DIY short term baffle
PostPosted: 19:33 - 08 Apr 2014    Post subject: DIY short term baffle Reply with quote
So, Château Borg is on a leafy suburban estate, and I set off at 7am.
In the thrill[*] of scoring my Enfield, I overlooked the issue that a massive[*] 500cc lump firing through an unbaffled pipe is actually pretty noisy. I do intend to use it as an everyday commuter[*].
In anticipation: no, I will not inflict the throat punch of justice, nor tell the neighbours to get bent. It's a nice estate, we all get on, and I want to keep it that way. It could be pushed, but my groom rarely bestirs himself at that hour.
So, how to temporarily mute an engine for around 1 minute and 200 yards? Stuff a rag in the tailpipe, or anything a bit less ghetto?
[*] Shut it.
PostPosted: 19:41 - 08 Apr 2014    Post subject: Reply with quote
Can I come visit with my KTM? Your's will be silent in comparison.
I'm sure you can get some form of flap/valve combo, unsure how they work exactly, but they are available for cars and open at x amount of revs. Working one into your power house might be a challenge, but I know you love that Wink
gavbriggs
PostPosted: 20:18 - 08 Apr 2014    Post subject: Reply with quote
Why not get a dbkiller for it and make it like a light bulb bayonet fitting? Then you can stop and just remove it.
PostPosted: 20:34 - 08 Apr 2014    Post subject: Reply with quote
Gavbriggs wrote:
dbkiller
See, this is the kind of hooligan street slang that I'm lacking. Cheers, chap, I'm getting the under-butler to investigate that. Thumbs Up
hmmmnz
PostPosted: 20:46 - 08 Apr 2014    Post subject: Reply with quote
what about a stuffed cone type baffle,
hmmm ms paint i think
basically a cone with the pre drilled holes in it, and then a flat plate on the end so the gas's have to go around it and through the small holes
you can then stuff that with wire wool if need be,
add a little tab off the end that you can grab to pull it back out
jobs a good un'
the humans are dead
I kick arse for the lord
wr6133
PostPosted: 20:51 - 08 Apr 2014    Post subject: Reply with quote
Rags don't work not even on my baffle free 250. You won't get enough rag in the pipe to kill the noise.
Though I heard a large part of Enfield ownership is telling everyone you have an Enfield so in that light the morning noise is really a great bonus.
The DBkiller idea sounds good.
gavbriggs
PostPosted: 21:22 - 08 Apr 2014    Post subject: Reply with quote
Rogerborg wrote:
Gavbriggs wrote:
dbkiller
It's worth a pop for 20 quid. One thing tho, if you drill your exhaust and then dont find a way to bung the hole when the db killer is out you will have some weird noises as the exhaust wafts over the hole.
I simply put a bolt and wing nut in there and keep the db killer under the seat so it's handy should I need it. Also tools to install/remove it.
If the bayonet fitting is an idea you want to use, put the studs on the exhaust and cut the slots in the dbkiller as the noises mentioned above are damn annoying.
Edit: I am not an 'hooligan' I am merely safety conscious and want to warn others of my approach, at the speed limit of course, so as to avoid any adverse collisions which could render me dead! Plus my neighbours are pensioners and tbh are always up early and are mostly deaf. The rest on the street can piss off cos I don't complain when they stagger home from the boozer up the road singing of a Friday evening!
PostPosted: 21:23 - 08 Apr 2014    Post subject: Re: DIY short term baffle Reply with quote
I've oft-wondered about making a switchable baffle.
My designs tend to be less realistic for production, but a simple butter fly valve in the exhaust probably do it.
Or, more ghetto something that swings down over the end like the lenses they have at the opticians.
In either case, a few holes in it if needed. I passed a c90 MOT with a pit bike exhaust (which they'd complained about) by circlipping a coke can with some holes in over the end. Pretty much no can left by the time I'd got it the half mile home again to be fair - but I did have the pass in my grubby mits, so no issue.
Or you could have a slit a little further up the exit pipe and have it popped in held with a latch. Pull an appropriate cable (push bike gear lever etc) to release the catch and let it drop down so the way is clear.
Or take a camera lens aperture thingy, but make it out of steel Smile.
gavbriggs
PostPosted: 21:29 - 08 Apr 2014    Post subject: Reply with quote
What about a large balloon or space hopper over the exhaust? It would probably only just be full by the time you get 200 yards down the road and may even fly off the exhaust on its own. All you have to do then collect it on the way back home. All the noise will still be in the balloon or will have released 200 yards down the road, thus not annoyng the residents! Easy
PostPosted: 22:00 - 08 Apr 2014    Post subject: Reply with quote
I think we have a winner.
Backup plan is the space hopper, although I'd use the captured carbons to grow a little bonsai tree in the panniers.
gbrand42
PostPosted: 22:08 - 08 Apr 2014    Post subject: Reply with quote
What us up with people? Given the choice of waking to a lovely Enfield soundtrack or my miserable squawking alarm clock I know which one I would choose.
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
PostPosted: 22:19 - 08 Apr 2014    Post subject: Reply with quote
Thing is, there are 3 (!) Subarus in this estate, 1 of which leaves about the same time as me, and another owner works shifts. I'd just rather be a bit less ASBO than them.
Db killer ordered, will be bayonetted. Thumbs Up
nowhere.elysium
The Pork Lord
PostPosted: 07:27 - 09 Apr 2014    Post subject: Reply with quote
If the DB killer doesn't pan out (and I have yet to encounter one that'll work in a 'classic' shaped exhaust), the incredibly ghetto method I had for baffling my 125 does work rather admirably; two sink strainers, with some wire wool packed in the middle, riveted together. Provided you can breathe through it, it is OK to go on the exhaust.
Given that it's an Enfield, I really wouldn't be too worried about the backpressure from 200 yards' worth of riding - the phrase "state of tune" doesn't even begin to apply, in truth.
PostPosted: 07:45 - 09 Apr 2014    Post subject: Reply with quote
In the old days when people walked fast in black and white, apparently a coke can with holes punched in the end worked well as a temporary baffle for MOT's and the like. However that might not work in a titchy Enfield classic peashooter...
PostPosted: 09:17 - 09 Apr 2014    Post subject: Reply with quote
They aren't all that intrusive at idle and it is most definately possible to ride one "quietly".
I spent the best part of two months staying on camping and caravan club sites when I did my tour of Britain with a totally unbaffled exhaust on the 350. If it had been in any way intrusive or antisocial, disgruntled of Hove (actually) would have been sure to say something. After all, an Englishmans caravan is his castle.
Hitchcocks sell both baffles and a mute for bullet exhausts (scroll down about two thirds of the way down the page with your eyes closed to avoid unecessary temptation).
https://www.hitchcocksmotorcycles.com/page.php?currentpageref=113
PostPosted: 09:33 - 09 Apr 2014    Post subject: Reply with quote
Oh, it's a pussycat at idle, but it does need a bit of throttle to get moving - which might be down to the fuelling, it's on my list. I'm coming uphill off my drive and haven't managed to do so quietly yet.
That Hitchcock's baffle looks identical in construction to the one I've just ordered from eBay, so I'll give it a go.
I am trying to avoid browsing Hitchcocks for obvious reasons. Whistle
map
Mr Calendar
PostPosted: 09:41 - 09 Apr 2014    Post subject: Reply with quote
stinkwheel wrote:
Tut Tut Posting bike porn, should put a not safe for work on that Wink
PostPosted: 11:08 - 09 Apr 2014    Post subject: Reply with quote
Uphill can do it, yeah, especially when they are cold.
I suppose you could always ask your neighbours. I had some old biddies next door at my last house and they always commented favourably on the noise it made. Usually accompanied by a story about a holiday they went to in their late husbands BSA and sidecar to Skegness which resulted in it being pushed into a ditch, set on fire and catching the bus home.
You on an Amal or a Mikcarb? Amal concentrics are famously problematic around the changeover between idle and main jet (the slow running circuit is a rediculously narrow and torturous drilling in the carb). Mine certainly has a big hole in the carburettion there (lags off the slow running as if it's going to stall then picks up onto the main) but I don't spend much time with it at that rev speed anyway.
You can mess with slide cutaways, jet diameters etc. etc. on a Mikcarb. I put a Japanese made jet kit on mine before I fitted the amal (so essentially replacing all the brass bits with mikuni ones) which certainly made it a lot smoother.
PostPosted: 12:40 - 09 Apr 2014    Post subject: Reply with quote
Amal. It idles beautifully but is fussy about running at just above idle when cold. It wants a resolved hand to get up my drive, and blat-blat-blat echoes off of the garage door. Great fun for me, not so much for those slug-a-beds still malingering in their bunks.
I've not had it that long, I may find a method to ease it away. In the meantime though, it'll be baffle in.
One of the "neighbours" in question is Mrs Borg who is still abed at 7am, so this is a non-negotiable issue.
map
Mr Calendar
PostPosted: 12:48 - 09 Apr 2014    Post subject: Reply with quote
Rogerborg wrote:
...idles beautifully but is fussy about running at just above idle when cold...to get up my drive, and blat-blat-blat echoes off of the garage door...
Out of interest how long before warm and therefore not so noisy when moving?
Thinking out of the box, sound deadening on garage door?
Also thinking out of the box, sound deadening Mrs Borg's bedroom. Mrs Borg getting an early morning job, just for the pin money you understand.
PostPosted: 13:12 - 09 Apr 2014    Post subject: Reply with quote
Dunno yet, I've only ridden it thoroughly warmed (when buying) and from fairly cold (at home). I'm not minded to become a warm-up merchant.
Early days though, never say never, game of two halves, fight them on the beaches.
map
Mr Calendar
PostPosted: 13:28 - 09 Apr 2014    Post subject: Reply with quote
Rogerborg wrote:
...I'm not minded to become a warm-up merchant...
I'd run that by Mrs Borg.
Or does she have experience of this technique? Wink
Hint: shouting brace as you leap off the chest of drawers is not foreplay.
PostPosted: 14:01 - 09 Apr 2014    Post subject: Reply with quote
Choke, a good solid kick, one hard twist and we're off.
Hi Mumsnet.
biker7
PostPosted: 18:29 - 20 Apr 2014    Post subject: Reply with quote
Easy temporary baffle......first take a large crocodile clip or jump lead clip. Clamp inside pipe to test it and see what shape you need to fill in. Carve a piece of wood to fit this shape. Drill a hoe in the clip. Use wood screw to secure bung to clip. Clip in pipe to close hole and eliminate 90% of noise. Ride away from home. Stop and remove bung. Reverse process to return home later. The wood will not burn for short distances. The engine will cope. If it will not stay in, drill small hole in pipe and fit bolt for the clip to bite on. Worked for me.
Swansea area
Fat Bob (2019)
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 132.87 Kb
