CBR 954 on GSX750 help!
ninoBFU
PostPosted: 22:28 - 07 Apr 2014    Post subject: CBR 954 on GSX750 help! Reply with quote
Hi guys
Can you please tell me if these forks would fit on my bike.
Bearing dimensions:
Top
INNER DIAMETER / OUTER DIAMETER / WIDTH
CBR. 26. / 47. / 15
Gsx. 25. / 47. / 15
Bottom
CBR. 30. / 55. / 17
Gsx. 30. / 55. / 17
Thanks in advance
<a href="https://www.bikechatforums.com/viewtopic.php?p=3879192#3879192/">My GSX 750 1981 Cafe Racer Project build</a>
hmmmnz
PostPosted: 09:34 - 08 Apr 2014    Post subject: Reply with quote
i think you pretty much answered your own question in regards to the bearing dimensions,
no, if you are using the donor bike yokes/triples and arnt using new bearings,
if you use the cbr sized bearings on the top it should be fine
provided the headstock isn't vastly different, you may need to make up a spacer
the humans are dead
I kick arse for the lord
ninoBFU
PostPosted: 09:58 - 08 Apr 2014    Post subject: Reply with quote
Thanks for the answer.
I am planning to get the CBR bearings top and bottom. I was wondering g if the headstock would fit the frame...the bottom bearings are the same, but the top one has a 1mm difference .
hmmmnz
PostPosted: 10:09 - 08 Apr 2014    Post subject: Reply with quote
there will be no difference if you use the cbr bearings,
the external dimensions of the bearings (the bit that would be in the head stock) is the same, its the stem at the top that is 1mm different,
get it and make it work,
ive done numerous usd conversions, and that looks like its going to be a pretty straight forward one,
keep us posted and start a build thread in the show and tell
the humans are dead
The last post was made 12 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 41.6 Kb
