| Rogerborg |
 Rogerborg nimbA
 Posted: 19:33 - 08 Apr 2014 Post subject: DIY short term baffle |
So, Château Borg is on a leafy suburban estate, and I set off at 7am.
In the thrill[*] of scoring my Enfield, I overlooked the issue that a massive[*] 500cc lump firing through an unbaffled pipe is actually pretty noisy. I do intend to use it as an everyday commuter[*].
In anticipation: no, I will not inflict the throat punch of justice, nor tell the neighbours to get bent. It's a nice estate, we all get on, and I want to keep it that way. It could be pushed, but my groom rarely bestirs himself at that hour.
So, how to temporarily mute an engine for around 1 minute and 200 yards? Stuff a rag in the tailpipe, or anything a bit less ghetto?
[*] Shut it. ____________________ Biking is 1/20th as dangerous as horse riding.
| P.addy |
 P.addy Red Rocket
 Posted: 19:41 - 08 Apr 2014 Post subject: |
Can I come visit with my KTM? Your's will be silent in comparison.
I'm sure you can get some form of flap/valve combo, unsure how they work exactly, but they are available for cars and open at x amount of revs. Working one into your power house might be a challenge, but I know you love that  |
| gavbriggs |
 gavbriggs Crazy Courier
| Rogerborg |
 Rogerborg nimbA
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 20:46 - 08 Apr 2014 Post subject: |
what about a stuffed cone type baffle,
hmmm ms paint i think
basically a cone with the pre drilled holes in it, and then a flat plate on the end so the gas's have to go around it and through the small holes
you can then stuff that with wire wool if need be,
add a little tab off the end that you can grab to pull it back out
jobs a good un' ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| wr6133 |
 wr6133 World Chat Champion
| gavbriggs |
| G |
 G The Voice of Reason
 Posted: 21:23 - 08 Apr 2014 Post subject: Re: DIY short term baffle |
I've oft-wondered about making a switchable baffle.
My designs tend to be less realistic for production, but a simple butter fly valve in the exhaust probably do it.
Or, more ghetto something that swings down over the end like the lenses they have at the opticians.
In either case, a few holes in it if needed. I passed a c90 MOT with a pit bike exhaust (which they'd complained about) by circlipping a coke can with some holes in over the end. Pretty much no can left by the time I'd got it the half mile home again to be fair - but I did have the pass in my grubby mits, so no issue.
Or you could have a slit a little further up the exit pipe and have it popped in held with a latch. Pull an appropriate cable (push bike gear lever etc) to release the catch and let it drop down so the way is clear.
Or take a camera lens aperture thingy, but make it out of steel . |
| gavbriggs |
| Rogerborg |
 Rogerborg nimbA
| gbrand42 |
 gbrand42 Could Be A Chat Bot
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:19 - 08 Apr 2014 Post subject: |
Thing is, there are 3 (!) Subarus in this estate, 1 of which leaves about the same time as me, and another owner works shifts. I'd just rather be a bit less ASBO than them.
Db killer ordered, will be bayonetted.  ____________________ Biking is 1/20th as dangerous as horse riding.
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 07:27 - 09 Apr 2014 Post subject: |
If the DB killer doesn't pan out (and I have yet to encounter one that'll work in a 'classic' shaped exhaust), the incredibly ghetto method I had for baffling my 125 does work rather admirably; two sink strainers, with some wire wool packed in the middle, riveted together. Provided you can breathe through it, it is OK to go on the exhaust.
Given that it's an Enfield, I really wouldn't be too worried about the backpressure from 200 yards' worth of riding - the phrase "state of tune" doesn't even begin to apply, in truth. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| MarJay |
 MarJay But it's British!
| stinkwheel |
 Posted: 09:17 - 09 Apr 2014 Post subject: |
They aren't all that intrusive at idle and it is most definately possible to ride one "quietly".
I spent the best part of two months staying on camping and caravan club sites when I did my tour of Britain with a totally unbaffled exhaust on the 350. If it had been in any way intrusive or antisocial, disgruntled of Hove (actually) would have been sure to say something. After all, an Englishmans caravan is his castle.
Hitchcocks sell both baffles and a mute for bullet exhausts (scroll down about two thirds of the way down the page with your eyes closed to avoid unecessary temptation).
https://www.hitchcocksmotorcycles.com/page.php?currentpageref=113 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:33 - 09 Apr 2014 Post subject: |
| stinkwheel wrote: | They aren't all that intrusive at idle and it is most definately possible to ride one "quietly". |
Oh, it's a pussycat at idle, but it does need a bit of throttle to get moving - which might be down to the fuelling, it's on my list. I'm coming uphill off my drive and haven't managed to do so quietly yet.
That Hitchcock's baffle looks identical in construction to the one I've just ordered from eBay, so I'll give it a go.
I am trying to avoid browsing Hitchcocks for obvious reasons.  ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
 Posted: 09:41 - 09 Apr 2014 Post subject: |
Posting bike porn, should put a not safe for work on that  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| stinkwheel |
 Posted: 11:08 - 09 Apr 2014 Post subject: |
| Rogerborg wrote: | [
Oh, it's a pussycat at idle, but it does need a bit of throttle to get moving - which might be down to the fuelling, it's on my list. I'm coming uphill off my drive and haven't managed to do so quietly yet. |
Uphill can do it, yeah, especially when they are cold.
I suppose you could always ask your neighbours. I had some old biddies next door at my last house and they always commented favourably on the noise it made. Usually accompanied by a story about a holiday they went to in their late husbands BSA and sidecar to Skegness which resulted in it being pushed into a ditch, set on fire and catching the bus home.
You on an Amal or a Mikcarb? Amal concentrics are famously problematic around the changeover between idle and main jet (the slow running circuit is a rediculously narrow and torturous drilling in the carb). Mine certainly has a big hole in the carburettion there (lags off the slow running as if it's going to stall then picks up onto the main) but I don't spend much time with it at that rev speed anyway.
You can mess with slide cutaways, jet diameters etc. etc. on a Mikcarb. I put a Japanese made jet kit on mine before I fitted the amal (so essentially replacing all the brass bits with mikuni ones) which certainly made it a lot smoother. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:40 - 09 Apr 2014 Post subject: |
| stinkwheel wrote: | You on an Amal or a Mikcarb? |
Amal. It idles beautifully but is fussy about running at just above idle when cold. It wants a resolved hand to get up my drive, and blat-blat-blat echoes off of the garage door. Great fun for me, not so much for those slug-a-beds still malingering in their bunks.
I've not had it that long, I may find a method to ease it away. In the meantime though, it'll be baffle in.
One of the "neighbours" in question is Mrs Borg who is still abed at 7am, so this is a non-negotiable issue. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:12 - 09 Apr 2014 Post subject: |
| map wrote: | Out of interest how long before warm and therefore not so noisy when moving? |
Dunno yet, I've only ridden it thoroughly warmed (when buying) and from fairly cold (at home). I'm not minded to become a warm-up merchant.
Early days though, never say never, game of two halves, fight them on the beaches. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:01 - 09 Apr 2014 Post subject: |
Choke, a good solid kick, one hard twist and we're off.
Hi Mumsnet. ____________________ Biking is 1/20th as dangerous as horse riding.
| biker7 |
 biker7 Crazy Courier
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
