| knitinglee |
 knitinglee L Plate Warrior
 Posted: 19:28 - 13 Apr 2014 Post subject: triumph tiger cub,electrics. |
Hi to you all,
I`m a forum virgin,and I need help,I have a 1960 triumph tiger cub,I`ve rebuilt it from the ground up,everything was going well until it came to the electrics,its 6 volt,positive earth,with a combined ignition/lighting switch,when I turn on the lights to the first position,I get parking lights front and rear,if I go to position two,I get front dip and main beam,but no rear light,if I turn on the ignition the main power feed from the battery starts melting also the rectifier gets really hot,I know I`ve done something stupid but I can`t find out what,all the wires are following the wiring diagram,I`ve checked and checked,but I cant find out whats wrong,any help would be great,thanks mandy. |
| WD Forte |
 WD Forte World Chat Champion
| Islander |
 Islander World Chat Champion
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| WD Forte |
| knitinglee |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| knitinglee |
 Posted: 09:10 - 21 Apr 2014 Post subject: triumph tiger cub electrics,again, |
After spending four days locked away in my garage,I must admit defeat,and once again throw myself on your mercy,1960 tiger cub,200cc,frame and engine number T20, 67561,I have three wires coming from the alternator,dark green,mid green,light green,the wiring was complete up to the combined ignition/lights switch,the only thing I have done is to wire the combined switch up to a wiring diagram from the haynes tiger cub book,it shows external links,from 12=10,on the combined switch,everything is good power to lights,but no power to ignition,but once I bridge 2=12,the rectifier gets hot,the power cable gets hot,no 1 =pilot light,No2 from battery,links to no12,no 3 =dip switch,no7 alt,no8 tail light,10 linked to 12,12=horn=2=10,13=rectifier,14 coil sw,15coil cb,16 alternator,any help or mystic spell to the prince of darkness ,would be great,thanks people from Mandy.[/img] |
| WD Forte |
| knitinglee |
 Posted: 17:31 - 26 Apr 2014 Post subject: |
Thanks for all your help everyone,especially WD forte,
I`ve tested the alternator,rectifier,wiring,combined ignition/light switch,each checks out on its own,put it all together,exactly the same,rectifier immediately gets very hot,I`ve used the wiring diagram from the haynes manual,this diagram checks out,with my wiring,but I will try out the diagram from WD forte,will let you know when I find out what the fault is,thanks again mandy. |
| Lone-Wolf |
 Posted: 20:28 - 26 Apr 2014 Post subject: |
Wotcha.
This is why I *ALWAYS* change to 12 volt.
More helpful info HERE ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
