Honda Varadero 125 ( 2011 ) - max 8500rpm - help
muruburu
PostPosted: 15:14 - 13 Apr 2014    Post subject: Honda Varadero 125 ( 2011 ) - max 8500rpm - help Reply with quote
Hello,
Just bought Varadero 125 11 plate , and discovered some restrictions ?
At 4 and 5 gear cant get more then 8500rpm , and Vara is bit weak.
I found possibly problems
1. There is a rubber bung in the airbox to restrict the flow of air.
2. The air filter itself is too small - but can be DIY replaced with a larger K&N.
3. Carb models are jetted differently for the front and rear cylinder - Fuel Injection models have different pulse widths for the front and rear injector.
4. The exhaust downpipes have restricter sections fitted internally to reduce the exhaust flow.
5. Fuel Injection models have a catalytic converter that further restricts airflow.
1st is sorted out - before max speed was ~50mph , now is ~55mph
For the rest maybe any1 can give me some advice how to do it?
PostPosted: 15:34 - 13 Apr 2014    Post subject: Reply with quote
Unless I'm being thicker than usual, why would you restrict a 125? Aren't they limited to 14kw or something stupid anyway?
muruburu
PostPosted: 15:51 - 13 Apr 2014    Post subject: Reply with quote
Maybe are somehow limited. but my friends Vara 125 easy get 65mph and 11500rpm , and my Honda at 8500rpm just starts choking if you know what I mean.
Fladdem
PostPosted: 16:05 - 13 Apr 2014    Post subject: Reply with quote
Here we go.
I had a 2005 Baby Vara.
The reason the carbs are jetted differently, is because, despite being watercooled, the rear cylinder will still get hotter than the front, so it needs a tiny bit more fuel to assist cooling. Don't worry about it.
Mine was standard, I took the bung out, all it did was make more induction noise, so it went back in. I got 80mph down fairly slight hill, I got off the clocks down the biggest hill in the area, and a smidge over 75 on the flat. I was at the time 6'3" and twelve and a half ish stone. Now, 6'5" and about 13 stone. Something is wrong with your bike. My dad is 17 stone and he can still cruise at a touch over 50 at 8,000 RPM. Thumbs Up
Maybe cutting the restrictors out the exhaust may help, but you need to be able to weld and understand the physics about gas flow and exhaust design, or performance will be hindered moreso. And after-market pipes, not the silencer, but the front pipes, are engineered in the same way, something to do with it being a replacement, rather than a performance enhancer.
To get rid of the cat, get a big stick and smash it down the tail-pipe, then take it off and shake the bits out.
Don't do that. I was joking. Do it. Laughing
The engine will never rev out in the top gears, it just doesn't have the torque to pull the gearing. Mine wouldn't get up to 10,000 in top. I would guess it stopped revving at about 9,750RPM, on a flat.
Maybe someone has change the gearing, and made it too tall for the engine to pull. I'm not sure what the standard gearing is, but maybe if you checked yours, and I checked mine we could have a look.
Does the engine make any noises? Smoke from the exhaust? How many miles has it done? What sort of range do you get to a tank? Maybe the air filter is dirty, and the bike is running rich, does she bog under acceleration? Did you check the filter while you were in there removing the bung that does nothing, apart from reduce air turbulence, thus giving better induction due to smoother flowing air? Or perhaps the rings are going? Possibly stretched valves... Maybe something simple like the brakes are rubbing slightly. Do they get REALLY hot after a ride?
Don't take it the wrong way, but are a you heavy person? It does have low torque and only about 14.5 BHP, weight could be the cause of the problems.
Mines just done 15,500 miles, I sold her to my dad, and the head gasket appears to be going in one, or maybe both, of the cylinders, oil in the coolant, coolant in the oil, and slightly down on power. I think it's because it sat for a year then got ragged mercilessly. Embarassed
Anyway, I don't think that you should bother messing with it too much. If the bike has been serviced correctly, it should be quite a strong engine.
muruburu
PostPosted: 17:46 - 13 Apr 2014    Post subject: Reply with quote
75 on the flat
Mine - no wind , nice weather ~58 on the flat :/
Wind in my face - 45-50mph
I`m bit more then 14 stones and 6`3"
Sounds too complicated for me...
No idea, all I know previous owner changed sprocket and chain.
How can I check it ?
No
No
7450 , its 11 plate
Checked , maybe change it for some K&N or smth , but I have no idea which one.
No idea
Wonko The Sane
PostPosted: 17:54 - 13 Apr 2014    Post subject: Reply with quote
Fladdem wrote:
Here we go.
Mine, in top gear would just hit the red but not go into it.
you can't take the restrictors out of the exhaust, the rear cylinder pipe is much narrower than the front, it's designed in.
You'd need to make a complete custom system to get round it
I looked into de-restricting mine when I'd passed my test, decided it wasn't worth it so sold it and bought a bigger bike.
Wonko The Sane
PostPosted: 18:09 - 13 Apr 2014    Post subject: Reply with quote
If larger sprocket on front then slower acceleration but higher top speed
If the previous owner wanted to use it on longer runs / motorway then they might have put a large sprocket on. You'd notice it take a little while to come up the revs, needing to keep the bike in gear until the top of the rev counter before changing up
If smaller sprocket on front then faster acceleration but lower top speed
if they were after beating people away from the lights they'll have gone for smaller - you'd notice high revs when flat out in top gear, bouncing it off the limiter.
Fladdem
PostPosted: 18:16 - 13 Apr 2014    Post subject: Reply with quote
Right, that seems underpowered for a varadero to me.
Two stone isn't going to make a difference, me and dad. two up, about 30 stone will still get about 55 from it.
Then, don't worry about it, it's too much for me too really, and I'm studying motorsport engineering.
I would suggest, cleaning the rear sprocket, there should be a marking on it telling you the size, if not, get some tipex or something, to mark one, then just start counting the teeth on the rear sprocket. Same on the front.
Recently changed the filter in ours. Just a standard one, but clean. It improved throttle response a bit, not sure about power.
I looked into tuning mine as well, after passing my test, but I coudn't justify the effort/cost over just getting another bike.
The fact you say:
Makes me think that the bike is running rich, meaning something is restricting airflow at higher RPM. So perhaps the filter is just knackered. Will it rev past that in lower gears? If it does, I'm stumped. Or I just thought, sometimes spark plugs will cause weird problems when they start getting old/worn out. But at 7,450 they may not be worn out, still for ten pounds or whatever, may be worth a shot. Or at wemoto, try their air filter, not the OEM honda, although again, at two years old, it may not need replacing.
gbrand42
PostPosted: 20:32 - 13 Apr 2014    Post subject: Reply with quote
Something definitely not right here. I'm around 125kg and my Varadero sits happily at 65-70 on the flat, will hold 55-60 up quite reasonable slopes if I drop a cog to 4th and cane it. If its only revving to 8500 I'm wondering if its not a UK spec bike. I've heard of foreign spec Varaderos having a different ignition system computer thingy that restricts revs (possibly for the German market although not sure).
Maybe a you could ring a friendly Honda dealer to get them to check the VIN?
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
_mjs_
PostPosted: 23:05 - 13 Apr 2014    Post subject: Reply with quote
Another fat 'Dero owner reporting in, mine would do 75mph and it was a neglected shed.
To see if the gearing has been altered, count the teeth on the front and rear sprockets, stock gearing is 14/44.
PostPosted: 06:07 - 14 Apr 2014    Post subject: Reply with quote
Look at gearing, perhaps consider checking the injectors for crap, get them cleaned.
My 77,000 mile 07 Vara never had an issue and pulled to the max revs every day for 20 miles.
muruburu
PostPosted: 08:13 - 14 Apr 2014    Post subject: Reply with quote
The rear is 44, front I`ll check tommorow cuz don't have wrench to take off chain / sprocket guard.
If you right , can they fix it in UK ?
If so , do I need find Honda dealer or just nearest garage ?
iooi
Have a look here Thumbs Up
muruburu
PostPosted: 12:49 - 16 Apr 2014    Post subject: Reply with quote
Hello,
Front sprocket is 14. So I have 14/44 .
Without rubber bung in the airbox and with unleaded 97 in the tank, Varadero drive much much better... but still not perfect :/
But I can drive 55mph easy. No wind in my face - 60mph.
Im waiting for new air filter , if it does not help then only option will be visit some Honda dealer. Maybe they help me. But it will be expensive I think.
Andy_Pagin
PostPosted: 15:15 - 16 Apr 2014    Post subject: Reply with quote
Start with a full service, plugs, oil, filters. Check the HT leads aren't corroded or otherwise obviously knackered, they should be fine at that mileage, crappy electrics account for an awful lot of engine problems.
Wonko The Sane
PostPosted: 18:39 - 16 Apr 2014    Post subject: Reply with quote
I used to squirt a small amount of fuel system cleaner in mine every once in a while and generally run it on cheap supermarket fuel
muruburu
PostPosted: 13:19 - 17 Apr 2014    Post subject: Reply with quote
This bike is really well maintained.
I got 1 question guys , cuz you are much more experienced.
What you think about exchange this Honda for:
1. Suzuki GZ125
2. Yamaha WR125X
Both are similar prices, and generally it could be good deal for me.
I am just not sure about Suzuki as I am 6`3"
If anybody tall or taller then me has Suzuki , tell me please is comfortable to ride ~100miles ?
Fladdem
PostPosted: 13:30 - 17 Apr 2014    Post subject: Reply with quote
I wouldn't bother swapping really.
I love the Varadero's I wish there was a 400. Closest thing is a TDR 250. It'll be comfier than both of those, and should be faster too. At least on par with the WR. It kept up with my cousins YZF-R125, he only had a touch more top-end though. But I paid 1700 for mine, he paid 3,500. So I win. And he struggled going round cones on his for the mod 1, mine was easy. Alas, I digress.
I think ,maybe, it just needs some love. Have you tried just changing spark plugs, oil, oil filter and air filter? Just basic maintenance can sometimes do a world of good. Although you said it's well maintained.
The GZ would be a comfier choice, perhaps, butbeing tall, like me, you may struggle with the bars in your lap and knees round your ears. Laughing
But a WR has a skinny seat, but you're a teenager, like me so you're probably man enough/stupid enough to just put up with it. I know I do on my TTR. I get cramps after about 40 miles, I put 120 something miles on the old girl yesterday, it was tiresome on a 250 single with no wind protection, but like I said, I'm just too stupid to stop. Thumbs Up
PostPosted: 13:37 - 17 Apr 2014    Post subject: Reply with quote
Evidently not, mine was fairly neglected and did an indicated 85 all day...
You need to get it stripped, cleaned and running nicely.
I wouldn't trade it for the GZ at all. Faggots own GZs, are you a faggot?
The WR is nice, but lets face it, no one will trade for a Varadero. It is worth far more than the Varadero. Doesn't go any faster, more likely to get robbed by scrap man Joes kids.
Fladdem
PostPosted: 13:45 - 17 Apr 2014    Post subject: Reply with quote
Mine was neglected by previous owner, but was carbed, I only saw those dizzying speeds going down a hill, a big one, But would get close to 80 on a flat. although my dads 1970 something cb125T got 86 on a flat. How's that for progression?!? He owned it at the same time I had my 125. And he had a top box the size of an original mini on the back.
Paddy's right. You don't want a GZ and no one with a WR will want a Varadero. I suggest trying to properly find out what's wrong with yours, because you should have an awesome bike there, one of my favourite modern 125's, well... out of the four strokes.
muruburu
PostPosted: 13:55 - 17 Apr 2014    Post subject: Reply with quote
Ok, thank you for your opinion.
The bike been checked by local garage aswell. They told me its briliant condition and everything works perfect...
I just cleaned and lubed chain last weekend.
So, I will wait and 1st I will check new air filter ( when it comes )
It just make me sick when I cant drive even 50-55 mph just cuz some wind in my face or small uphill :/
Yaka
PostPosted: 22:02 - 19 Apr 2014    Post subject: Reply with quote
strange that you are strugling for speed, im no expert my ive done 65 on my 2007 vara, im 22 stones
Current Bike : 2008 Varadero XL125
mod 1: passed 16/02/2015
mod 2: passed 19/02/2015
muruburu
PostPosted: 09:05 - 20 Apr 2014    Post subject: Reply with quote
Try to drive no more than 45-50mph on A roads... will be long tail of cars, with angry drivers behind you Wink , then, you will understand how it can piss off, when they try to overtake.
And the point is that I travel a lot , I think ( for example - last Thursday , I did around 200miles, Yesterday - 70 , today - who knows ... ) And sometimes, I just need to be a bit faster.
Anyway, I visited Honda dealer yesterday... They have no idea what is wrong with my Honda... they can take and check this bike, but earliest, they can do it... is middle of may. ( cuz they are busy )
And it looks that I lost a lot of time and money...
I just can not wait :/ . So decided to exchange Honda. I am not sure , what I will take... we will see tomorrow.
Please don`t attack me , I don`t say that Varadero is a bad bike... Its really really comfortable and beautiful bike... but this one just pissed me off...
Teflon-Mike
tl;dr
PostPosted: 11:55 - 20 Apr 2014    Post subject: Reply with quote
This might sound daft, but... have you tried changing down to 3rd... get the revs almost in the red, up to 4th, let it rev into the red, then hook 5th?
Very common newbie niggle, this...
To get past 60mph, Learner-Legals need all the power they can make; trouble is, they only make enough at peak power revs. Lower down they have a fair amount of oomph, and newbs will often 'short shift', and get into fourth or firth gear before about 40mph.
Thing is, you only need about 3-4bhp, as much as a moped has, to go that fast, so letting the motor labour in the lower revs where thats all the engine has, they feel fine...
Then they pass a the NSL sign, and open the throttle....
3-4000rpm, engine has enough power 'spare' to accelerate a little, but then they hit a wall, where as road speed increases, so does wind resistance, and at about 50-55, that wind resistance is more than the force the engine can make, and the bike 'tops out', and seemingly wont go any faster; simply because the force the engine is making at those lower revs, and in that high a gear isn't increasing as fast with revs as wind resistance is with road-speed.
Change down, thrash the knackers off the thing.... two things many more cautious newbies are reluctant to try... but, gets the revs up where the engine can make the force to over come wind resistance at higher speeds.
Might not be a thing wrong with the bike; and if, as you believe, the bike is in good, well maintained standard condition, ought to be able to get up to 70ish, so this is the more likely.
PostPosted: 11:58 - 20 Apr 2014    Post subject: Reply with quote
Yeah but you're not:
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 146.22 Kb
