help- problems starting my bike
Gaz92
PostPosted: 19:02 - 07 Apr 2014    Post subject: help- problems starting my bike Reply with quote
i have a Yamaha sr 125
i Haven't started it since July, so 7 months .
im having problems starting it. I can start it with the choke ,but it has no power and will cut out in 1-5 seconds .
the oil was out, so fill it up with fresh oil .
i have tried rolling starting it but still has no power and cuts out after about 5 seconds .
CaNsA
PostPosted: 19:30 - 07 Apr 2014    Post subject: Reply with quote
Check battery
Check Spark plug.
Drain carb
Fresh fuel
PostPosted: 19:59 - 07 Apr 2014    Post subject: Re: help- problems starting my bike Reply with quote
how why oil was out might problem maybe be perhaps
Scythe
PostPosted: 20:36 - 07 Apr 2014    Post subject: Reply with quote
Drain carb and fresh fuel.
My Carbed SV used to do this, sputtered and cut out a little when getting it out after winter until the fresh fuel ran through. When you have it running, give it a ride to clear out the cobwebs. Thumbs Up
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
Gaz92
PostPosted: 21:52 - 07 Apr 2014    Post subject: Reply with quote
Is it easy to drain the carb. I've just had a little look in the Haynes manual. Will try it tomorrow. Also do I need to drain the little bit of petrol left in there before I add new stuff
clancy
PostPosted: 22:59 - 07 Apr 2014    Post subject: Reply with quote
Yes and yes
Take the Carb off and clean it with a bit of petrol then put it back together, empty the tank, new fuel in then run it
Will struggle to start at first till the fuel gets through the system. Then give it a good run once it's started
KLX 300r
Gaz92
PostPosted: 12:53 - 08 Apr 2014    Post subject: Reply with quote
Okay cheers guys I drained the carb and sieved the petrol out( got a mouth full lol) put new petrol in. And starts now and rides fine. But it won't tick over as soon as I stop revving it cuts out
Any ideas?
CaNsA
PostPosted: 12:56 - 08 Apr 2014    Post subject: Reply with quote
Full choke for a few mins, then half choke for a few mins, then should be fine.
Gaz92
PostPosted: 09:29 - 09 Apr 2014    Post subject: Reply with quote
Okay I did full choke for about 2 mins and it cut out
And now it will not start at all. I left it over night and tried
It this morning and still it's not making any attempt to start
HotdogMcDraw
PostPosted: 13:17 - 09 Apr 2014    Post subject: Reply with quote
Try the air/fuel mixture on the carb. Played around with mine after months of storage and worked for me. Not sure where they are on your bike but usually located at the bottom of the carb and on the side.
Gaz92
PostPosted: 14:28 - 09 Apr 2014    Post subject: Reply with quote
Is that the thing you turn to change the idle speed? Or is that something else
HotdogMcDraw
PostPosted: 16:43 - 09 Apr 2014    Post subject: Reply with quote
Check this link out https://hondacg125.awardspace.com/idle_screws.htm helped me get my carb sorted, might not be the answer to your problem though but worth a try.
Edit: I know it's not the same carb as your bike, but i'm sure you get the idea from seeing the link.
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.93 - MySQL Queries: 13 - Page Size: 69.77 Kb
