| marlc0 |
 marlc0 Renault 5 Driver
 Posted: 07:18 - 06 Apr 2014 Post subject: ER6-F Blowing exhaust |
Right then, out on a ride t'other day, and after a bit of a bumpy stretch of road, the bike started to sound rather loud.
Limped it back home, and parked her up, had a look around, couldn't see anything obvious, when i gave it some revs, the back box was rattling on the joint to the header, thus the issue.
So, has anyone done this before? I've got a haynes manual, but i thought i'd ask some sage advice before I dive into it. It looks like it's held on by a jubulee clip type thing, but it's rusty as shit, so will probs need replacing.
Any tips? ____________________ 2010 Kawasaki ER6-f - Given to the Mrs.
2016 Triumph Tiger 800 |
| wots |
 wots World Chat Champion
| barrkel |
 barrkel World Chat Champion
 Posted: 13:57 - 06 Apr 2014 Post subject: |
Mine snapped after 5 years and 45k miles.
Delkevic do a decent enough set of stainless headers. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| marlc0 |
| wots |
| marlc0 |
| guile |
 guile Spanner Monkey
| marlc0 |
| Muscle Bike Rider |
 Muscle Bike Rider World Chat Champion
| guile |
 Posted: 12:37 - 07 Apr 2014 Post subject: |
Mine is an 06 but I have seen even 12 models being affected, so they have done nothing to correct it.
Check out this long thread about it (sign-up required):
https://www.bikersoracle.com/er5/forum/forumdisplay.php?f=28
Hammering a smaller socket got another 2 out, so thanks for that advice. Now I have one stubborn nut left. 12mm socket seems to fit quite nicely but it just slips whenever I turn it. Can I just go mental with the 11mm? It doesn't want to go on with the hammering I have done so far but it is in a tight place where I probably havn't been hitting hard enough. Any reason not to get too rough with it? |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 14:20 - 07 Apr 2014 Post subject: |
Had a similar problem with my '03 Bandit.
Eventually got the link pipe replaced, and the original silencer swapped with a Beowulf stubby can ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| marlc0 |
 Posted: 17:04 - 07 Apr 2014 Post subject: |
| guile wrote: |
I think I used a 12mm socket on it, which isn't a normal size for standard metric, which is kinda the reason I remember it. I think.....
If you can get hold of an imperial socket set, or an old witworth set, try using an equivilant size, you'll find they are never a true equivilent, i've had a look at my metrinch socket set, and it uses 12mm&15/32, try something that size.
Or, are you using a bi-hex socket? If so, use a single hex, you get more grip, if you want to batter on a smaller socket, use a bi-hex, you get a little more "wriggle" with it.
Also, make sure when you're putting everything back together, use a bolt lube, such as coppaslip or molycote, it aids in torque, by reducing friction (only 10% of bolt load is "useful load") and aids in taking it out the next time, plus it'll help with reducing bolt corrosion. ____________________ 2010 Kawasaki ER6-f - Given to the Mrs.
| sickpup |
 sickpup Old Timer
| guile |
| andys675 |
 andys675 World Chat Champion
| marlc0 |
 Posted: 11:15 - 10 Apr 2014 Post subject: |
| wots |
The last post was made 11 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
