| muruburu |
 muruburu Two Stroke Sniffer
| Polarbear |
 Polarbear Super Spammer
| muruburu |
| Fladdem |
 Fladdem World Chat Champion
 Posted: 16:05 - 13 Apr 2014 Post subject: |
Here we go.
I had a 2005 Baby Vara.
The reason the carbs are jetted differently, is because, despite being watercooled, the rear cylinder will still get hotter than the front, so it needs a tiny bit more fuel to assist cooling. Don't worry about it.
Mine was standard, I took the bung out, all it did was make more induction noise, so it went back in. I got 80mph down fairly slight hill, I got off the clocks down the biggest hill in the area, and a smidge over 75 on the flat. I was at the time 6'3" and twelve and a half ish stone. Now, 6'5" and about 13 stone. Something is wrong with your bike. My dad is 17 stone and he can still cruise at a touch over 50 at 8,000 RPM.
Maybe cutting the restrictors out the exhaust may help, but you need to be able to weld and understand the physics about gas flow and exhaust design, or performance will be hindered moreso. And after-market pipes, not the silencer, but the front pipes, are engineered in the same way, something to do with it being a replacement, rather than a performance enhancer.
To get rid of the cat, get a big stick and smash it down the tail-pipe, then take it off and shake the bits out.
Don't do that. I was joking. Do it.
The engine will never rev out in the top gears, it just doesn't have the torque to pull the gearing. Mine wouldn't get up to 10,000 in top. I would guess it stopped revving at about 9,750RPM, on a flat.
Maybe someone has change the gearing, and made it too tall for the engine to pull. I'm not sure what the standard gearing is, but maybe if you checked yours, and I checked mine we could have a look.
Does the engine make any noises? Smoke from the exhaust? How many miles has it done? What sort of range do you get to a tank? Maybe the air filter is dirty, and the bike is running rich, does she bog under acceleration? Did you check the filter while you were in there removing the bung that does nothing, apart from reduce air turbulence, thus giving better induction due to smoother flowing air? Or perhaps the rings are going? Possibly stretched valves... Maybe something simple like the brakes are rubbing slightly. Do they get REALLY hot after a ride?
Don't take it the wrong way, but are a you heavy person? It does have low torque and only about 14.5 BHP, weight could be the cause of the problems.
Mines just done 15,500 miles, I sold her to my dad, and the head gasket appears to be going in one, or maybe both, of the cylinders, oil in the coolant, coolant in the oil, and slightly down on power. I think it's because it sat for a year then got ragged mercilessly.
Anyway, I don't think that you should bother messing with it too much. If the bike has been serviced correctly, it should be quite a strong engine. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| muruburu |
 Posted: 17:46 - 13 Apr 2014 Post subject: |
Mine - no wind , nice weather ~58 on the flat :/
Wind in my face - 45-50mph
| Quote: | I was at the time 6'3" and twelve and a half ish stone |
I`m bit more then 14 stones and 6`3"
| Quote: | Maybe cutting the restrictors out the exhaust may help, but you need to be able to weld and understand the physics about gas flow and exhaust design, or performance will be hindered moreso. And after-market pipes, not the silencer, but the front pipes, are engineered in the same way, something to do with it being a replacement, rather than a performance enhancer. |
Sounds too complicated for me...
| Quote: | Maybe someone has change the gearing |
No idea, all I know previous owner changed sprocket and chain.
| Quote: | I'm not sure what the standard gearing is, but maybe if you checked yours, and I checked mine we could have a look. |
How can I check it ?
| Quote: | Does the engine make any noises? |
No
| Quote: | Smoke from the exhaust? |
No
| Quote: | How many miles has it done? |
7450 , its 11 plate
| Quote: | Did you check the filter |
Checked , maybe change it for some K&N or smth , but I have no idea which one.
| Quote: | Or perhaps the rings are going? Possibly stretched valves... |
No idea |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 17:54 - 13 Apr 2014 Post subject: |
| Fladdem wrote: | Here we go.
Mine, in top gear would just hit the red but not go into it.
you can't take the restrictors out of the exhaust, the rear cylinder pipe is much narrower than the front, it's designed in.
You'd need to make a complete custom system to get round it
I looked into de-restricting mine when I'd passed my test, decided it wasn't worth it so sold it and bought a bigger bike. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| Wonko The Sane |
| Fladdem |
 Posted: 18:16 - 13 Apr 2014 Post subject: |
| muruburu wrote: |
Wind in my face - 45-50mph | Right, that seems underpowered for a varadero to me.
I`m bit more then 14 stones and 6`3" | Two stone isn't going to make a difference, me and dad. two up, about 30 stone will still get about 55 from it.
| Quote: | Sounds too complicated for me... |
Then, don't worry about it, it's too much for me too really, and I'm studying motorsport engineering.
| Quote: |
How can I check it ? |
I would suggest, cleaning the rear sprocket, there should be a marking on it telling you the size, if not, get some tipex or something, to mark one, then just start counting the teeth on the rear sprocket. Same on the front.
Checked , maybe change it for some K&N or smth , but I have no idea which one. |
Recently changed the filter in ours. Just a standard one, but clean. It improved throttle response a bit, not sure about power.
I looked into tuning mine as well, after passing my test, but I coudn't justify the effort/cost over just getting another bike.
The fact you say:
| Quote: | and my Honda at 8500rpm just starts choking if you know what I mean. |
Makes me think that the bike is running rich, meaning something is restricting airflow at higher RPM. So perhaps the filter is just knackered. Will it rev past that in lower gears? If it does, I'm stumped. Or I just thought, sometimes spark plugs will cause weird problems when they start getting old/worn out. But at 7,450 they may not be worn out, still for ten pounds or whatever, may be worth a shot. Or at wemoto, try their air filter, not the OEM honda, although again, at two years old, it may not need replacing. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| gbrand42 |
 gbrand42 Could Be A Chat Bot
| _mjs_ |
 _mjs_ Could Be A Chat Bot
| P.addy |
 P.addy Red Rocket
| muruburu |
| iooi |
 iooi Super Spammer
 Posted: 08:13 - 14 Apr 2014 Post subject: |
Have a look here ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| muruburu |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 15:15 - 16 Apr 2014 Post subject: |
Start with a full service, plugs, oil, filters. Check the HT leads aren't corroded or otherwise obviously knackered, they should be fine at that mileage, crappy electrics account for an awful lot of engine problems. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| Wonko The Sane |
| muruburu |
| Fladdem |
 Posted: 13:30 - 17 Apr 2014 Post subject: |
I wouldn't bother swapping really.
I love the Varadero's I wish there was a 400. Closest thing is a TDR 250. It'll be comfier than both of those, and should be faster too. At least on par with the WR. It kept up with my cousins YZF-R125, he only had a touch more top-end though. But I paid 1700 for mine, he paid 3,500. So I win. And he struggled going round cones on his for the mod 1, mine was easy. Alas, I digress.
I think ,maybe, it just needs some love. Have you tried just changing spark plugs, oil, oil filter and air filter? Just basic maintenance can sometimes do a world of good. Although you said it's well maintained.
The GZ would be a comfier choice, perhaps, butbeing tall, like me, you may struggle with the bars in your lap and knees round your ears.
But a WR has a skinny seat, but you're a teenager, like me so you're probably man enough/stupid enough to just put up with it. I know I do on my TTR. I get cramps after about 40 miles, I put 120 something miles on the old girl yesterday, it was tiresome on a 250 single with no wind protection, but like I said, I'm just too stupid to stop.  ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| P.addy |
 P.addy Red Rocket
| Fladdem |
 Posted: 13:45 - 17 Apr 2014 Post subject: |
| Paddy wrote: | Evidently not, mine was fairly neglected and did an indicated 85 all day...
Mine was neglected by previous owner, but was carbed, I only saw those dizzying speeds going down a hill, a big one, But would get close to 80 on a flat. although my dads 1970 something cb125T got 86 on a flat. How's that for progression?!? He owned it at the same time I had my 125. And he had a top box the size of an original mini on the back.
Paddy's right. You don't want a GZ and no one with a WR will want a Varadero. I suggest trying to properly find out what's wrong with yours, because you should have an awesome bike there, one of my favourite modern 125's, well... out of the four strokes. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| muruburu |
| Yaka |
 Yaka Borekit Bruiser
| muruburu |
 Posted: 09:05 - 20 Apr 2014 Post subject: |
Try to drive no more than 45-50mph on A roads... will be long tail of cars, with angry drivers behind you , then, you will understand how it can piss off, when they try to overtake.
And the point is that I travel a lot , I think ( for example - last Thursday , I did around 200miles, Yesterday - 70 , today - who knows ... ) And sometimes, I just need to be a bit faster.
Anyway, I visited Honda dealer yesterday... They have no idea what is wrong with my Honda... they can take and check this bike, but earliest, they can do it... is middle of may. ( cuz they are busy )
And it looks that I lost a lot of time and money...
I just can not wait :/ . So decided to exchange Honda. I am not sure , what I will take... we will see tomorrow.
Please don`t attack me , I don`t say that Varadero is a bad bike... Its really really comfortable and beautiful bike... but this one just pissed me off... |
| Teflon-Mike |
 Posted: 11:55 - 20 Apr 2014 Post subject: |
This might sound daft, but... have you tried changing down to 3rd... get the revs almost in the red, up to 4th, let it rev into the red, then hook 5th?
Very common newbie niggle, this...
To get past 60mph, Learner-Legals need all the power they can make; trouble is, they only make enough at peak power revs. Lower down they have a fair amount of oomph, and newbs will often 'short shift', and get into fourth or firth gear before about 40mph.
Thing is, you only need about 3-4bhp, as much as a moped has, to go that fast, so letting the motor labour in the lower revs where thats all the engine has, they feel fine...
Then they pass a the NSL sign, and open the throttle....
3-4000rpm, engine has enough power 'spare' to accelerate a little, but then they hit a wall, where as road speed increases, so does wind resistance, and at about 50-55, that wind resistance is more than the force the engine can make, and the bike 'tops out', and seemingly wont go any faster; simply because the force the engine is making at those lower revs, and in that high a gear isn't increasing as fast with revs as wind resistance is with road-speed.
Change down, thrash the knackers off the thing.... two things many more cautious newbies are reluctant to try... but, gets the revs up where the engine can make the force to over come wind resistance at higher speeds.
Might not be a thing wrong with the bike; and if, as you believe, the bike is in good, well maintained standard condition, ought to be able to get up to 70ish, so this is the more likely. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
