do.first time spraying with gun so will practice a bit on old stuff before i tackle bike.1coat isolator,4 base,decals,3-4 clear??? do i let harden and sand in between any coats?
PostPosted: 23:38 - 06 Apr 2014    Post subject: Reply with quote
Could just be over-eager for the re-coat too.
I've had a second layer of paint crack up on me after putting the first layer onto dry, bare metal with a rattle can. Nothing there for it to react with other than the first layer of exactly the same paint which went on smooth.
Pure impatience, I should have left it a few days before re-coating.
lihp
PostPosted: 00:12 - 07 Apr 2014    Post subject: Reply with quote
Plenty to react with unless you're in a spray booth
PostPosted: 09:20 - 07 Apr 2014    Post subject: Reply with quote
More that the second coat also cracked and lifted the first coat too.
lihp
PostPosted: 09:30 - 07 Apr 2014    Post subject: Reply with quote
Reactions don't always happen instantly though, and can take a few days even depending on the paint used. Any reaction will affect all layers above it.
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 104.75 Kb
